楼主: iJero
[讨论] LSP怎么改Leader(引线)里的箭头样式和大小
发表于 2018-11-16 08:37:23 | 显示全部楼层
你自己先试一下再说,我一直这样画图的,我设置的是QQ画小点引线,QA画箭头引线。
我在一个图档里所有的标注样式只有一个,只是设置的dimscale 标注比例不同。
  1. 你自己先试一下再说,我一直这样画图的,我设置的是QQ画小点引线,QA画箭头引线。
  2. 我在一个图档里所有的标注样式只有一个,只是设置的dimscale 标注比例不同。
  3. (defun c:Qq ( / mirrtxt pt1 pt2 pt3 pt0)
  4. (setq pt1 (getpoint  "\n指定个引线第一点:"))
  5. (setq pt2 (getpoint pt1 "\n指定个引线第二点:"))
  6. ;;(undobe)
  7. (SETVAR "CMDECHO" 0)
  8. (setvar 'dimldrblk "小点")
  9. (setq *error* q_err )
  10. (setq qscale (getvar "dimscale"))
  11. (setvar "attreq" 0)
  12. (setq pt3(mapcar '/ (mapcar '+ pt1 pt2) '(2 2 2)))
  13. (setq pt0 ( polar pt3 (angtof "90") (* 3.5 (getvar 'dimscale))) )
  14. (command "_.leader" "non" pt1 "non" pt2 "" "" "n")
  15. (command "chprop" (entlast) ""  "LA" "02标注" "")
  16. (if (= (fix(cadr pt1))(fix(cadr pt2)))
  17. (entmake (list '(0 . "TEXT") (cons 1 "默认文字") (cons 7 (getvar 'textstyle)) '(8 . "06文字层") (cons 10 pt1)(cons 11 pt0)
  18.                (cons 40 (* (getvar 'dimscale) 5))(cons 41 0.8) (cons 71 0)(cons 72 4)))
  19. (progn(command "_.line" pt2 (getpoint pt2 "\n指定个引线第三点:") "")(command "chprop" (entlast) ""  "LA" "02标注" "") )
  20. )
  21. (SETVAR "CMDECHO" 1)
  22. ;;(undoe)
  23. (prin1)
  24. )
  25. (defun c:Qa ( / mirrtxt pt1 pt2 pt3 pt0)
  26. (setq pt1 (getpoint  "\n指定个引线第一点:"))
  27. (setq pt2 (getpoint pt1 "\n指定个引线第二点:"))
  28. ;;(undobe)
  29. (SETVAR "CMDECHO" 0)
  30. (setvar 'dimldrblk ".")
  31. (setq *error* q_err )
  32. (setq qscale (getvar "dimscale"))
  33. (setvar "attreq" 0)
  34. (setq pt3(mapcar '/ (mapcar '+ pt1 pt2) '(2 2 2)))
  35. (setq pt0 ( polar pt3 (angtof "90") (* 3.5 (getvar 'dimscale))) )
  36. (command "_.leader" "non" pt1 "non" pt2 "" "" "n")
  37. (command "chprop" (entlast) ""  "LA" "02标注" "")
  38. (if (= (fix(cadr pt1))(fix(cadr pt2)))
  39. (entmake (list '(0 . "TEXT") (cons 1 "默认文字") (cons 7 (getvar 'textstyle)) '(8 . "06文字层") (cons 10 pt1)(cons 11 pt0)
  40.                (cons 40 (* (getvar 'dimscale) 5))(cons 41 0.8) (cons 71 0)(cons 72 4)))
  41. (progn(command "_.line" pt2 (getpoint pt2 "\n指定个引线第三点:") "")(command "chprop" (entlast) ""  "LA" "02标注" "") )
  42. )
  43. (SETVAR "CMDECHO" 1)
  44. ;;(undoe)
  45. (prin1)
  46. )
发表于 2018-11-16 08:41:50 | 显示全部楼层
你自己尝试过没有?同一个标注样式名,可以标注出不同的样式!
  1. (defun c:qq ( / mirrtxt pt1 pt2 pt3 pt0)
  2. (setq pt1 (getpoint  "\n指定个引线第一点:"))
  3. (setq pt2 (getpoint pt1 "\n指定个引线第二点:"))
  4. ;;(undobe)
  5. (SETVAR "CMDECHO" 0)
  6. (setvar 'dimldrblk "小点")
  7. (setq *error* q_err )
  8. (setq qscale (getvar "dimscale"))
  9. (setvar "attreq" 0)
  10. (setq pt3(mapcar '/ (mapcar '+ pt1 pt2) '(2 2 2)))
  11. (setq pt0 ( polar pt3 (angtof "90") (* 3.5 (getvar 'dimscale))) )
  12. (command "_.leader" "non" pt1 "non" pt2 "" "" "n")
  13. (command "chprop" (entlast) ""  "LA" "02标注" "")
  14. (if (= (fix(cadr pt1))(fix(cadr pt2)))
  15. (entmake (list '(0 . "TEXT") (cons 1 "默认文字") (cons 7 (getvar 'textstyle)) '(8 . "06文字层") (cons 10 pt1)(cons 11 pt0)
  16.                (cons 40 (* (getvar 'dimscale) 5))(cons 41 0.8) (cons 71 0)(cons 72 4)))
  17. (progn(command "_.line" pt2 (getpoint pt2 "\n指定个引线第三点:") "")(command "chprop" (entlast) ""  "LA" "02标注" "") )
  18. )
  19. (SETVAR "CMDECHO" 1)
  20. ;;(undoe)
  21. (prin1)
  22. )
  23. (defun c:qa ( / mirrtxt pt1 pt2 pt3 pt0)
  24. (setq pt1 (getpoint  "\n指定个引线第一点:"))
  25. (setq pt2 (getpoint pt1 "\n指定个引线第二点:"))
  26. ;;(undobe)
  27. (SETVAR "CMDECHO" 0)
  28. (setvar 'dimldrblk ".")
  29. (setq *error* q_err )
  30. (setq qscale (getvar "dimscale"))
  31. (setvar "attreq" 0)
  32. (setq pt3(mapcar '/ (mapcar '+ pt1 pt2) '(2 2 2)))
  33. (setq pt0 ( polar pt3 (angtof "90") (* 3.5 (getvar 'dimscale))) )
  34. (command "_.leader" "non" pt1 "non" pt2 "" "" "n")
  35. (command "chprop" (entlast) ""  "LA" "02标注" "")
  36. (if (= (fix(cadr pt1))(fix(cadr pt2)))
  37. (entmake (list '(0 . "TEXT") (cons 1 "默认文字") (cons 7 (getvar 'textstyle)) '(8 . "06文字层") (cons 10 pt1)(cons 11 pt0)
  38.                (cons 40 (* (getvar 'dimscale) 5))(cons 41 0.8) (cons 71 0)(cons 72 4)))
  39. (progn(command "_.line" pt2 (getpoint pt2 "\n指定个引线第三点:") "")(command "chprop" (entlast) ""  "LA" "02标注" "") )
  40. )
  41. (SETVAR "CMDECHO" 1)
  42. ;;(undoe)
  43. (prin1)
  44. )
 楼主| 发表于 2018-11-16 09:17:45 | 显示全部楼层
谢谢,
我研究一下。
再次感谢。
GMT+8, 2026-1-19 18:10 , Processed in 1.520771 second(s), 19 queries , Gzip On.
