查看: 2168|回复: 3
[已解答] 急需求助,关于如何用lsp实现以下功能!!
发表于 2015-4-9 12:21:40 | 显示全部楼层 |阅读模式
有没有类似实现以下功能的lsp程序??????????
点选一根多段线或者直线,选择该线的一个端点,然后提示输入一个长度值x,确认后,从该线被选择的端点起,每隔x长度按次序提取坐标(线上,同时该线两个端点的坐标也要提取),然后将提取的坐标按次序保存到txt文件或excle文件中(随便),文件保存格式 :
序号  x坐标  y坐标
如果没有,请哪位大侠帮忙写个吧,不会lsp啊!!!
有空的请帮帮忙!!!
发表于 2015-4-9 14:37:56 | 显示全部楼层
  1. (defun c:tt (/ EN D PT L1 L FN F D0 I)
  2.   (if (and
  3.         (setq en (entsel "\n选择曲线:"))
  4.         (setq d (getdist "\n输入间距:"))
  5.       )
  6.     (progn
  7.       (setq pt (cadr en)
  8.             en (car en)
  9.             pt (vlax-curve-getclosestpointto en pt)
  10.             l1 (vlax-curve-getDistAtPoint en pt)
  11.             l (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en))
  12.             )
  13.       (setq fn (VL-FILENAME-MKTEMP "" "" ".txt"))
  14.       (setq f (open fn "w"))
  15.       (if (< l1 (* 0.5 l))
  16.         (progn
  17.           (setq d0 0 i 1)
  18.           (while (< d0 l)
  19.             (setq pt (vlax-curve-getPointAtDist en d0))
  20.             (write-line (strcat (itoa i) " " (rtos (car pt) 2 3) " " (rtos (cadr pt) 2 3)) f)
  21.             (setq i (1+ i)
  22.                   d0 (+ d0 d)
  23.                   )
  24.             )
  25.           (setq pt (vlax-curve-getEndPoint en))
  26.           (write-line (strcat (itoa i) " " (rtos (car pt) 2 3) " " (rtos (cadr pt) 2 3)) f)
  27.           (close f)
  28.           )
  29.         (progn
  30.           (setq d0 l i 1)
  31.           (while (> d0 0)
  32.             (setq pt (vlax-curve-getPointAtDist en d0))
  33.             (write-line (strcat (itoa i) " " (rtos (car pt) 2 3) " " (rtos (cadr pt) 2 3)) f)
  34.             (setq i (1+ i)
  35.                   d0 (- d0 d)
  36.                   )
  37.             )
  38.           (setq pt (vlax-curve-getStartPoint en))
  39.           (write-line (strcat (itoa i) " " (rtos (car pt) 2 3) " " (rtos (cadr pt) 2 3)) f)
  40.           (close f)
  41.           )
  42.         )
  43.       (startapp "notepad.exe" fn)
  44.     )
  45.   )
  46.   (princ)
  47. )
发表于 2015-4-10 02:45:06 | 显示全部楼层
Gu_xl 发表于 2015-4-9 14:37
G版出手难题迎刃而解!
 楼主| 发表于 2015-4-11 20:57:00 | 显示全部楼层
谢谢,g版啊
GMT+8, 2026-1-25 00:08 , Processed in 0.381971 second(s), 26 queries , Gzip On.
