楼主: tungtat
[源码] CAD转钻孔帮忙修改
发表于 2018-4-21 20:14:54 | 显示全部楼层
(defun c:db()
   (setvar "cmdecho" 0)
   (setq FN (getvar "dwgname")); PCB1234MT.dwg
   (setq n 1 k 0)
   (While (> n 0)
     (setq Tac (vl-string-elt FN k))
         (if (and (> Tac 47)(< Tac 58));0是48,9是57
             (setq n 0)
                 (setq k (1+ k))
   (setq FN (substr FN (+ k 1)))
   (setq n 1 k 0)
   (While (> n 0)
         (if (> Tac 64);65是大写字母A
             (setq n 0)
                 (setq k (1+ k))
   (setq FN (substr FN 1 k))
   (setq file2 (strcat "C:\\NC\\" FN "p.NC"))
   ;(setq file2 (getstring "\n 请输入路径及文件名"))
   (setq file3(open file2 "w"))
   (if(= file3 nil)
      (alert  "路径或文件名错误!")
      (exit)
  (princ "请选择要钻孔的圆:")
   (setq a (ssget))
   (setq n (sslength a))
   (setq i 0 m 0 Lzb nil)
   (repeat n
     (setq en(ssname a i))
     (setq endata(entget en))
     (setq entype(cdr (assoc 0 endata)))
     (if(= entype "CIRCLE")
           (setq ZB (cdr(assoc 10 endata)))
           (setq Lzb (cons ZB Lzb))
       (setq x(cadr(assoc 10 endata)))
       (setq y(caddr(assoc 10 endata)))
       (princ "X" file3)
       (princ (rtos x 2 3) file3)
       (princ "  " file3)
       (princ "Y" file3)
       (princ (rtos y 2 3) file3)
       (princ "\n" file3)
       (setq m (+ 1 m))
     (setq i (+ 1 i))
(princ (strcat "\n共有<" (itoa m) ">孔被选取!"))
(prin1)
(close file3)
(setq R_c (cdr(assoc 40 endata)))
        (setq Tzb1(Last Lzb))
        (setq Tzb2 (last (reverse Lzb)))
        (setq Txzb (- (* 1.5 (car Tzb1)) (* 0.5 (car Tzb2))))
        (setq Tyzb (* 0.5 (+ (cadr Tzb2) (cadr Tzb1))))
        (setq Tzb (list Txzb Tyzb))
        (prin1)
;;;;写字: PCB板钻孔文件为FN;;;;;;;;
(setq Txt (strcat "PCB板钻孔文件为" FN "P.NC"))
(entmake (list
                 (cons 0 "TEXT")
                         (cons 100 "AcDbEntity")
                         (cons 100 "AcDbTexe")
                 (cons 62 6);颜色粉红
                         (cons 10 Tzb)
                         (cons 40 (/ R_c 3));字高2.5
                 (cons 7  "standard")
                 (cons 1  Txt)
发表于 2018-4-22 08:38:16 | 显示全部楼层
看一下是不是你想要的
(defun c:db(/ a en endata entype file2 file3 i m n pt x y)
        (setq file2 (strcat "c:/Nc/"(vl-string-right-trim ".dwg"(getvar "DWGNAME")) "P.nc"))
        (if(= file3 nil)
      (alert  "路径或文件名错误!")
      (exit)
  (princ "请选择要钻孔的圆:")
        (setq a (ssget))
        (setq i 0 m 0)
        (repeat n
                                (princ "X" file3)
                                (princ "  " file3)
                                (princ "Y" file3)
                                (princ "\n" file3)
                                (setq m (+ 1 m))
                (setq i (+ 1 i))
        (close file3)
        (if (setq pt (getpoint "\n文字放置点: "))
                (entmakeX (list '(0 . "TEXT") (cons 1 (strcat (vl-string-right-trim ".dwg"(getvar "DWGNAME")) "P.nc")) (cons 10 pt) (cons 40 5) (cons 62 1)))
        (prin1)
 楼主| 发表于 2018-4-22 14:17:05 | 显示全部楼层
ntwison 发表于 2018-4-21 20:14
(defun c:db()
非常感谢。谢谢
 楼主| 发表于 2018-4-22 14:19:28 | 显示全部楼层
xiaolong1487 发表于 2018-4-22 08:38
看一下是不是你想要的
        (setvar "cmdecho" ...
输出的文件名没达到,不过会员 ntwison 已帮我搞定。还是非常感谢你
 楼主| 发表于 2018-4-22 14:49:35 | 显示全部楼层
Andyhon 发表于 2018-4-21 18:16
(setq file7 (getstring (strcat "\nDefault-->" file2 " OK?  ")))
(cond
  ((= file7 ""))
非常感谢,符合我的使用
发表于 2018-4-24 23:21:25 | 显示全部楼层
这个东西,写出去,是不是还要加文件头,文件尾啊?
孔径不同的在一起,咋处理啊?
发表于 2018-4-24 23:34:27 | 显示全部楼层
(ssget (list (cons 0 "CIRCLE")))
选实体的时候,变成上面的这样,就只选圆了。
后面的用repeat也好,while循环也好,直接处理了。不在需要进行判断是否为圆了。
在搜一搜,坐标排序,这样的话,你的NC程序,虽然简单,但是钻孔时,就是按最短路径加工了。
 楼主| 发表于 2018-4-25 16:13:58 | 显示全部楼层
后面的用repeat也好,wh ...
这个程式只用于天马机钻孔而已,只需一种钻嘴,开头和结束,天马软件会识别。
以下这个可以分孔径大小,镭铭机钻孔用,照参各位大神的提示修改文件名。
兄弟机不能用,除非另外软件改写。再说我厂也没兄弟机,所以没有源代码。
(defun c:nc()
  (setvar "CMDECHO" 0)
  (if (setq ss (ssget '((0 . "CIRCLE")))) (progn
   (command ".UNDO" "BE")
   (setq i -1  cirlst (list))
   (repeat (sslength ss)
    (setq r (cdr (assoc 40 (entget (setq en (ssname ss (setq i (1+ i))))))))
    (if (assoc r cirlst)
  (setq cirlst (subst (cons r (1+ (cdr (assoc r cirlst)))) (assoc r cirlst) cirlst))
     (setq cirlst (cons (cons r 1) cirlst))
   (setq i -1 cirlst (reverse cirlst) cclist (list))
   (setq cirlst (vl-sort cirlst (function (lambda (e1 e2) (> (car e1) (car e2))))))
   (repeat (length cirlst)
    (setq r (car (nth (setq i (1+ i)) cirlst)))
    (command "select" ss "")
    (setq ss1 (ssget "P" (list (cons 0 "CIRCLE") (cons 40 r))))
    (setq j 0 clist (list r))
    (repeat (sslength ss1)
     (setq ent (entget(ssname ss1 j)))
  (setq j (1+ j))
  (setq pc (cdr(assoc 10 ent)))
  (setq clist (append clist (list (list (car pc) (cadr pc)))))
    (setq cclist (cons clist cclist))
   (setq nm (if nm nm ""))
   (if (setq nm (getfiled "输入文件名" nm "drl" 1)) (progn
    (setq i 0)
    (setq fp (open nm "w"))
    (princ "M48\nMETRIC\nVER,1\nFMAT,2\n" fp)
    (repeat (length cclist)
     (setq r (car(nth i cclist)))
     (setq i (1+ i))
     (princ (strcat "T" (if (< i 10) "0" "") (itoa i) "C" (rtos (+ r r) 2 3) "F423B423S6H1800\n") fp)
    (princ "DETECT,ON\nATC,ON\n%\n" fp)
    (setq i 0)
     (setq clist (nth i cclist) i (1+ i))
  (princ (strcat "T" (if (< i 10) "0" "") (itoa i) "\n") fp)
  (setq j 0 clist (cdr clist))
  (repeat (length clist)
   (setq pc (nth j clist) j (1+ j))
   (princ (strcat "X" (rtos (car pc) 2 3) "Y" (rtos (cadr pc) 2 3) "\n") fp)
    (princ "M30\n%\n" fp)
    (close fp)
   (command ".UNDO" "E")
  (setvar "CMDECHO" 1)
发表于 2018-12-5 21:36:44 | 显示全部楼层
我知你是那个人了,叫我改呀。:P
GMT+8, 2026-1-19 17:06 , Processed in 0.249941 second(s), 20 queries , Gzip On.
