楼主: 77077
[已解答] 函数搜索,便于大家收集整理自己的函数库~~~
发表于 2017-10-31 10:29:19 | 显示全部楼层
程序真的很不错,谢谢分享啊。
发表于 2018-2-8 23:21:02 来自手机 | 显示全部楼层
谢谢楼主无私分享,非常好,好好学习,好好用,大大提高效率
发表于 2022-12-4 03:22:16 | 显示全部楼层
感谢大佬分享~
发表于 2022-12-4 18:50:50 | 显示全部楼层
感谢无私分享
发表于 2022-12-29 17:55:17 | 显示全部楼层
不知道是怎么个搜索
发表于 2023-2-1 15:51:39 | 显示全部楼层
这个对话框有问题
发表于 2023-7-22 20:08:41 | 显示全部楼层
怎么啥都不显示,对话框里啥都不显示?
发表于 2023-7-25 18:02:17 | 显示全部楼层
修改了AutoCAD2021运行的问题
  1. (defun make-dcl  (/ lst_str str file f)
  2.     (setq lst_str '(
  3. "hsss:dialog {"
  4. "    label = \"函数搜索\" ;"
  5. "    :spacer {}"
  6. "    :row {"
  7. "        :edit_box {"
  8. "            key = \"key1\" ;"
  9. "            label = \"关键词(&K)\" ;"
  10. "            width = 60 ;"
  11. "        }"
  12. "        :button {"
  13. "            key = \"key2\" ;"
  14. "            label = \"搜索(&S)\" ;"
  15. "        }"
  16. "        :button {"
  17. "            key = \"key3\" ;"
  18. "            label = \"显示全部(&A)\" ;"
  19. "        }"
  20. "    }"
  21. "    :boxed_column {"
  22. "        label = \"函数列表(&L)\" ;"
  23. "        :list_box {"
  24. "            key = \"key4\" ;"
  25. "        }"
  26. "    }"
  27. "    :edit_box {"
  28. "        key = \"key5\" ;"
  29. "        label = \"功能(&F)\" ;"
  30. "    }"
  31. "    :edit_box {"
  32. "        key = \"key6\" ;"
  33. "        label = \"用法(&U)\" ;"
  34. "    }"
  35. "    :spacer {}"
  36. "        :row {"
  37. "    ok_cancel;"
  38. "        :button {"
  39. "            key = \"key7\" ;"
  40. "            label = \"执行(&R)\" ;"
  41. "            fixed_width = true ;"
  42. "            width = 12 ;"
  43. "        }"
  44. "        }"
  45. "}"
  46.         )
  47.     )
  48.     (setq file (vl-filename-mktemp "DclTemp.dcl"))
  49.     (setq f (open file "w"))
  50.     (foreach str lst_str
  51.   (princ "\n" f)
  52.   (princ str f)
  53.     )
  54.     (close f)
  55.     file
  56. )
  57. ;读取txt文本文件,按行组成表
  58. (defun xx-txt2lst(files / out)
  59. (setq file (open files "r"))
  60. (setq out '())
  61. (while (setq a (read-line file))
  62.       (if (= (substr a 1 2) ";[");只提取";["开头的行.
  63.       (setq out (cons a out))
  64.       )
  65.   )
  66. (close file)
  67. (setq out (reverse out))
  68. )
  69. ;填充列表框
  70. (defun fill-list-box (key lst)
  71.      (start_list key)
  72.      (mapcar 'add_list lst)
  73.      (end_list)
  74. )
  75. ;;返回关键字所在的字符串表位置
  76. ;;code by edata@mjtd
  77. (defun sk_ss_str(str_lst key_str / i lst lst2)
  78.   (setq i -1 lst str_lst)
  79.   (while (setq a(car lst))
  80.     (setq lst(cdr lst) i (1+ i))
  81.     (if(wcmatch a (strcat "*" key_str "*"))
  82.       (setq lst2(cons  i lst2)))
  83.     )
  84.   (if lst2 (setq lst2(reverse lst2)))
  85. )
  86. ;=================程序开始========================
  87. (defun C:HSSS( / lst  lst1 lst2 lstx1 lstx2 dcl_file)
  88.   (setq f(open "D:\\XX工具箱\\我的函数库.lsp" "r"))
  89.   (if f (progn (and f (close f))(setq sk_path  "D:\\XX工具箱\\我的函数库.lsp"))
  90.     (or sk_path (setq sk_path(getfiled "选择函数库文件" "c:/" "lsp;dat;txt;*" 8))))
  91. (if sk_path
  92.   (progn
  93. (setq lst  (xx-txt2lst sk_path)
  94.       lst1  (vl-remove-if '(lambda (x) (/= (substr x 1 (if (= (getvar 'lispsys) 1) 5 7)) ";[功能]")) lst)
  95.       lst2  (vl-remove-if '(lambda (x) (/= (substr x 1 (if (= (getvar 'lispsys) 1) 5 7)) ";[用法]")) lst)
  96.       lst1  (mapcar '(lambda (x) (substr x (if (= (getvar 'lispsys) 1) 6 8))) lst1)
  97.       lst2  (mapcar '(lambda (x) (substr x (if (= (getvar 'lispsys) 1) 6 8))) lst2)
  98.       lstx1 lst1
  99.       lstx2 lst2
  100.       )
  101. (setq dcl_id (load_dialog (setq dcl_file (make-dcl))))
  102. (if(findfile dcl_file)(vl-file-delete dcl_file))
  103. (new_dialog "hsss" dcl_id)
  104. (fill-list-box "key4" lstx1)
  105. (action_tile "key2" "(act-key2 lst1 lst2)")
  106. (action_tile "key3" "(act-key3)")
  107. (action_tile "key4" "(act-key4)")
  108. (action_tile "accept" "(act-key5)(done_dialog)")
  109. (action_tile "key7" "(act-key7)(done_dialog)")
  110. (start_dialog)(unload_dialog dcl_id)
  111. )
  112.   )
  113. (princ)
  114. )
  115. ;============DCL动作=============
  116. (defun act-key2(lst1 lst2 / str)
  117. (setq str (get_tile "key1"))
  118.   (if (setq key_ss (sk_ss_str lst1 str))
  119.     (progn
  120.       (setq i -1 lstx1 '()  lstx2 '())
  121.       (while(setq a (nth (setq i (1+ i)) key_ss))
  122.         (setq lstx1(cons (nth a lst1) lstx1))
  123.         (setq lstx2(cons (nth a lst2) lstx2))
  124.         )
  125.       (if(and lstx1 lstx2)
  126.         (progn
  127.         (setq lstx1 (reverse lstx1)
  128.               lstx2 (reverse lstx2))
  129.         (fill-list-box "key4" lstx1)
  130.         )
  131.         )
  132.       )
  133.     (fill-list-box "key4" '("Sorry,未找到与描述相符的函数!"))
  134.     )
  135. )
  136. ;
  137. (defun act-key4( / n)
  138. (setq n (atoi (get_tile "key4")))
  139. (set_tile "key5" (nth n lstx1))
  140. (set_tile "key6" (nth n lstx2))
  141. )
  142. ;
  143. (defun act-key3 ()
  144. (setq lstx1 lst1 lstx2 lst2)
  145. (fill-list-box "key4" lst1)
  146. )
  147. ;
  148. (defun act-key5        (/ str)
  149.   (if (/= (setq str (get_tile "key6")) "")
  150.     (sk_SetClipboard str)
  151.   )
  152. )
  153. ;
  154. (defun act-key7        (/ str)
  155.   (if (/= (setq str (get_tile "key6")) "")
  156.     (progn
  157.       (sk_SetClipboard str)
  158.     (if sk_path(load  sk_path))
  159.       (vla-SendCommand (vla-get-activedocument(vlax-get-acad-object)) (strcat str " "))
  160.        )
  161.   )
  162. )
  163. (defun sk_SetClipboard(clip / htm Clip_Bord);设置剪切板
  164. (setq htm (vlax-create-object "htmlfile"))
  165. (setq Clip_Bord (Vlax-Get-Property (Vlax-Get htm 'ParentWindow) 'ClipboardData))
  166. (Vlax-Invoke Clip_Bord 'SetData "text" clip)
  167. )
GMT+8, 2026-1-12 04:54 , Processed in 0.154538 second(s), 20 queries , Gzip On.
