- 积分
- 31999
- 明经币
- 个
- 注册时间
- 2013-1-25
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
自己写了LISP创建工具栏菜单组代码,在AutoCAD2014版下加载,工具栏不能全部调出,大家分析原因在哪?就是下面几句,只有2句奏效:
- (if (menugroup "三领工具栏") ; 若已加载三领工具栏
- (progn
- (command "toolbar" "SL-绘制" "s" ) ; 显示工具栏
- (command "toolbar" "SL-钢筋" "s" )
- (command "toolbar" "SL-查询" "s" )
- (command "toolbar" "SL-编辑" "s" )
- (command "toolbar" "SL-常用" "s" )
- (command "toolbar" "SL-文件" "s" )
- (command "toolbar" "SL-缩放" "s" )
- (princ)
程序代码如下:
 - ;;判断【三领外挂工具栏】菜单是否加载,没有则创建并加载之
- (defun create_toolbar (/ file lst x)
- (if (null (menugroup "三领工具栏")) ; 判断cad是否加载三领工具栏
- (progn ; 如果没加载,则自动执行下面程序
- ;;;;;(alert "\n程序自动创建\"三领工具栏\",请稍后")
- (setq file (open "D:/三领外挂/三领工具栏.mnu" "W")) ; 在cad搜索目录创建一个菜单mnu文件,写状态打开
- (foreach x '(
- "***menugroup=三领工具栏"
- "***toolbars"
- "**绘制"
- "[_toolbar(\"SL-绘制\", _floating, _show, 3, 97, 21)]"
- "[_button(\"直线 line \", line16, line16)]^c^c_line "
- "[_button(\"云线 yx\", yx_16, yx_16)]^c^cyx "
- "[_button(\"线045\", icon1322, icon1322)]*^c^cpline;\\w;(* (getvar \"DIMSCALE\") 0.45);(* (getvar \"DIMSCALE\") 0.45) "
- "[_button(\"线070\", icon0333, icon0333)]*^c^cpline;\\w;(* (getvar \"DIMSCALE\") 0.7);(* (getvar \"DIMSCALE\") 0.7)"
- "[_button(\"折线 polyline\", icon3035, icon3035)]^c^c_pline;\\w;0;0 "
- "[_button(\"样条曲线 spline\", icon0153, icon0153)]^c^c_spline"
- "[_button(\"平行线 pxx\", icon9894, icon9894)]^c^cpxx "
- "[_button(\"选线写字 suan-xz\", icon9895, icon9895)]^c^csuan-xz "
- "[_button(\"水平字符 xzp\", icon8716, icon8716)]^c^cxzp"
- "[_button(\"垂直字符 xzc\", icon9718, icon9718)]^c^cxzc "
- "[_button(\"水平空心字符 x-xzp\", icon7035, icon7035)]^c^cxxzp "
- "[_button(\"垂直空心字符 xxzc\", icon9264, icon9264)]^c^cxxzc "
- "[_button(\"写汉字 xhz\", rcda9358, rcda9358)]^c^cxhz"
- "[_button(\"写5号汉字x-hz\", rcda9169, rcda9169)]^c^cx-hz "
- "[_button(\"两点圆弧 arc\", arc2p, arc2p)]^C^C2parc"
- "[_button(\"智能中心线 ce\", zxx, zxx)]^c^cce"
- "[_button(\"圆 圆心、半径 circle\",icon1150, icon1150)]^c^c_circle "
- "[_button(\"椭圆 中心点 ellipse\", ellipse16, ellipse16)]^c^c_ellipse"
- "[_button(\"填充圆 tc-point\", icon3811, icon3811)]^c^ctcyx "
- "[_button(\"钢筋点shi-point\", icon8703, icon8703)]^c^cgangjind "
- "[_button(\"点 point\", icon8723, icon8723)]*^c^c_point "
- "[_button(\"细线矩形 00jx\", icon7711, icon7711)]^c^c_rectang "
- "[_button(\"钢筋框 045jx\", icon8253, icon8253)]^c^cgjk "
- "[_button(\"涂黑 th\", icon5141, icon5141)]^c^cth "
- "[_button(\"填充矩形 tcjx\", icon6868, icon6868)]^c^ctcjx "
- "[_button(\"椭圆孔 slot\", tyk, tyk)]^c^cslot "
- "[_button(\"剖面号 pmh\", icon4771, icon4771)]^c^cpmhao "
- "[_button(\"剖切符 pq\", xtsy, xtsy)]^c^cpq "
- "[_button(\"现场焊 xth\", xch, xch)]^c^cxth "
- "[_button(\"非现场焊 fxth\", fxch, fxch)]^c^cfxth "
- "[_button(\"3点焊缝 3phf \", icon8636, icon8636)]^c^c3phf "
- "[_button(\"箭头 jian tou\", icon1538, icon1538)]^c^cjt "
- "[_button(\"对称符 dui chen\", duic, duic)]^c^cduichen "
- "[_button(\"折断线 zdx\", icon1726, icon1726)]^c^czdx "
- "[_button(\"双折断线 zdx1\", shuang-jx, shuang-jx)]^c^czdx1 "
- "[_button(\"圆柱截断线 syp\", zhujd, zhujd)]^c^csyp "
- "[_button(\"左标高 l-bgf\", icon1842, icon1842)]^c^cl-bgf "
- "[_button(\"右标高 r-bgf\", icon5447, icon5447)]^c^cr-bgf "
- "[_button(\"加轴线号 zhx-hao\", icon1869, icon1869)]^c^czhux-hao "
- "[_button(\"详图号 xthao\", rcda5705, rcda5705)]^c^cxthao "
- "[_button(\"填充 hatch\", icon7644, icon7644)]^c^c_bhatch "
- "[_button(\"墙线填充 tc-qx\", icon7673, icon7673)]^c^ctcqx "
- "[_button(\"混凝土填充 tc-hnt\", icon4664, icon4664)]^c^ctchnt "
- "[_button(\"填充轻材 tcqc\", rcda6334, rcda6334)]^c^ctcqc "
- "[_button(\"继承填充 jctc\", laywlk16, laywlk16)]^c^cjctc "
- "[_button(\"动态填充比例\", icon6541, icon6541)]^c^ctt "
- "[_button(\"平行线间距 ll\", icon3430, icon3430)]^c^cll "
- "[_button(\"点点标注 dd-dim\", rcda9718, rcda9718)]^c^cdd-dim "
- "[_button(\"选线标注 ali-dim\", al-dim, al-dim)]^c^cali-dim "
- "[_button(\"尺寸界线 ccjx\", icon5667, icon5667)]^c^cccjx-h "
- "[_button(\"弧长标注 hu\", rcda9961, rcdat9961)]^c^chu "
- "[_button(\"引线标注 yxbz\", rcda4827, rcda4827)]^c^cyxbz "
- "[_button(\"坐标标注 zb\", rcda2382, rcda2382)]^c^czb "
- "**钢筋"
- "[_toolbar(\"SL-钢筋\", _floating, _show, 963, 130, 21)]"
- "[_button(\"门钢构件表\", mengang, mengang)]^c^cmggl "
- "[_button(\"钢构件截面特征\", jmtz, jmtz)]^c^c(startapp \"d://三领外挂//实用程序//型钢截面特性查询及计算工具.exe\")"
- "[_button(\"选筋表\", xjb, xjb)]^c^c(startapp \"d://三领外挂//实用程序//TSSD2010选筋表.exe\")"
- "[_button(\"画板钢筋 bj\", rcda7421, rcda7421)]^c^cbj "
- "[_button(\"画板正筋 ban-zj\", icon6299, icon6299)]^c^cban-zj "
- "[_button(\"画板负筋 ban-fj\", icon9912, icon9912)]^c^cban-fj "
- "[_button(\"改写箍筋\", gujin, gujin)]^c^cgujin "
- "[_button(\"改写1根3级\", d1-3, d1-3)]^c^c1-3 "
- "[_button(\"改写2根3级\", d2-3, d2-3)]^c^c2-3 "
- "[_button(\"改写3根3级\", d3-3, d3-3)]^c^c3-3 "
- "[_button(\"改写4根3级\", d4-3, d4-3)]^c^c4-3 "
- "**查询"
- "[_toolbar(\"SL-查询\", _floating, _show, 937, 461, 6)]"
- "[_button(\"列表显示\", list_16, list_16)]^c^cus-list "
- "[_button(\"查找、替换\", icon3931, icon3931)]^c^cfid "
- "[_button(\"查小于定字高的汉字\", chahz1, chahz1)]^c^cchahz "
- "[_button(\"面积\", mianji, mianji)]^c^c_area "
- "[_button(\"显示实体dxf码\", icon4084, icon4084)]^c^cprintdxf "
- "[_button(\"距离\", juli_16, juli_16)]'_dist "
- "[_button(\"标出型心\", rcda2391, rcda2391)]^c^ccr "
- "**编辑"
- "[_toolbar(\"SL-编辑\", _floating, _show, 963, 130, 21)]"
- "[_button(\"删除 erase\", icon7421, icon7421)]*^c^c_erase si auto "
- "[_button(\"按层删除 ly-erase\", icon2382, icon2382)]^c^cdellayer "
- "[_button(\"oops!\", icon8909, icon8909)]^c^c_oops "
- "[_button(\"剪切 trim\", icon7529, icon7529)]^c^c_trim "
- "[_button(\"点移dmove\", icon6827, icon6827)]*^c^cmove;\\;(nth 1(grread 5)) "
- "[_button(\"选移 ss-move\", icon9961, icon9961)]^c^csmove "
- "[_button(\"定距移 move disp\", icon2929, icon2929)]^c^cpy "
- "[_button(\"点拷贝 d-copy\", icon5705, icon5705)]*^c^ccopy;\\;(nth 1(grread 5)) "
- "[_button(\"多点拷贝 copy m\", icon8145, icon8145)]^c^ccopym "
- "[_button(\"选拷贝ss-copy\", icon3281, icon3281)]^c^cscopy "
- "[_button(\"定距拷贝 copy disp\", icon4833, icon4833)]^c^cpyfz "
- "[_button(\"偏移\", icon6308, icon6308)]^c^c_offset "
- "[_button(\"双向延伸 extend\", icon0778, icon0778)]^c^cys "
- "[_button(\"拉伸 stretch\", icon1323, icon1323)]*^c^c_stretch c "
- "[_button(\"定值改变实体比例 num-sc\", icon0491, icon0491)]^c^cnum-sc "
- "[_button(\"倒角chamfer\", icon2859, icon2859)]^c^c_chamfer "
- "[_button(\"圆角fillet\", yuanjiao, yuanjiao)]^c^c_fillet "
- "[_button(\"旋转ang-rot\" icon2995, icon2995)]^c^cang-rot "
- "[_button(\"【文字或物体】动态对齐于曲线 x-rot-mov\", icon2082, icon2082)]^c^c(if (null c:x-rot-mov )(load \"x-rot-mov.vlx\"));x-rot-mov "
- "[_button(\"实体旋转平行于直线 x-rotate\", icon1115, icon1115)]^c^cx-rotate "
- "[_button(\"按图层改线宽与线型 c-gx\", icon0292, icon0292)]^c^cc-gx "
- "[_button(\"分解-explode\", icon8397, icon8397)]^c^c_explode "
- "[_button(\"分解pl-explode\", icon5350, icon5350)]^c^cexpline "
- "[_button(\"改线宽为 0 gx00\", icon1942, icon1942)]^c^cgx00 "
- "[_button(\"改线宽为 0.70 gx070\", icon0333, icon0333)]^c^cgx070 "
- "[_button(\"改线宽为 0.45 gx045\", icon1322, icon1322)]^c^cgx045 "
- "[_button(\"线弧圆宽度修改\", rcda6962, rcda6962)]^c^cpn1 "
- "[_button(\"连线、弧、多段线\", lianxian, lianxian)]^c^cjf "
- "[_button(\"编辑多段线\", bjddx, bjddx)]^c^c_pedit "
- "[_button(\"水平镜像且移动定位,原图删除 h-mir-mv\", icon3805, icon3805)]^c^ch-mr-mv "
- "[_button(\"垂直镜像且移动定位,原图删除v-mir-mv\", icon5890, icon5890)]^c^cv-mr-mv "
- "[_button(\"水平镜像且移动定位,原图不删除h-mr-mv-n\", icon5537, icon5537)]^c^ch-mr-mv-n "
- "[_button(\"垂直镜像且移动定位,原图不删除v-mr-mv-n\", icon6118, icon6118)]^c^cv-mr-mv-n "
- "[_button(\"以直线镜像 j-mirror\", icon2704, icon2704)]^c^cj-mirror "
- "[_button(\"阵列\", zhenlie_16, zhenlie_16)]^c^c_array "
- "[_button(\"两点打断\", icon4370, icon4370)]*^c^c_break \\_f "
- "[_button(\"改为虚线 ch-cxx\", icon2391, icon2391)]^c^cch-cxx "
- "[_button(\"改为实线ch-sx\", icon0153, icon0153)]^c^cch-csx "
- "[_button(\"改为点划线 ch-cl\", icon3902, icon3902)]^c^cch-cl "
- "[_button(\"改为轴线 ch-czx\", icon4604, icon4604)]^c^cch-czx "
- "[_button(\"动态线型比例\", dtxx_16, dtxx_16)]^c^cdt-xx "
- "[_button(\"改成-虚体字\", rcda1478, rcda1478)]^c^cch-xz "
- "[_button(\"改成-实体字\", gstz, gstz)]^c^cch-sz "
- "**常用"
- "[_toolbar(\"SL-常用\", _top, _show, 0, 0, 1)] "
- "[_button(\"炸开清理全图\", icon9741, icon9741)]^c^ct-explode "
- "[_button(\"删除重复线\", trmblk16, trmblk16)]^c^cduprem "
- "[_button(\"1,1,0插入图块 insert;1;1;0\", icon2662, icon2662)]^c^cinsert "
- "[_button(\"选取图块插入点 insbase\", 4mi_16, 4mi_16)]^c^cinsbase "
- "[_button(\"设计中心\", rcda6500, rcda6500)]$m=$(if,$(and,$(getvar,adcstate),1),'_adcclose,'_adcenter) "
- "[_button(\"删除及合并图层\", rcda, rcda)]^c^c(if (null c:sstc )(load \"sstc.vlx\"));sstc "
- "[_button(\"将对象的图层置为当前\", dqc_16, dqc_16)]^c^c_ai_molc "
- "[_button(\"图层特性管理器\", tcgl_16, tcgl_16)]'_layer "
- "[_control(_layer)]"
- "[_button(\"按色分层\", d2, d2)]^c^cas-c "
- "[_button(\"全图-颜色随层\", d3, d3)]^c^csc-zd "
- "[_button(\"选择-颜色随层\", d1, d1)]^c^csc-x "
- "[_button(\"色变\", wzzk, wzzk)]^c^c(if (null c:sb )(load \"sbv10.vlx\"));sb "
- "[_button(\"match properties\", icon2209, icon2209)]'_matchprop "
- "[_button(\"ss-cht\", icon5724, icon5724)]^c^cch-text "
- "[_button(\"edit text\", icon2648, icon2648)]^c^cdd-cht "
- "[_button(\"chtext\", icon3548, icon3548)]^c^cchgtext "
- "[_button(\"改数字高\", icon1101, icon1101)]^c^cch-sz-hi "
- "[_button(\"改汉字高\", icon4393, icon4393)]^c^cch-hz-hi "
- "[_button(\"动态文字\", dtwz, dtwz)]^c^cmacedit "
- "[_button(\"屏幕改字\", rcda3902, rcda3902)]^c^c(if (null c:pmgz )(load \"pmgz.vlx\"));pmgz "
- "[_button(\"插入特殊符号\", icon1621, icon1621)]^c^ccrfh "
- "[_button(\"文字炸开\", icon6729, icon6729)]^c^cexpzi "
- "[_button(\"炸字成线\", zha-z-xian, zha-z-xian)]^c^czhazxian "
- "[_button(\"字符合并zfhb\", zfhb, zfhb)]^c^czfhb "
- "[_button(\"求和\", icon4626, icon4626)]^c^cqiuhe "
- "[_button(\"求平均值\", pjz, pjz)]^c^cpjz "
- "[_button(\"求积\", qiuji, qiuji)]^c^c_qiuji "
- "[_button(\"线长度统计\", adline, adline)]^c^cad "
- "[_button(\"打印预览\", icon4583, icon4583)]^c^c_preview "
- "[_button(\"页面设置\", ymsz, ymsz)]^c^c_pagesetup "
- "[_button(\"批量打印\", bdyplot, bdyplot)]^c^c(if (null c:BatchPlot-v3.6 )(load \"BatchPlot-v3.6.vlx\"));bplot "
- "[_button(\"打印\", icon5573, icon5573)]^c^c_plot "
- "[_button(\"计算器\", d41, d41)]^c^c(startapp \"d://三领外挂//实用程序//calcplus.exe\") "
- "**文件"
- "[_toolbar(\"SL-文件\", _floating, _show, 57, 97, 19)] "
- "[_button(\"设置绘图\", icon2623, icon2623)]^c^chtbl "
- "[_button(\"按1:1绘图\", bl1-1, bl1-1)]^c^c(setvar \"DIMSCALE\" 100) "
- "[_button(\"按1:100绘图\", bl1-100, bl1-100)]^c^c(setvar \"DIMSCALE\" 1) "
- "[_button(\"cancel\", icon8756, icon8756)]^c^c "
- "[_button(\"new\", icon1840, icon1840)]^c^c_new "
- "[_button(\"limtoext\", icon2554, icon2554)]^c^climtoext "
- "[_button(\"打开\", cj_open, cj_open)]^c^c_open "
- "[_button(\"保存\", cj_save, cj_save)]^c^c_qsave "
- "[_button(\"另存为\", icon2757, icon2757)]^c^c_saveas "
- "[_button(\"局部存盘\", jbcp, jbcp)]^c^c_wblock "
- "[_button(\"quit\", icon2316, icon2316)]^c^c_quit "
- "[_button(\"end\", icon0037, icon0037)]^c^c_end "
- "[_button(\"cut\", icon5006, icon5006)]^c^c_cutclip "
- "[_button(\"copy to clipboard\", icon9629, icon9629)]^c^c_copyclip "
- "[_button(\"paste\", icon3094, icon3094)]^c^c_pasteclip "
- "[_button(\"paste\", icon7446, icon7446)]^c^cpasteblock "
- "[_button(\"放弃\", icon3655, icon3655)]_u "
- "[_button(\"重做\", icon4767, icon4767)]^c^c_mredo 1 "
- "[_button(\"文字样式批量修改\", c_texedi, c_texedi)]^c^c(if (null c:cs )(load \"csstyle.vlx\"));cs "
- "[_button(\"修改乱码,炸开mtext,text统一左定位\", exp_zq, exp_zq)]^c^cfs "
- "[_button(\"整图缩放\", rcda9895, rcda9895)]^c^csc-t "
- "[_button(\"选项\", rcda1942, rcda1942)]^c^c_options "
- "[_button(\"autolisp 加载\", rcda2995, rcda2995)]^c^c_appload "
- "**缩放"
- "[_toolbar(\"SL-缩放\", _floating, _show, 934, 127, 14)] "
- "[_button(\"实时缩放\", sssf, sssf)]'_zoom ; "
- "[_button(\"实时平移\", zysx_pan, zysx_pan)]'_pan "
- "[_button(\"zoom all\", icon9658, icon9658)]'_zoom _all "
- "[_button(\"范围缩放\", icon2386, icon2386)]'_zoom _e "
- "[_button(\"zoom window\", icon9954, icon9954)]'_zoom;_w "
- "[_button(\"放大\", icon1107, icon1107)]'_zoom 2x "
- "[_button(\"缩小\", icon0191, icon0191)]'_zoom .5x "
- "[_button(\"zoomc4x\", icon9169, icon9169)]^c^czoomc4x "
- "[_button(\"zoomc1/2x\", icon5547, icon5547)]^c^czoomc1/2x "
- "[_button(\"pan left\", icon0041, icon0041)]'_pan ^p(trans (list (* -0.4 (getvar \"viewsize\")) 0) 0 1) ;^p "
- "[_button(\"pan right\", icon8467, icon8467)]'_pan ^p(trans (list (* 0.4 (getvar \"viewsize\")) 0) 0 1) ;^p "
- "[_button(\"pan up\", icon6334, icon6334)]'_pan ^p(trans (list 0 (* 0.4 (getvar \"viewsize\"))) 0 1) ;^p "
- "[_button(\"pan down\", icon6500, icon6500)]'_pan ^p(trans (list 0 (* -0.4 (getvar \"viewsize\"))) 0 1) ;^p "
- "[_button(\"zoom p\", icon1478, icon1478)]^c^c5 "
- "[_button(\"全部重生成\", rcda8145, rcda8145)]^c^c_regenall "
- (princ (strcat x "\n") file) ; 将定义工具栏内容写入mnu文件
- (close file) ; 关闭mnu文件
- (command "menuload" "三领工具栏.mnu") ; 加载三领工具栏
- (progn
- (princ)
- (create_toolbar) ; 本句的作用是加载本lisp就自动执行create_toolbar子程序
