楼主: 鱼与熊掌
[已解答] 求完善下代码.(画线并自动标注功能) (源码来自73.)
发表于 2014-6-3 17:45:03 | 显示全部楼层
;;根据鱼与熊掌君提供的程序,添加两点:1保留小数位数时如果位数不足可以补零2自定义字高
(defun c:tts (/ p q pt en obj)
;(setvar'osmode 16384)
(setvar"dimzin"0);;保留小数位数时如果位数不足可以补零
(setq TextHeight (getdist "\n请输入文字高度:"))
  (setq os_bak(getvar 'cmdecho))
  (setvar 'cmdecho 0)
  (setq p (getpoint "\n指定起点"))
  (while p
    (if        p
        (command "pline" "_non" p)
        (while (setq q        (getpoint p "下一点")
                     pt        (mapcar '(lambda (x) (* x 0.5)) (mapcar '+ p q))
          (command "_non" q)
          (entmake (list '(0 . "TEXT")
                         (cons 10 pt)
                         (cons 40 1)
                         (cons 1 (rtos (distance p q) 2 2))
                         (cons 50
                               (if (and        (< (/ Pi 2) (angle p q))
                                        (> (* 1.5 pi) (angle p q))
                                 (angle q p)
                                 (angle p q)
                        (cons 8 "标注")
                         (cons 7 "BG_ST")
                         (cons 62 3)
                         (cons 72 1)
                         (cons 73 1)
                         (cons 40 TextHeight)
                         (cons 41 0.7)
                         (cons 11 pt)
          (setq p q)
        (if (>(getvar 'CMDACTIVE) 0) (command ""))
      ;(setvar 'osmode (- (getvar osmode) 16384))
  (if os_bak(setvar 'cmdecho os_bak))
发表于 2014-6-4 09:14:45 | 显示全部楼层
压缩一下
  1. (defun c:tts (/ p q pt)
  2. ;(setvar'osmode 16384)
  3. (setvar "cmdecho" 0)
  4. (setvar "dimzin" 0);;保留小数位数时如果位数不足可以补零
  5. (setq TextHeight (getdist "\n请输入文字高度: "))
  6. (while (setq p (getpoint "\n指定起点: "))
  7.   (command "pline" "_non" p)
  8.   (while (setq q (getpoint p "\n下一点: ")
  9.                      pt (mapcar '(lambda (x) (/ x 2)) (mapcar '+ p q)))
  10.    (command "_non" q)
  11.    (entmake
  12.     (list
  13.      '(0 . "TEXT")
  14.      (cons 10 pt)
  15.      (cons 40 1)
  16.      (cons 1 (rtos (distance p q) 2 2))
  17.      (cons 50 (if (< (/ Pi 2) (angle p q) (* 1.5 pi)) (angle q p) (angle p q)))
  18.      (cons 8 "标注")
  19.      (cons 7 "BG_ST")
  20.      (cons 62 3)
  21.      (cons 72 1)
  22.      (cons 73 1)
  23.      (cons 40 TextHeight)
  24.      (cons 41 0.7)
  25.      (cons 11 pt)
  26.     )
  27.    )
  28.    (setq p q)
  29.   )
  30.   (command "")
  31. )
  32.   ;(setvar 'osmode (- (getvar osmode) 16384))
  33. (setvar "cmdecho" 1)
  34. (princ)
  35. )
 楼主| 发表于 2014-6-4 10:12:50 | 显示全部楼层
ZZXXQQ 发表于 2014-6-4 09:14
压缩一下
酷炫`~~~   d     `````
发表于 2022-5-19 09:09:42 | 显示全部楼层
CAD2006试了,没显示标注
GMT+8, 2026-1-16 12:41 , Processed in 0.175233 second(s), 19 queries , Gzip On.
