楼主: masterlong
[源码] 刚刚随手编的一个相同文字连线的小程序
发表于 2024-8-31 13:03:53 | 显示全部楼层
非常感谢分享
发表于 2024-9-18 23:41:46 | 显示全部楼层
非常感谢分享,局部修改可以实现天正文字连线
发表于 2024-9-20 14:07:03 | 显示全部楼层
  1. (defun c:tt ()
  2.   "相同文字连线"
  3.   (defun Ep5 (e / p1 p9 p)
  4.     (vla-getboundingbox (vlax-Ename->Vla-Object e) 'p1 'p9)
  5.     (setq p(mapcar 'vlax-safearray->list (list p1 p9)))
  6.     (mapcar '(lambda (x y) (/ (+ x y) 2.0))(car p)(cadr p))
  7.   )
  8.   (defun ss2list (ss)
  9.     (vl-remove-if'(lambda (x) (/= (type x) 'ENAME))(mapcar 'cadr (ssnamex ss)))
  10.   )
  11.   (if (and (setq ss1 (ssget ":e:s" '((0 . "TEXT"))))
  12.            (setq s1 (ssname ss1 0))
  13.            (setq tx (cdr (assoc 1 (entget s1))))
  14.            (setq ss (ssget (list '(0 . "TEXT") (cons 1 tx))))
  15.       )
  16.     (progn
  17.       (command "-layer" "m" "文字连线" "c" "6" "" "")
  18.       (setq p0  (Ep5 s1)
  19.             lst (vl-remove s1 (ss2list ss))
  20.       )
  21.       (foreach x lst (command "line" "non" p0 "non" (Ep5 x) ""))
  22.       (princ "\n相同文本数量 = ")
  23.       (princ (length lst))
  24.       (alert (strcat "\n相同文本数量 = "(itoa (length lst))))
  25.     )
  26.   )
  27.   (princ)
  28. )
GMT+8, 2026-1-13 15:41 , Processed in 0.165920 second(s), 19 queries , Gzip On.
