查看: 3008|回复: 3
唉!又卡住了
发表于 2002-8-14 12:12:00 | 显示全部楼层 |阅读模式
为什么选择集带参数就不可以了呢?是不是写法不正确?
(defun delblk()
  (setq ck_insert_name_del "A")
  (command "erase" (ssget "x" '((0 . "insert")(2 . ck_insert_name_del))) "")
(command "purge" "b" ck_insert_name_del "n")
帮忙解决。
发表于 2002-8-14 12:30:00 | 显示全部楼层
改成这样吧...
(command "erase" (ssget "X"  (list (cons  0 "INSERT)(cons  2 ck_insert_name_del))) "")
发表于 2002-8-14 12:34:00 | 显示全部楼层
这样…
(defun DELBLK ()
  (setq CK_INSERT_NAME_DEL "A")
  (command "erase"
           (ssget "x"
                  (list (CONS 0  "insert") (cons 2 CK_INSERT_NAME_DEL))
  (command "purge" "b" CK_INSERT_NAME_DEL "n")
 楼主| 发表于 2002-8-14 13:51:00 | 显示全部楼层
好了,多谢两位版主!
GMT+8, 2026-1-18 04:15 , Processed in 0.155596 second(s), 26 queries , Gzip On.
