查看: 2220|回复: 12
[源码] 错误: 参数类型错误: numberp: nil
发表于 2016-6-29 17:23:00 | 显示全部楼层 |阅读模式
(DEFUN C:XGF()
(SETQ A (SSGET))
(SETQ N (SSLENGTH A))
(SETQ UNIPRS (getreal "价格:"))
(SETQ THICK (getreal "厚度:"))
(SETQ MINPRS1 (GETREAL "每孔的最低价格:<80>"))
(IF (= MINPRS1 nil) (SETQ MINPRS 80) (SETQ MINPRS MINPRS1))
(SETQ INDEX 0)
(SETQ TL 0)
(SETQ HOLENO 0)
(SETQ TLPRS 0)
(REPEAT N
   (SETQ B (ENTGET (SSNAME A INDEX)))
   (SETQ INDEX (1+ INDEX))
   (SETQ B1 (ASSOC 0 B))
   (IF (= "LINE" (CDR B1))
       (PROGN
         (SETQ SP (ASSOC 10 B))
         (SETQ SPC (CDR SP))
         (SETQ EP (ASSOC 11 B))
         (SETQ EPC (CDR EP))
         (SETQ LD (DISTANCE SPC EPC))
         (SETQ UTPRS (* UNIPRS (* LD THICK)))
   (IF (= "CIRCLE" (CDR B1))
       (PROGN
         (SETQ RA (ASSOC 40 B))
         (SETQ RAL (CDR RA))
         (SETQ LD (* 2 (* Pi RAL)))
         (SETQ UTPRS1 (* UNIPRS (* LD THICK)))
         (SETQ UTPRS UTPRS1)
         (IF (< UTPRS1 MINPRS)
             (PROGN
               (SETQ UTPRS 0)
               (SETQ LD 0)
               (SETQ HOLENO (+ 1  HOLENO))
   (IF (= "ARC" (CDR B1))
       (PROGN
         (SETQ RAL (CDR RA))
         (SETQ AS (ASSOC 50 B))
         (SETQ ASV (CDR AS))
         (SETQ AE (ASSOC 51 B))
         (SETQ AEV (CDR AE))
         (IF (< AEV ASV) (SETQ ASV (- ASV (* 2 Pi))))
         (SETQ LD (* RAL (ABS (- AEV ASV))))
    (SETQ TL (+ TL LD))
    (SETQ TLPRS (+ TLPRS UTPRS))
    (SETQ THPRS (* MINPRS HOLENO))
    (SETQ TPRS (+ TLPRS THPRS))
(TEXTSCR)(TERPRI)
(PROMPT "******************************************************************")(TERPRI)
(princ "$")(PRINC MINPRS)(PRINC " * ")(PRINC HOLENO)(PRINC "    +    ")(princ "$")(PRINC UNIPRS)
(PRINC " * ")(PRINC THICK)(PRINC " * ")(PRINC TL)(PRINC "   = ")(princ "$")(PRINC TPRS)(TERPRI)
各位大哥,请问这个程序错在哪里?
发表于 2016-6-30 00:43:24 | 显示全部楼层
此程序只支持圆、圆弧、直线,不支持多段线!
 楼主| 发表于 2016-6-30 12:53:06 | 显示全部楼层
你好,如果让程序支持直线和由直线和圆弧串接的多义线的话,是不是要做很大改动?
 楼主| 发表于 2016-6-30 13:24:03 | 显示全部楼层
你好,能不能帮请你在程序上加几句代码,把计算结果用TEXT文本写出来
发表于 2016-6-30 20:46:27 | 显示全部楼层
改动了一下.
 楼主| 发表于 2016-6-30 21:28:01 | 显示全部楼层
waterchen 发表于 2016-6-30 20:46
改动了一下.
多谢waterchen ,程序很好用,也精简了不少
能不能请你加几句代码,把计算结果用TEXT文本写出来,有点贪心,,,惭愧
曾尝试比对了多个有写TEXT文本的程序,想拆借其中的语句拼接起来,都没成功
发表于 2016-7-1 10:37:53 | 显示全部楼层
能不能请你加几句代码,把计算结果用TEXT文本写出来,有点贪 ...
已增加写至txt文件,路径可以在lisp改你想要的。
 楼主| 发表于 2016-7-1 14:03:49 | 显示全部楼层
谢谢你,辛苦了
 楼主| 发表于 2016-7-1 21:45:24 | 显示全部楼层
你好,程序最后写写txt文件没成功。我曾想先根据你的蓝本自己折腾一下,,,折腾一下也没摸到边,无奈,想再次麻烦你一回,好吗,
 楼主| 发表于 2016-7-1 22:21:35 | 显示全部楼层
发错,,,,
GMT+8, 2026-1-21 04:33 , Processed in 0.162159 second(s), 28 queries , Gzip On.
