楼主: 124803430
[提问] LISP是否能控制OPTIONS设置内容???
发表于 2018-10-10 22:04:41 | 显示全部楼层
参数怎么设定?这个只能显示而已
发表于 2018-10-11 16:27:32 | 显示全部楼层
之前只表达思路以参考,其它都以同样方式让自己去研究
因为有些参数我也搞不懂怎样设置 。。。
先用vlax-dump-object查询字典 activeX方式(method)或属性 (property)
(RO) - 只读
vla- 应用方式(如有)
vla-get- 读取参数
vla-put- 设定参数
举例:
(setq display (vla-get-display  (vla-get-preferences (vlax-get-acad-object) ) ) ) ;显示之文件库
(vlax-dump-object display t) ;查询相关字典
; IAcadPreferencesDisplay: This object contains the options from the Display tab on the Options dialog
; Property values:
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00d077b4>
;   AutoTrackingVecColor = unsupported result type: 19
;   CursorSize = 5
;   DisplayLayoutTabs = -1
;   DisplayScreenMenu = 0
;   DisplayScrollBars = 0
;   DockedVisibleLines = 2
;   GraphicsWinLayoutBackgrndColor = unsupported result type: 19
;   GraphicsWinModelBackgrndColor = unsupported result type: 19
;   HistoryLines = 400
;   ImageFrameHighlight = 0
;   LayoutCreateViewport = -1
;   LayoutCrosshairColor = unsupported result type: 19
;   LayoutDisplayMargins = -1
;   LayoutDisplayPaper = -1
;   LayoutDisplayPaperShadow = 0
;   LayoutShowPlotSetup = 0
;   MaxAutoCADWindow = 0
;   ModelCrosshairColor = unsupported result type: 19
;   ShowRasterImage = 0
;   TextFont = "Courier New"
;   TextFontSize = 10
;   TextFontStyle = 0
;   TextWinBackgrndColor = unsupported result type: 19
;   TextWinTextColor = unsupported result type: 19
;   TrueColorImages = -1
;   XRefFadeIntensity = 50
; No methods ;无应用方式
  1. (vla-get-LayoutDisplayPaperShadow display ) ; 读取阴影值
  2. ;返回 0
  3. (vla-put-LayoutDisplayPaperShadow display -1 ) ; 设置阴影值-开启=-1
  4. (vla-regen (vla-get-activedocument(vlax-get-acad-object)) 0 ) ;更新
发表于 2021-5-25 20:30:54 来自手机 | 显示全部楼层
reg文件不香嘛
发表于 2021-5-27 16:36:34 | 显示全部楼层
我记得有个低版本的CAD中,是可以用系统变量设置输入命令行的行数的?但是就是忘记了是哪个变量?现在高版本的CAD中调整命令行行数,得用鼠标拖动。有没有高人知道是哪个系统变量控制命令行的行数啊?谢谢
GMT+8, 2026-1-17 09:44 , Processed in 0.182012 second(s), 20 queries , Gzip On.
