楼主: 呆呆
[求助][LISP]紧急求救
发表于 2003-11-25 17:05:00 | 显示全部楼层
帖一个吧摘自xdcad.com
给朵花吧
发表于 2003-11-25 17:22:00 | 显示全部楼层
(defun C:GetArea ( / AcadObj AcadEnt pt msg)
(setq AcadEnt (car (entsel)))
(setq AcadObj (vlax-ename->vla-object AcadEnt))
(setq msg "")
(if (member (vla-get-objectname acadobj)
'("AcDbCircle" "AcDbCircle" "AcDbEllipse" "AcDbSpline"
"AcDbPolyline" "AcDb3dPolyline" "AcDb2dPolyline" "AcDbRegion" "AcDb3dSolid"))
(command "_.area" "object" acadent)
(setq msg (strcat msg "面积是:"
(rtos (/ (getvar "area") 1000000))
"平方米\n"
(setq msg (strcat msg "周长是:"
(rtos (/ (getvar "erimeter") 1000))
"米\n"
(setq msg "没有面积或周长信息。\n")
(setq msg (strcat "物体:" (vla-get-objectname acadobj) "\n\n" msg))
(princ msg)
(alert msg)
发表于 2004-4-14 23:30:00 | 显示全部楼层
哈哈,该我上场了吧?!
哦,mm上来了。那。。。下次吧 :(
楼上搞错了吧?人家是要求hatch的面积,龙龙仔说的得边界后如何求,不是说如何求曲线面积,而是说如何判断哪些面积该加,哪些该减。哪些要求交。。。
发表于 2004-4-21 23:17:00 | 显示全部楼层
能不能用填充时判断孤岛的办法来决定哪该加,哪该减。
GMT+8, 2025-12-17 19:37 , Processed in 0.167320 second(s), 20 queries , Gzip On.
