楼主: congcong
用LISP怎么样获取硬盘的物理序列号?或是网卡的MAC地址?
发表于 2005-11-18 16:14:00 | 显示全部楼层
好象网上有小程序下载可以任意更改网卡的MAC地址?!
(command "_.Shell" "ipconfig /all >c:\\result.txt") 会有DOS窗体出现!——怎么隐藏掉它?
发表于 2021-7-24 00:08:06 | 显示全部楼层
每个人的系统不一样,不一定是你说的这个macaddress单词
发表于 2025-5-14 10:15:49 | 显示全部楼层
;获取网卡号
;;Test OK with XP
;;Use WMI to Get Networkadapter MAC.
;;Author : eachy [eachy@xdcad.net]
;;Web : http://www.xdcad.net
;;2005.11.22
(defun xdl-MACAddress (/ mac WMIobj serv lox sn)
  (vl-load-com)
  (setq mac '())
  (if (SETQ WMIobj (VLAX-CREATE-OBJECT "wbemScripting.SwbemLocator"))
    (progn (SETQ serv (VLAX-INVOKE WMIobj 'ConnectServer "." "\\root\\cimv2" "" "" "" "" 128 nil))
           (setq lox (vlax-invoke serv 'ExecQuery "Select * From Win32_NetworkAdapter "))
           (vlax-for item lox
             (if (and (= (vlax-get item 'NetConnectionID) "本地连接") ;中文系统
                      (not (member (setq sn (vlax-get item 'MACAddress)) mac))
               (setq mac (cons sn mac))
           (mapcar 'vlax-release-object (list lox serv WMIobj))
  (reverse mac)
GMT+8, 2026-1-11 00:47 , Processed in 0.154081 second(s), 18 queries , Gzip On.
