楼主: lengxiaxi
[提问] 局部视图放大后 标注不变的问题
发表于 2018-7-23 17:10:48 | 显示全部楼层
maxli 发表于 2018-6-22 08:50
另外可以加矩形的么?
刚好我也用到这个,把方框选择加上,原图上的选框感觉保留比较好,比例为1时省去最后的尺寸比例处理,程序可以顺点
(DEFUN C:tt5()
(setq oldos (getvar "osmode"))
(setvar "osmode" 0)
(PRINC "\n局部放大图-【默认圆形选区/方框选区(空格)】: ")
(if
(SETQ pt (getpoint "\n请指定圆心点: "))
(command "circle" pt pause)
(command "chprop" (entlast) "" "lt" "DASHED" "s" "1" "c" "252" "")
(SETQ e  (entlast)
PC (cdr (assoc 10 (entget E)))
P  (getpoint "\n请指定视图放置点: ")
K  (getreal "\n请指定放大比例 <1>: ")
r  (cdr (assoc 40 (entget e)))
        (if (= nil k) (setq k 1))
  (command "copy" "cp")
  (setq n 0)
  (repeat 180
    (command (polar pc (/ (* 2 n pi) 180) r))
    (setq n (+ n 1))
  (command "" "" pc p)
  (setq n 0)
  (setvar "pickbox" 5)
  (command "circle" p r)
  (setq ep (entlast))
  (command "trim" ep "")
  (repeat 180
    (command "f" (polar p (/ (* 2 n pi) 180) (* r 1.01)))
    (setq n (+ n 1))
    (command (polar p (/ (* 2 n pi) 180) (* r 1.01)) "")
  (command "")
        (command "erase" ep "")
(if (/= 1 k)
  (command "scale"
    "c"
    (list (- (car p) r) (- (cadr p) r))
    (list (+ (car p) r) (+ (cadr p) r))
    p
    k
      (setq ss (ssget "p" '((0 . "dimension"))));此处过滤出标注对象
      (if ss
   (setq oldds (getvar "dimstyle"))
   (command "_dimstyle" "restore" "" (ssname ss 0))
   (setq oldfac (getvar "dimlfac"))
   (SETVAR "DIMLFAC" (/ oldfac k))
   (COMMAND "DIMSTYLE" "_APPLY" ss "")
   (command "-dimstyle" "r" oldds)))
         (PRINC "\n【方框选区】: ")
  (SETQ pt1 (getpoint "\n请指定第一点: ") pt2 (getcorner pt1 "\n请指定第二点: "))
  (command "RECTANG" pt1 pt2)
  (SETQ e  (entlast)
  (command "copy" "c" pt1 pt2 "" pt1 p)
  (command "RECTANG" p (polar p (angle pt1 pt2) (distance pt1 pt2)))
  (setq ep (entlast))
(command "OFFSET" 1 ep (list 0 0) "")
(setq en2 (entlast))
  (setq Lst (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) (entget en2)))
        s1  (nth 0 Lst)
        s2  (nth 1 Lst)
        s3  (nth 2 Lst)
        s4  (nth 3 Lst))
(command "TRIM" ep "" "f" s1 s2 s3 s4 s1 "" "")
(command "ERASE" ep en2 "")
(if (/= 1 k)
                                (command "scale" "c" s1 s3 "" p k )
      (if ss
(setvar "osmode" oldos)
发表于 2018-7-27 09:27:23 | 显示全部楼层
start4444 发表于 2018-7-23 17:10
刚好我也用到这个,把方框选择加上,原图上的选框感觉保留比较好,比例为1时省去最后的尺寸比例处理,程 ...
非常谢谢!!!!
发表于 2023-12-18 05:21:55 来自手机 | 显示全部楼层
学一下,希望好用
GMT+8, 2026-1-28 03:15 , Processed in 5.353905 second(s), 20 queries , Gzip On.
