楼主: 革天明
[提问] 求助数学问题,如何判断三维点在另外三个三维点构成的平面上的投影点,是否在三角形内
发表于 2017-10-23 09:58:28 | 显示全部楼层
  1. (setq A '(0 0 0)
  2.       B '(10 0 -7)
  3.       C '(5 10 15)
  4.       P '(5 5 3)
  5.       )
  6. (command "ucs" "")
  7. (command "ucs" a b c)
  8. (setq a1 (trans a 0 1))
  9. (setq b1 (trans b 0 1))
  10. (setq c1 (trans c 0 1))
  11. (setq p1 (trans p 0 1))
  12. (setq a1 (list (car a1) (cadr a1))
  13.       b1 (list (car b1) (cadr b1))
  14.       c1 (list (car c1) (cadr c1))
  15.       p1 (list (car p1) (cadr p1))
  16.       )
  17. (command "ucs" "")
  18. (command "pline" a1 b1 c1 "c")
  19. (setq plent (vlax-ename->vla-object (entlast)))
  20. (setq e0 (vla-get-Area plent))
  21. (vlax-put plent 'Coordinates (append a1 b1 p1))
  22. (setq e1 (vla-get-Area plent))
  23. (vlax-put plent 'Coordinates (append c1 b1 p1))
  24. (setq e2 (vla-get-Area plent))
  25. (vlax-put plent 'Coordinates (append a1 c1 p1))
  26. (setq e3 (vla-get-Area plent))
  27. (vla-delete plent)
  28. (command "ucs" "p")
  29. (command "ucs" "p")
  30. (command "ucs" "p")
  31. (>= e0 (+ e1 e2 e3))
发表于 2022-7-30 21:38:54 | 显示全部楼层
假设AC是三角形ABC的最长边,求P点在直线AC上的垂足P’,如果P'在直线AC外面则P点投影在三角形外;
否则再计算角PP'B,若角PP'B大于90度,则P点投影在三角形ABC外。
 楼主| 发表于 2022-7-31 18:13:18 | 显示全部楼层
先求出点在面上的投影点,剩下的就是判断是否在三角形内了
发表于 2022-8-1 15:00:24 | 显示全部楼层
距离关系应该能判断吧?
发表于 2022-8-3 08:22:40 来自手机 | 显示全部楼层
直接用向量法,求总面积= 3个三角形面积和,如果一个面积为0就是点落在某边上
GMT+8, 2026-1-16 07:44 , Processed in 1.937110 second(s), 20 queries , Gzip On.
