查看: 2385|回复: 8
如何能用一条线裁剪裁减尺寸界限(不炸开)
发表于 2004-2-15 01:20:00 | 显示全部楼层 |阅读模式
发表于 2004-2-15 09:07:00 | 显示全部楼层
不可以,如果你是为了不与字重叠,可以使用WIPEOUT
 楼主| 发表于 2004-2-15 22:29:00 | 显示全部楼层
多谢
发表于 2004-2-15 23:35:00 | 显示全部楼层
尺寸界限?
是尺寸两边的线么?如果是那个可以改
 楼主| 发表于 2004-2-16 00:12:00 | 显示全部楼层
是呀
发表于 2004-3-8 14:28:00 | 显示全部楼层
你用stretch命令也行啊,试下看合你意不
发表于 2004-3-8 15:54:00 | 显示全部楼层
直接裁减也行啊.
发表于 2004-3-8 19:16:00 | 显示全部楼层
(prompt
"\nDBREAK - dimension line break utility. (C)1997 W.Kramer"
(prompt "\n Downloaded from www.cadgineering.com")
;;NOTE:
;; This program originally appeared in CADENCE magazine however,
;; the version displayed in the magazine and available for download
;; has a problem. This version corrects the problem that was
;; discovered.
;; Programmer's Toolbox - February 1997
;; W.Kramer
;; Dimension line break utility
;; Break whitness and dimension lines in R13
;; dimension objects with out exploding the
;; object. Demonstrates how dimension objects
;; are stored and manipulated as well as
;; dynamic scoping of variables.
;; Listing 1: Main Entry Point
;; Function (C:DBREAK)
(defun C:DBREAK (/
;;Local Bound Variables
EN
;;operator selection
P1
;;break point 1
P2
;;break point 2
ENL ENB ELB NMB ELT ENT
;;see listing 3
;;Operator select input object
;;and break point. -see listing 2
(if (DBREAK0)
(DBREAK1)
;;See listing 3
(if (null
(entmake (list
'(0 . "BLOCK")
(assoc 2 ELT)
(assoc 10 ELT)
'(70 . 1)
(prompt "\nRedefine failed!")
(exit)
;;force exit of routine
;;end IF PROGN
;;Loop through block def seeking
;;LINE object to change.
(while ENT
;;Get the entity list data
(setq ELT (entget ENT))
;;Does entity match the one
;;we want to change?
(if (not (eq ENL ENT))
;;NOT a match,
;;reconstruct block def.
(entmake ELT)
;;else, Found a match,
;; do break & reconstruction.
(DBREAK2)
;;see listing 4
;;end IF
;;get next entity in block def.
(setq ENT (entnext ENT))
;;end WHILE
(if (entmake '((0 . "ENDBLK")))
(prompt "\nBlock modified")
(prompt "\nBLOCK END failure!")
;;end IF
(entupd ENB)
;;end PROGN
(prompt "\nInvalid input")
;;end IF dbreak0
;; Listing 2 - Function DBREAK0
;; Function: DBREAK0 - user input section
(defun DBREAK0 (/
EL
;;entity list of selected object
;;Global Variables
;; EN entity name of selected object
;; P1,P2 points selected
(setq EN
(nentsel
"\nSelect dimension line to break: "
(if EN
;;get the object details
(setq EL (entget (car EN))
P1 (cadr EN)
;;first check to see if object selected
;;was a LINE which was part of an insert.
(if (and (= (cdr (assoc 0 EL)) "LINE")
(> (length EN) 2)
;;now ask operator to supply the
;;other side of the break.
(if (= (assoc 62 EL) nil)
(setq linecolor (cdr(assoc 62 (tblsearch "layer" (cdr(assoc 8(entget(car(last en)))))))))
(setq LINECOLOR (cdr (assoc 62 EL)))
(setq P2
(getpoint
(cadr EN)
"\nOther side of break: "
(prompt "\nLine was not selected!")
;;end IF
;;Snap selected points to the nearest object
(if (and P1 P2)
(setq P1 (osnap (cadr EN) "NEA")
P2 (osnap P2 "NEA")
;;return True if both input points are okay
(if (and P1 P2)
't
NIL
;; Listing 3 - Function DBREAK1
;; FUNCTION: DBREAK1 - Set up global variables.
(defun DBREAK1 ()
;;Global Variables
;;ENL entity list of line selected
;;ENB entity name of block/dimension
;;ELB entity list of block/dimension
;;NMB name of the block/dimension in table
;;ELT entity list of table entry
;;ENT entity name of block object
(setq
ENL (car EN)
ENB (car (last EN))
ELB (entget ENB)
NMB (cdr (assoc 2 ELB))
ELT (tblsearch "BLOCK" NMB)
ENT (cdr (assoc -2 ELT))
;; Listing 4 - Function DBREAK2
;; Function DBREAK2: convert line object into
;; two line objects at break points.
(defun DBREAK2 (/
;;Local Variables
LYR
;;layer name of dim/blk line
PP1
;;start point of dim/blk line
PP2
;;end point of dim/blk line
PA
;;break point 1
PB
;;break point 2
;;Global Variables
;; P1,P2 - operator break points
;; ELT - entity list of dim/blk line
;;get the line details
(setq PP1 (cdr (assoc 10 ELT))
PP2 (cdr (assoc 11 ELT))
LYR (cdr (assoc 8 ELT))
;; Determine end points of
;;new line segments.
(if (< (distance PP1 P1)
(distance PP1 P2)
(setq PA P1
PB P2
(setq PA P2
PB P1
;;Build new lines to replace
;;the broken line.
(LINE PP1 PA LYR 1)
(LINE PB PP2 LYR 1)
(setq LINECOLOR NIL)
;; Listing 5 - Function LINE
;; Function: LINE - create line object
(defun LINE (P1 P2 LYR BLKFLG)
(entmake (list
'(0 . "LINE")
(cons 6
(if BLKFLG
"BYBLOCK"
"BYLAYER"
(if LYR
(cons 8 LYR)
(getvar "CLAYER")
(cons 10 P1)
(cons 11 P2)
(cons 62 LINECOLOR)
;(if BlkFlg 0 256))))
;;----------------------------------------------- END OF FILE
 楼主| 发表于 2004-3-13 17:02:00 | 显示全部楼层
谢谢斑竹的留言,在这里觉得要学的真是很多
GMT+8, 2025-12-10 09:01 , Processed in 0.181781 second(s), 26 queries , Gzip On.
