楼主: 李青松
[提问] 请问e派工具箱的xy方向缩放工具的源程序是什么 ?要他的那种效果
发表于 2014-7-31 07:19:53 | 显示全部楼层
  1. ;x,y方向不同比例缩放
  2. ; ***  XSCALE   [Version 1.0] 6/22/2005  ***
  3. ;
  4. ;Copyleft Gu Wenwei
  5. ;
  6. ; ***************************************
  7. ; ****  Author:  Apooollo            ****
  8. ; ****                               ****
  9. ; ****  Wuxi Jiangsu China           ****
  10. ; ***************************************
  11. ;
  12. ;
  13. ; This program takes selected objects, defines an anonymous block,
  14. ; then inserts the block at the original location, Scale by X,Y
  15. (defun C:XSCALE(/ bp ss xscal yscal entL)
  16.   (defun errexit (s)
  17.     (princ "\nError:  ")
  18.     (princ s)
  19.     (restore)
  20.   )
  21.   (defun restore ()
  22.     (setvar "CMDECHO" (car oldvar))
  23.     (setq *error* olderr)
  24.     (princ)
  25.   )
  26.
  27. (defun MAKEUNBLOCK (ss ip / tmp errexit mbx BLAYER)
  28.   (setq T (not nil))
  29.   (setq olderr  *error*
  30.         *error* errexit
  31.   )
  32.   (setq oldvar
  33.     (list
  34.       (getvar "CMDECHO")
  35.     )
  36.   )
  37.   (setvar "CMDECHO" 0)
  38.   (terpri)
  39.   (if BLAYER
  40.     (command "._LAYER"
  41.       (if (tblsearch "LAYER" BLAYER) "_S" "_M")
  42.       BLAYER
  43.       ""
  44.     )
  45.   )
  46.   (if (and ip ss)
  47.     (progn
  48.       (entmake (list
  49.         (cons '0 "BLOCK")
  50.         (cons '2 "*U")
  51.         (cons '70 1)
  52.         (cons '10 ip)
  53.       ))
  54.       (setq cnt (sslength ss))
  55.       (while (>= (setq cnt (1- cnt)) 0)
  56.         (setq tmp (ssname ss cnt))
  57.         (entmake (setq el (entget tmp)))
  58.         (if (> (cdr (assoc 66 el)) 0)
  59.           (while
  60.             (/= "SEQEND"
  61.               (cdr
  62.                 (assoc 0
  63.                   (entmake (setq el (entget (entnext (cdr (assoc -1 el))))))
  64.                 )
  65.               )
  66.             )
  67.           )
  68.         )
  69.         (entdel tmp)
  70.       )
  71.       (setq tmp (entmake (list (cons '0 "ENDBLK"))))
  72.       (entmake (list
  73.         (cons '0 "INSERT")
  74.         (cons '2 tmp)
  75.         (cons '10 ip)
  76.       ))
  77.     )
  78.   )
  79.   (restore)
  80. )
  81.   (setq ss (ssget))    ;;; 选择缩放实体
  82.   (if ss
  83.     (progn
  84.       (setvar "cmdecho" 0)
  85.       (setq bp (getpoint "缩放基准点 (<0,0,0>): "))
  86.       (if (not bp) (setq bp (list 0 0 0)))
  87.       (setq xscal (getreal "X向比例因子 <1>: "))
  88.       (if (not xscal) (setq xscal 1))
  89.       (setq yscal (getreal "Y向比例因子 <1>: "))
  90.       (if (not yscal) (setq yscal 1))
  91.       (MAKEUNBLOCK ss bp)
  92.       (setq entL (entget (entLast))
  93.           entL (subst (cons 41 xscal) (assoc 41 entL) entL)
  94.           entL (subst (cons 42 yscal) (assoc 42 entL) entL)
  95.       )
  96.       (entmod entL)
  97.       (command "_explode" "l" "")
  98.     )
  99.   )
  100.   (princ "X,Y不同比例缩放, 命令:XSCALE")
  101. )
发表于 2020-9-11 11:49:06 | 显示全部楼层
支持支持,谢谢楼主的话题,谢谢各位大神的讨论
GMT+8, 2026-1-16 01:36 , Processed in 0.169953 second(s), 20 queries , Gzip On.
