查看: 2633|回复: 3
怎样做一个带参数的螺纹孔图形的程序
发表于 2004-2-24 19:22:00 | 显示全部楼层 |阅读模式
请教各位高手,怎样做一个带参数的螺纹孔程序,我是机械设计的,螺纹孔在机械图中用的很多,形状都相同,但大小不一样,我想编一个程序,只要输入参数就可以画出来,能教教我吗?
发表于 2004-2-24 21:00:00 | 显示全部楼层
先建立一个Center层,然后运行命令:lw
发表于 2004-2-24 21:01:00 | 显示全部楼层
程序:
  1. (defun err(msg)
  2.    (princ msg)
  3.    (command "_.undo" "e")
  4.    (command "u")
  5.    (setq *error* errtmp)
  6.    (setvar "osmode" os)
  7.    (princ "请建立Center层!")
  8.    (princ)
  9. )(defun GetVal(fun msg key flag vla_tmp / val)
  10.    (if (not (eval vla_tmp))
  11.        (progn
  12.            (initget key (if flag flag ""))
  13.            (setq val (fun (strcat msg ":")))
  14.        )
  15.        (progn
  16.            (initget key (if flag (1- flag) ""))
  17.            (setq val (fun (strcat msg "<" (rtos (eval vla_tmp)) ">:")))
  18.            (if (not val) (setq val (eval vla_tmp)))
  19.        )
  20.    )
  21.    (set vla_tmp val)
  22. )(defun c:lw( / d d2 pt lay)
  23.    (setvar "cmdecho" 0)
  24.    (command "_.undo" "be")
  25.    (setq errtmp *error*)
  26.    (setq *error* err)
  27.    (setq ty_tmp d_tmp)
  28.    (setq d (getval getreal "外螺纹,输入直径或[内螺纹(I)]" "I" 7 'ty_tmp))
  29.    (if (= d "I")
  30.        (progn
  31.            (setq d (getval getreal "内螺纹,输入直径" "" 7 'd_tmp))
  32.            (setq d2 (/ d 1.1))
  33.        )
  34.        (setq d2 (* d 1.1))
  35.    )
  36.    (initget 1)
  37.    (setq pt (getpoint "输入中心:"))
  38.    (setq os (getvar "osmode"))
  39.    (setvar "osmode" 0)
  40.    (command "_.circle" pt (/ d 2.0))
  41.    (command "_.arc" "c" pt (polar pt (/ pi 18.0) (/ d2 2.0)) (polar pt (+ (/ (* pi 3.0) 2.0) (/ pi 18.0)) (/ d2 2.0)))
  42.    (setq lay (getvar "clayer"))
  43.    (command "_.clayer" "Center")
  44.    (command "_.line" (polar pt (/ pi 2.0) (* 5.0 (/ d 7.0))) (polar pt (/ (* pi 3.0) 2.0) (* 5.0 (/ d 7.0))) "")
  45.    (command "_.line" (polar pt 0 (* 5.0 (/ d 7.0))) (polar pt pi (* 5.0 (/ d 7.0))) "")
  46.    (command "_.clayer" lay)
  47.    (command "_.undo" "e")
  48.    (setq *error* errtmp)
  49.    (setvar "osmode" os)
  50.    (princ)
  51. )
 楼主| 发表于 2004-2-24 21:35:00 | 显示全部楼层
谢谢你了
很感谢你,我还有很多很多问题要请教你,谢谢
GMT+8, 2025-12-31 07:02 , Processed in 0.178648 second(s), 25 queries , Gzip On.
