楼主: lxdz443
[已解答] 如何将输入50*3这类乘法数据转换为50+50+50这类的加法?
发表于 2024-8-19 00:41:55 | 显示全部楼层
  1. (defun abc(_str / LM:lst->str LM:str->lst _alst  _xlst )
  2. (defun LM:lst->str ( lst del )
  3.     (if (cdr lst)
  4.         (strcat (car lst) del (LM:lst->str (cdr lst) del))
  5.         (car lst)
  6.     )
  7. )
  8. (defun LM:str->lst ( str del / pos )
  9.     (if (setq pos (vl-string-search del str))
  10.         (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del))
  11.         (list str)
  12.     )
  13. )
  14. (LM:lst->str
  15.   (apply 'append
  16.   (mapcar '(lambda(x)
  17.     (setq _alst nil)
  18.     (cond
  19.       ((wcmatch x "*`**")
  20.         (setq _xlst (LM:str->lst x "*"))
  21.         ((lambda(y z)(repeat (atoi z) (setq _alst (cons y _alst)))_alst)(car _xlst)(cadr _xlst))
  22.       )
  23.       (t (list x))
  24.     )
  25.   )(LM:str->lst _str " "))) " ")
  26. )
命令: (abc "50 100*3 200*2 100*1")
"50 100 100 100 200 200 100"
参与人数 1明经币 +1 金钱 +20 收起 理由
大角牛 + 1 + 20 很给力!
发表于 2024-8-19 09:43:05 | 显示全部楼层
感谢感谢感谢
发表于 2024-8-19 09:44:11 | 显示全部楼层
感谢,这个需要下载工具箱才能运行吧
GMT+8, 2026-1-9 18:04 , Processed in 0.169315 second(s), 20 queries , Gzip On.
