楼主: jack093
[讨论] 恢复被打碎的块
发表于 2015-12-22 13:36:11 | 显示全部楼层
楼主,还缺函数呀
发表于 2015-12-22 15:06:53 | 显示全部楼层
支持楼主,好东西
发表于 2015-12-24 08:00:07 | 显示全部楼层
支持楼主
发表于 2015-12-24 11:34:30 | 显示全部楼层
这个真是很有意义哦!有能力的支持支持!
 楼主| 发表于 2015-12-24 16:58:48 | 显示全部楼层
找到2个bug
1.比较角度前
                            (if (> aann (* 2.0 pi))
                                (setq aann (- aann (* 2.0 pi)))
                            (if (< aann (* -1.0 pi))
                                (setq aann (+ aann (* 2.0 pi)))
否则旋转对象无法匹配
2.变量an因为ang
(defun points_2_mrs(p1 p2 p1a ang sc /  an sc x1 y1 x1a y1a x3 y3 x1s y1s ang13 d1s3 x3s y3s)
    (setq x1 (car p1)y1 (cadr p1))
    (setq x1a (car p1a)y1a (cadr p1a))
    (setq x2 (car p2)y2 (cadr p2))
    ;;scale p2不动
    (setq x1s (+ (* sc x1) (* (- 1 sc) x2)))
    (setq y1s (+ (* sc y1) (* (- 1 sc) y2)))
    ;;rotate p1不动 后 p2坐标
    (setq ang12 (angle p1 p2))
    (setq d1s2 (sqrt(+ (*(- x1s x2)(- x1s x2))(*(- y1s y2)(- y1s y2)))))
    (setq x2s (+ (* (cos (+ ang ang12)) d1s2)x1s))
    (setq y2s (+ (* (sin (+ ang ang12)) d1s2)y1s))
    ;;move p1移到p1a 后 p2坐标
    (list (+ x2s (- x1a x1s))(+ y2s (- y1a y1s))0)
已经可以对固定比例,旋转变比的匹配了(xyz不同比例不能匹配)
还剩下其它图元支持了
 楼主| 发表于 2016-1-6 15:26:41 | 显示全部楼层
支持图元增加
(defun find_eq_ent(ent ent2 pt p3 ang sc /  flag ret nm p1 p2 p1a p2a aann sscc ptt r1 r2 a1 a2)
    (setq flag nil ret nil)
    (setq nm (cdr (assoc 0 ent)))
    (setq p1 (cdr (assoc 10 ent)) p2 (cdr (assoc 10 ent2)))
    (if (and
            (= nm(cdr (assoc 0 ent2)))
            (= (cdr (assoc 8 ent))(cdr (assoc 8 ent2)))
            (= (cdr (assoc 62 ent))(cdr (assoc 62 ent2)))
            (= (cdr (assoc 6 ent))(cdr (assoc 6 ent2)))
            (= (cdr (assoc 48 ent))(cdr (assoc 48 ent2)))
        (cond
            ((= nm "LINE")
                (setq p1a (cdr (assoc 11 ent)) p2a (cdr (assoc 11 ent2)))
                (setq sscc (/ (distance p2 p2a)(distance p1 p1a)))
                (if (null sc)
                    (setq sc sscc)
                    (if (null(equal sc sscc 1e-7))
                        (setq flag t)
                (if (null flag)
                        (setq aann (- (angle p2 p2a)(angle p1 p1a)))
                        (if (null ang)
                            (setq ang aann)
                            (if (null(eq_angle_pi ang aann))
                                (setq flag t)
                (if (null flag)
                        ;;(setq ptt (triangle_2_mrs p1 p1a pt p2 p2a))
                        (setq ptt (points_2_mrs (midpoint p1 p1a) pt (midpoint p2 p2a) ang sc))
                        (if (null p3)
                            (setq p3 ptt)
                            (if (null(equal p3 ptt 1e-7))
                                (setq flag t)
                        (if (null flag)
                            (setq ret (list p3 ang sc))
            ((or(= nm "TEXT")(= nm "MTEXT"))
                (if (and(= (cdr (assoc 1 ent))(cdr (assoc 1 ent2)))
                        (= (cdr (assoc 7 ent))(cdr (assoc 7 ent2)))
                        (= (cdr (assoc 71 ent))(cdr (assoc 71 ent2)))
                        (= (cdr (assoc 72 ent))(cdr (assoc 72 ent2)))
                        (setq a1 (cdr (assoc 50 ent))a2(cdr (assoc 50 ent2)))
                        (setq aann (- a2 a1))
                        (if (null ang)
                            (setq ang aann)
                            (if (null(eq_angle ang aann))
                                (setq flag t)
                                    (setq sscc (/ (cdr (assoc 40 ent2))(cdr (assoc 40 ent))))
                                    (if (null sc)
                                        (setq sc sscc)
                                            (setq flag t)
                                                (setq ptt (points_2_mrs p1 pt p2 ang sc))
                                                (if (null p3)
                                                    (setq p3 ptt)
                                                        (setq flag t)
                                                (if (null flag)
            ((= nm "CIRCLE")
                    (setq flag t)
                            (setq flag t)
            ((= nm "DIMENSION")
                (if (null sc)
                    (setq sc sscc)
                        (setq flag t)
                (if (null flag)
                        (if (null ang)
                            (setq ang aann)
                                (setq flag t)
                (if (null flag)
                        (if (null p3)
                            (setq p3 ptt)
                        (if (null(and
                                    (equal p3 ptt 1e-7)
                                    (equal p3 (points_2_mrs p1a pt p2a ang sc) 1e-7)
                            (setq flag t)
            ((or (= nm "LWPOLYLINE")(= nm "POLYLINE"))
                (setq p1s(GETPTS ent)p2s(GETPTS ent2))
                (setq len (length p1s))
                (if (= len (length p2s))
                        (while (> len 0)
                            (setq len (1- len))
                            (if (null(equal p3 (points_2_mrs (nth len p1s) pt (nth len p2s) ang sc) 1e-7))
                                (setq flag t len 0)
                        (if (null flag)
            ((= nm "ARC")
                (if (equal (- (cdr (assoc 50 ent))(cdr (assoc 51 ent)))(- (cdr (assoc 50 ent2))(cdr (assoc 51 ent2))) 1e-7)
                        (setq r1 (cdr (assoc 40 ent)) r2 (cdr (assoc 40 ent2)))
                        (setq aann (- (cdr (assoc 50 ent2))(cdr (assoc 50 ent))))
                        (if (null ang)
                            (setq ang aann)
                                (setq flag t)
                        (if (null flag)
                                (if (null sc)
                                    (setq sc sscc)
                                        (setq flag t)
                        (if (null flag)
                                (setq p1a (list (+(car p1) (* r1 (cos a1))) (+(cadr p1) (* r1 (sin a1)))))
                                (setq p2a (list (+(car p2) (* r2 (cos a2))) (+(cadr p2) (* r2 (sin a2)))))
                                (if (null p3)
                                    (setq p3 ptt)
                                    (if (or(null(equal p3 ptt 1e-7))(null(equal (- a2 a1)ang 1e-7)))
                                        (setq flag t)
                                (if (null flag)
            (if (= nm "INSERT")
                (if (and(= (cdr (assoc 2 ent))(cdr (assoc 2 ent2)))
                        (equal (/ (cdr (assoc 42 ent))(cdr (assoc 41 ent)))(/ (cdr (assoc 42 ent2))(cdr (assoc 41 ent2)))  1e-7))
                        (setq sscc (/ (cdr (assoc 41 ent2))(cdr (assoc 41 ent))))
                        (if (null sc)
                            (setq sc sscc)
                                (setq flag t)
                        (if (null ang)
                            (setq ang aann)
                                (setq flag t)
                        (if (null p3)
                            (setq p3 ptt)
                                (setq flag t)
                        (if (null flag)
            (t
                (if(and
                        (equal p3 (points_2_mrs p1 pt p2 ang sc) 1e-7)
                        (eq_dxf ent ent2))
    ret
);;其它图元有待增加完善
jltx123456 + 1 赞一个!
发表于 2016-1-6 16:58:22 | 显示全部楼层
jack093 发表于 2016-1-6 15:26
支持图元增加
(defun find_eq_ent(ent ent2 pt p3 ang sc /  flag ret nm p1 p2 p1a p2a aann sscc ptt  ...
楼主,很好的主题, 但是看到每层都放一点代码,这样会不易阅读 ,建议整理成一个完整的贴出来,或者直接上传lisp附件!
发表于 2019-4-18 10:37:03 | 显示全部楼层
想不到还可以,破镜重圆,点赞
发表于 2020-9-27 02:38:05 | 显示全部楼层
老师:加载一楼的插件,使用时提示no function definition: SS_ADD-DEL,怎么解决?
发表于 2020-9-27 08:25:12 | 显示全部楼层
关注,以备日后学习
GMT+8, 2026-1-17 06:50 , Processed in 0.268454 second(s), 30 queries , Gzip On.
