楼主: alexmai
[源码] 天花石膏线偏移工具
发表于 2017-11-7 09:58:54 | 显示全部楼层
非常好的资料,谢谢分享啊。
发表于 2017-11-8 06:52:37 | 显示全部楼层
好插件,谢谢分享~~
发表于 2017-11-9 09:22:59 | 显示全部楼层
以前有一个网友写的,效果差不多的,亦可以实现,
可以参考一下
(defun c:TQ (/ char-02 char-1 ent i lay lays list1 list2 long lst name name1 pt pt1 s snap ss uuu x y)
  (vl-load-com)
  (defun zz01 (ent / lst x)
    (foreach x ent
      (if (= (car x) 10)
(setq lst (cons (cdr x) lst))
    lst
  (setvar "CMDECHO" 0)
  (command "_.purge" "B" "" "n")
  (if (null jbak)
    (setq jbak 15.0)
  (setq lay nil)
  (while (setq lay (tblnext "block" (not lay)))
    (setq lays (append
   lays
   (list (cdr (assoc 2 lay)))
  (setq uuu 0
i 0
  (while (< i (length lays))
    (setq char-02 (nth i lays))
    (if (= (substr char-02 1 4) "区域")
(if (> (atoi (substr char-02 5)) uuu)
   (setq uuu (atoi (substr char-02 5)))
    (setq i (1+ i))
  (while (progn
    (while (progn
      (initget "S ")
      (if (= (setq pt (getpoint (strcat "\n指定内部点,或[设置(S)]:<偏移距离" (rtos jbak) ">")))
      "S"
        (if (setq s (getreal (strcat "\n设置偏移距离:<" (rtos jbak) ">")))
   (setq jbak s)
      (if (null pt)
       (vl-exit-with-error "")
      (or
        (= pt "S")
        (not (= (type pt) 'list))
    (= (type pt) 'list)
    (command ".UNDO" "BE")
    (setq snap (getvar "osmode"))
    (setvar "osmode" 0)
    (command "BPOLY" pt "")
    (setq name (entlast)
   list1 (zz01 (entget name))
   ss (ssadd)
    (command "OFFSET" jbak name pt "")
    (setq name1 (entlast)
   list2 (zz01 (entget name1))
    (ssadd name1 ss)
    (entdel name)
    (foreach x list2
      (setq long 1e6)
      (foreach y list1
(if (< (distance x y) long)
   (setq pt1 y
  long (distance x y)
      (entmake (list '(0 . "LINE") '(100 . "AcDbEntity") (cons 10 x) (cons 11 pt1)))
      (ssadd (entlast) ss)
    (setq char-1 (strcat "区域" (itoa (setq uuu (1+ uuu)))))
    (command "block" char-1 pt ss "")
    (command "INSERT" char-1 pt 1 1 0)
    (setvar "osmode" snap)
    (command ".UNDO" "E")
发表于 2018-12-5 18:40:44 | 显示全部楼层
hhh454 发表于 2017-11-1 19:11
代码思路:1,取得选择多义线的各个端点                  2,取得偏移后多义线的端点
用不了,程序缺失
发表于 2018-12-5 19:16:53 | 显示全部楼层
拾取饰线偏移连接端点
快捷命令 QG
发表于 2018-12-7 00:00:15 | 显示全部楼层
谢谢! KO你 分享程序!!!!!
发表于 2018-12-7 00:23:56 | 显示全部楼层
谢谢! xyp1964 分享程序!!!!!
发表于 2019-9-13 21:15:27 | 显示全部楼层
能给个源码吗?,谢谢了:D
发表于 2019-9-13 22:29:26 | 显示全部楼层
请问程序的启动命令,谢谢!
发表于 2019-9-21 21:45:53 | 显示全部楼层
谢谢!分享程序!
GMT+8, 2026-1-16 08:56 , Processed in 0.183282 second(s), 18 queries , Gzip On.
