查看: 2642|回复: 2
lisp小程序的问题,请各位帮忙
发表于 2002-7-30 11:08:00 | 显示全部楼层 |阅读模式
我写了一个程式如下:
(defun text_change (name number name_new)
  (setq name_old (sslength name))
  (while (> name_old 0)
    (setq temp (ssname name (setq name_old (1- name_old))))
    (entmod (subst (cons number name_new)
                   (assoc nember (setq int (entget temp)))
                   int
可我先在命令行里输(setq se (ssget))
然后选择文字
接着再输(text_change se 40 8)
这个程式不知道存在什么问题我一直找不出来,请各位指点一下.谢谢.
发表于 2002-7-30 12:40:00 | 显示全部楼层
把錯字 nember → number ;;;usage: (text_change (ssget) 40 8)
(defun TEXT_CHANGE (NAME NUMBER NAME_NEW)
  (setq NAME_OLD (sslength NAME))
  (while (> NAME_OLD 0)
    (setq TEMP (ssname NAME (setq NAME_OLD (1- NAME_OLD))))
    (entmod (subst (cons NUMBER NAME_NEW)
                   (assoc NUMBER (setq INT (entget TEMP)));;錯字 nember
                   INT
 楼主| 发表于 2002-7-30 13:50:00 | 显示全部楼层
我真粗心,谢了
GMT+8, 2026-1-21 04:31 , Processed in 0.133005 second(s), 25 queries , Gzip On.
