楼主: 357785513
[基础] 好长时间没发铁了,现在发一个铁,
发表于 2014-10-1 18:58:44 | 显示全部楼层
  1. ;;;制作命名为HG1.dwg的图存入支持搜索文件路径内,加入下面两行代码(如果块HG1未定义的话):
  2. ;;(command "INSERT" "HG1" '(0 0 0) 1 1 0)(command "erase" (entlast) "")试试看。
  3. (defun C:aa (/ pt1 pt2)
  4.    (command "INSERT" "HG1" '(0 0 0) 1 1 0)
  5.     (command "erase" (entlast) "")
  6.   (setq pt1 (getpoint "\n指定第一点:"))
  7.   (entmake (list '(0 . "INSERT") (cons 2 "hg1") (cons 10 pt1)))
  8.   (while (setq pt2 (getpoint pt1 "\n指定下一点:"))
  9.     (entmake (list '(0 . "LINE") (cons 10 pt1) (cons 11 pt2)))
  10.     (entmake (list '(0 . "INSERT") (cons 2 "hg1") (cons 10 pt2)))
  11.     (setq pt1 pt2)
  12.   )
  13.   (princ)
  14. )
发表于 2014-10-31 00:04:05 | 显示全部楼层
顶上去,能执行完后打散块就好,求大神修改
 楼主| 发表于 2014-10-31 00:11:55 | 显示全部楼层
高实在是高
GMT+8, 2025-12-17 23:44 , Processed in 0.184288 second(s), 19 queries , Gzip On.
