楼主: azbk00
[已解答] 怎么获取炸开后的所有对象
发表于 2023-5-23 13:42:17 | 显示全部楼层
使用上一次选择集,我很喜欢用(ssget "c" p1 p2),在版主大大的代码上做了修改,供你参考。
(defun c:11();改成洋红色块
(setvar "cmdecho" 0)
(command "undo" "be")
(if (null (tblsearch "LAYER" "LClayer"))
(entmake (list
        '(0 . "LAYER")
        '(100 . "AcDbSymbolTableRecord")
        '(100 . "AcDbLayerTableRecord")
         (cons 2 "LClayer")       ;图层名称
        '(70 . 0)                 ;图层状态
        '(62 . 6)                 ;图层颜色
        '(6 . "bylayer")          ;图层线型
(setq p1 (getpoint "框选第一点"))
(setq p2 (getcorner p1 "\n框选对角点"))
(setvar "QAFLAGS" 1)
(command "explode" (ssget "c" p1 p2 ) "")
(setvar "QAFLAGS" 0)
(command "change" (ssget "c" p1 p2 ) "" "p" "c" "6" "")
(command "change" (ssget "c" p1 p2 ) "" "p" "la" "LClayer" "")
(ZG_MakeBlock (ssget "c" p1 p2 ))
(command "undo" "e")
(setvar "cmdecho" 1)
发表于 2023-5-24 07:49:37 | 显示全部楼层
感謝!!學到東西了
GMT+8, 2026-1-15 11:37 , Processed in 0.231756 second(s), 19 queries , Gzip On.
