楼主: mmmjjj
[求助]请看看这个程序什么问题
 楼主| 发表于 2004-2-8 13:37:00 | 显示全部楼层
kaixin119发表于2004-2-8 13:17:00把对象捕捉关了试试!,我用了用没发现0的线啊
请看第5楼要求
发表于 2004-2-8 21:01:00 | 显示全部楼层
  1. (defun c:lin (/ ms ang pt0 pt1)
  2.    (vl-load-com)
  3.    (setq ms (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
  4.   pt0 (getpoint "\n起点:"))
  5.    (while (setq ang (getangle pt0 "\n下一点:"))
  6.        (setq pt1 (polar pt0 ang 1000))
  7.        (vla-addline ms (vlax-3d-point pt0)(vlax-3d-point pt1))
  8.        (setq pt0 pt1)
  9.    )
  10. )
发表于 2004-2-8 21:57:00 | 显示全部楼层
看这样行不... (defun C:sss (/ d1 d2 ang cd n)
(setq d1 (getpoint "\n点取点:"))
(setq d2 (getpoint "\n点取下一点:"))
(while d2
(setq cd (distance d1 d2))
(setq ang (angle d1 d2))
(if (> cd 10.0)
(setq d2 (polar d1 ang 10.0))
(setq os(getvar "osmode"))
(command "osnap" "off")
(command "line" d1 d2 "")
(setvar "osmode" os)
(setq d1 d2)
 楼主| 发表于 2004-2-11 16:45:00 | 显示全部楼层
谢谢楼上二位,两位的程序都已解决0长度线问题,多谢!多谢!
GMT+8, 2025-12-16 23:07 , Processed in 0.170375 second(s), 19 queries , Gzip On.
