查看: 874|回复: 2
[提问] 求助,请问论坛的各位大神,坐标点如何按y坐标分组!
发表于 2018-3-11 09:46:22 | 显示全部楼层 |阅读模式
((0.0 0.0 0.0) (15.0 0.0 0.0) (0.0 0.0 0.0) (15.0 15.0 0.0) (15.0218 15.0
0.0) (0.0 20.8341 0.0) (30.0 30.0 0.0) (40.0 30.0 0.0) (60.0 55.0 0.0) (90.0
80.0 0.0) (80.0 80.0 0.0) (90.0 90.0 0.0) (100.0 90.0 0.0) (100.0 100.0 0.0)
(79.5591 100.0 0.0))
发表于 2018-3-11 11:36:52 | 显示全部楼层
发表于 2018-3-13 14:15:04 | 显示全部楼层
  1. (defun c:tt ()
  2.   (setq        ptn  '((0.0 0.0 0.0)
  3.                (15.0 0.0 0.0)
  4.                (0.0 0.0 0.0)
  5.                (15.0 15.0 0.0)
  6.                (15.0218 15.0 0.0)
  7.                (0.0 20.8341 0.0)
  8.                (30.0 30.0 0.0)
  9.                (40.0 30.0 0.0)
  10.                (60.0 55.0 0.0)
  11.                (90.0 80.0 0.0)
  12.                (80.0 80.0 0.0)
  13.                (90.0 90.0 0.0)
  14.                (100.0 90.0 0.0)
  15.                (100.0 100.0 0.0)
  16.                (79.5591 100.0 0.0)
  17.               )
  18.         ptn  (vl-sort ptn '(lambda (x y) (< (cadr x) (cadr y))))
  19.         tmp '()
  20.   )
  21.   (while ptn
  22.     (setq z    (cadar ptn)
  23.           ptn1 (vl-remove-if '(lambda (x) (/= (cadr x) z)) ptn)
  24.           tmp (cons ptn1 tmp)
  25.           ptn  (vl-remove-if '(lambda (x) (= (cadr x) z)) ptn)
  26.     )
  27.   )
  28.   (reverse tmp)
  29. )
GMT+8, 2026-1-26 04:27 , Processed in 1.842093 second(s), 25 queries , Gzip On.
