楼主: iszc
[提问] 求快速修改所有图元颜色的源码
发表于 2020-4-2 09:26:10 | 显示全部楼层
(defun c:resetcolor (/ c)
  (setq cmd (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq Document (vla-get-ActiveDocument (vlax-get-acad-object)))
  (setq Blocks (vla-get-blocks Document))
  (vla-StartUndoMark Document)
  (setq c  8 )
  (If (progn
          (princ "\n请选择要更改颜色的图元:")
          (setq ssa (ssget))
      (vlax-for Obj (vla-get-ActiveSelectionSet Document)
         (vl-catch-all-apply 'vla-put-color (list Obj c))
         (if (= "AcDbBlockReference" (vla-get-objectname Obj))
                 (vlax-for BlkObj (vla-item Blocks (vla-get-name Obj))
                       (vl-catch-all-apply 'vla-put-color (list BlkObj c))
                 (if (= :vlax-true (vla-get-hasattributes Obj))
                     (foreach AttObj (vlax-safearray->list
                                           (vlax-variant-value (vla-getattributes Obj))
                         (vl-catch-all-apply 'vla-put-color (list AttObj c))
  (vla-EndUndoMark Document)
  (vlax-release-object Blocks)
  (vlax-release-object Document)
  (setvar "cmdecho" cmd)
发表于 2020-4-2 09:55:32 | 显示全部楼层
vectra 发表于 2017-9-25 09:03
增加了对属性的支持
不需要选择颜色时可将(setq c (acad_colordlg 8))这行修改为(setq c 8)
能否加入可以选择图元
发表于 2020-4-13 20:38:25 | 显示全部楼层
非常感谢
发表于 2020-4-16 11:24:42 | 显示全部楼层
非常好用
GMT+8, 2026-1-18 12:49 , Processed in 0.152297 second(s), 17 queries , Gzip On.
