楼主: pengl86
[提问] 样条曲线动态显示半径或者长度
 楼主| 发表于 2019-1-23 12:59:49 | 显示全部楼层
在网上看了下叫动态查询属性 插件,大神们,http://bbs.mjtd.com/forum.php?mo ... E9%D1%AF&page=1
谁能帮我下载下。LSP.
这个代码有谁用过吗
;;;飞鸟集]心随我动--为LISP定制的动态输入,动态拖拉和动态信息函数之应用---动态信息查询;;;由一个经典的yad动态信息查询函数改编而来!改编: Gu_xl 2011.11.19(defun InfoCallBak (PT /  TOANG    DIS ENT)  (defun toang(ang i)    (if (= i 1)      (* ang (/ 180 pi))      (* ang (/ pi 180))    )  )(defun gxl-dxf (ent i) (cdr (assoc i (entget ent))) )  (defun dis (ENT / MJBL OBJ LAYNM NAME LST)    (if (= mjdw 1000) (setq mjbl 1000000) (setq mjbl 1))    (setq obj (vlax-ename->vla-object ent))    (setq laynm (strcat "图层:" (gxl-dxf ent 8)) name (gxl-dxf ent 0))    (cond      ((= name "3DFACE")        (setq lst (list "【三维面】" laynm))      )      ((= name "3DSOLID")        (setq lst (list "【三维实体】" laynm (strcat "格式版本号:" (itoa (gxl-dxf ent 70)))))      )      ((= name "ACAD_PROXY_ENTITY")        (setq lst (list "【代理】" laynm))      )      ((= name "ARC")        (setq lst (list "【圆弧】" laynm (strcat "半径:" (rtos (vla-get-radius obj) 2 0))                                         (strcat "圆心角:" (rtos (toang (vla-get-TotalAngle obj) 1) 2 1) "度")                                         (strcat "起始角:" (rtos (toang (vla-get-StartAngle obj) 1) 2 1) "度")                                         (strcat "终止角:" (rtos (toang (vla-get-EndAngle obj) 1) 2 1) "度")                                         (strcat "总弧长:" (rtos (vla-get-ArcLength obj) 2 0))                                         (strcat "面积:" (rtos (/ (vla-get-Area obj) mjbl) 2 2) "㎡")        ))      )      ((= name "ATTDEF")        (setq lst (list "【属性定义】" laynm (strcat "标签:" (vla-get-TagString obj))                                             (strcat "提示:" (vla-get-PromptString obj))                                             (strcat "缺省值:" (vla-get-TextString obj))                                             (strcat "高度:" (rtos (vla-get-Height obj) 2 0))                                             (strcat "角度:" (rtos (toang (vla-get-Rotation obj) 1) 2 1) "度")                                             (strcat "文字样式:" (vla-get-StyleName obj))        ))      )      ((= name "ATTRIB")        (setq lst (list "【属性】" laynm (strcat "标签:" (vla-get-TagString obj))                                         (strcat "缺省值:" (vla-get-TextString obj))                                         (strcat "高度:" (rtos (vla-get-Height obj) 2 0))                                         (strcat "角度:" (rtos (toang (vla-get-Rotation obj) 1) 2 1) "度")                                         (strcat "文字样式:" (vla-get-StyleName obj))        ))      )      ((= name "BODY")        (setq lst (list "【体】" laynm (strcat "格式版本号:" (itoa (gxl-dxf ent 70)))))      )      ((= name "CIRCLE")        (setq lst (list "【圆】" laynm (strcat "半径:" (rtos (vla-get-radius obj) 2 0))                                       (strcat "周长:" (rtos (vla-get-Circumference obj) 2 0))                                       (strcat "面积:" (rtos (/ (vla-get-Area obj) mjbl) 2 2) "㎡")        ))      )      ((= name "DIMENSION")        (setq lst (list "【尺寸标注】" laynm (strcat "标注样式:" (vla-get-StyleName obj))                                             (strcat "文字样式:" (vla-get-TextStyle obj))                                             (strcat "文字高度:" (rtos (vla-get-TextHeight obj) 2 1))                                             (strcat "替带文字:" (if (= (gxl-dxf ent 1) "") "无" (gxl-dxf ent 1)))        ))      )      ((= name "ELLIPSE")        (setq lst (list "【椭圆】" laynm (strcat "长轴半径:" (rtos (vla-get-MajorRadius obj) 2 0))                                         (strcat "短轴半径:" (rtos (vla-get-MinorRadius obj) 2 0))                                         (strcat "起始角:" (rtos (toang (vla-get-StartAngle obj) 1) 2 1) "度")                                         (strcat "终止角:" (rtos (toang (vla-get-EndAngle obj) 1) 2 1) "度")                                         (strcat "面积:" (rtos (/ (vla-get-Area obj) mjbl) 2 2) "㎡")        ))      )      ((= name "HATCH")        (setq lst (list "【图案填充】" laynm (strcat "图案名称:" (vla-get-PatternName obj))                                             (strcat "角度:" (rtos (toang (vla-get-PatternAngle obj) 1) 2 1))                                             (strcat "比例:" (rtos (vla-get-PatternScale obj) 2 0))                                             (strcat "关联:" (if (= (vla-get-AssociativeHatch obj) :vlax-false) "关闭" "打开"))                                             (strcat "填充样式:" (nth (vla-get-HatchStyle obj) '("普通" "外部" "忽略")))        ))      )      ((= name "IMAGE")        (setq lst (list "【图像】" laynm (strcat "图像大小:" (rtos (car (gxl-dxf ent 13)) 2 0) "X" (rtos (cadr (gxl-dxf ent 13)) 2 0))))      )      ((= name "INSERT")        (setq lst (list "【图块】" laynm (strcat "名称:" (gxl-dxf ent 2))                                         (strcat "X比例:" (rtos (gxl-dxf ent 41) 2 1))                                         (strcat "Y比例:" (rtos (gxl-dxf ent 42) 2 1))                                         (strcat "Z比例:" (rtos (gxl-dxf ent 43) 2 1))                                         (strcat "角度:" (rtos (toang (vla-get-Rotation obj) 1) 2 1) "度")        ))      )      ((= name "LEADER")        (setq lst (list "【引线】" laynm (strcat "标注样式:" (vla-get-StyleName obj))                                         (strcat "引线类型:" (gxl-dxf (list (cons 0 "折线") (cons 1 "样条曲线")) (gxl-dxf ent 72)))        ))      )      ((= name "LINE")        (setq lst (list "【直线】" laynm (strcat "长度:" (rtos (vla-get-length obj) 2 0))                                         (strcat "角度:" (rtos (toang (vla-get-angle obj) 1) 2 1) "度")        ))      )      ((= name "LWPOLYLINE")        (setq lst (list "【多段线】" laynm (strcat "常量宽度:" (if (gxl-dxf ent 43) (rtos (vla-get-ConstantWidth obj) 2 0) "变宽度"))                                            (strcat "多段线:" (if (= (vla-get-Closed obj) :vlax-false) "不闭合" "闭合"))                                            (strcat "面积:" (rtos (/ (vla-get-Area obj) mjbl) 2 2) "㎡")        ))      )      ((= name "MLINE")        (setq lst (list "【多线】" laynm (strcat "多线样式:" (vla-get-StyleName obj))                                         (strcat "比例因子:" (rtos (gxl-dxf ent 40) 2 1))                                         (strcat "对齐:" (nth (gxl-dxf ent 70) '("上" "零" "下")))        ))      )      ((= name "MTEXT")        (setq lst (list "【多行文字】" laynm (strcat "高度:" (rtos (vla-get-Height obj) 2 0))                                             (strcat "角度:" (rtos (toang (vla-get-Rotation obj) 1) 2 1) "度")                                             (strcat "样式:" (vla-get-StyleName obj))        ))      )      ((or (= name "OLEFRame") (= name "OLE2FRame"))        (setq lst (list "【OLE边框】" laynm (strcat "格式版本号:" (itoa (gxl-dxf ent 70)))))      )      ((= name "OINT")        (setq lst (list "【点】" laynm))      )      ((= name "OLYLINE")        (setq lst (list "【三维多段线】" laynm))      )      ((= name "RAY")        (setq lst (list "【射线】" laynm))      )      ((= name "REGION")        (setq lst (list "【面域】" laynm (strcat "格式版本号:" (itoa (gxl-dxf ent 70)))))      )      ((= name "SHAPE")        (setq lst (list "【形】" laynm (strcat "高度:" (rtos (vla-get-Height obj) 2 0))                                       (strcat "宽度系数:" (rtos (vla-get-ScaleFactor obj) 2 1))                                       (strcat "角度:" (rtos (toang (vla-get-Rotation obj) 1) 2 1) "度")        ))      )      ((= name "SOLID")        (setq lst (list "【实体】" laynm))      )      ((= name "SPLINE")        (setq lst (list "【样条曲线】" laynm (strcat "多段线:" (if (= (vla-get-Closed obj) :vlax-false) "不闭合" "闭合"))                                             (strcat "阶数:" (rtos (vla-get-Degree obj) 2 0))                                             (strcat "面积:" (rtos (/ (vla-get-Area obj) mjbl) 2 2) "㎡")        ))      )      ((= name "TEXT")        (setq lst (list "【文字】" laynm (strcat "高度:" (rtos (vla-get-Height obj) 2 0))                                         (strcat "宽度系数:" (rtos (vla-get-ScaleFactor obj) 2 1))                                         (strcat "角度:" (rtos (toang (vla-get-Rotation obj) 1) 2 1) "度")                                         (strcat "样式:" (vla-get-StyleName obj))                                         (strcat "对齐:" (nth (vla-get-Alignment obj) '("Left" "Center" "Right" "Aligned" "Middle" "Fit" "TopLeft" "TopCenter" "TopRight"        "MiddleLeft" "MiddleCenter" "MiddleRight" "BottomLeft" "BottomCenter" "BottomRight")))        ))      )      ((= name "TOLERANCE")        (setq lst (list "【公差】" laynm (strcat "标注样式:" (vla-get-StyleName obj))                                         (strcat "文字样式:" (vla-get-TextStyle obj))                                         (strcat "文字高度:" (rtos (vla-get-TextHeight obj) 2 1))        ))      )      ((= name "TRACE")        (setq lst (list "【宽线】" laynm))      )      ((= name "VERTEX")        (setq lst (list "【顶点】" laynm (strcat "起始宽度:" (rtos (gxl-dxf ent 40) 2 0))                                         (strcat "结束宽度:" (rtos (gxl-dxf ent 41) 2 0))                                         (strcat "凸度:" (rtos (gxl-dxf ent 42) 2 1))        ))      )      ((= name "XLINE")        (setq lst (list "【构造线】" laynm))      )      (T        (setq lst (list "【未知对象】" laynm))      )    )    (apply 'strcat (mapcar '(lambda (x)(strcat x "\n")) lst))  ) (if (setq ent (nentselp pt)            ent (if (and ent (= (type (last (last ent))) 'ename))                  (last (last ent))                  (car ent)                )      )  (dis ent)   ))(defun c:DynInfo  (/ loaded openview closeview)  (defun openview  (/ arxs)    (VL-ACAD-DEFUN 'InfoCallBak)    (if (null mjdw)      (progn (INITget 7 "Yes No  ") (setq Mjdw (getKword "\n以毫米为单位?[<Yes/No>]<No>:")) (if (= mjdw "Yes")   (setq mjdw 1000)   (setq mjdw 999) )      )    )    (HFB_PointMonitor)    (HFB_PointMonitor "InfoCallBak")    (princ "\n动态信息查看打开!")    (setq *dynViewEnt* t)    )  (defun closeview  ()    (HFB_PointMonitor)    (princ "\n动态信息查看关闭!")    (setq *dynViewEnt* nil)    )  (cond ((= 16 (atoi (getvar 'acadver)))  (if (not (member "dynarxfor2004-2006.arx" (arx)))    (if (setq fn (findfile "dynarxfor2004-2006.arx"))      (setq loaded (arxload fn "1"))      (setq loaded "2")      )    (setq loaded "3") ;_ 已加载    )  ) ((= 17 (atoi (getvar 'acadver)))  (if (not (member "dynarxfor2007-2009.arx" (arx)))    (if (setq fn (findfile "dynarxfor2007-2009.arx"))      (setq loaded (arxload fn "1"))      (setq loaded "2")      )    (setq loaded "3")    )  ) ((= 18 (atoi (getvar 'acadver)))  (if (= "x86" (getenv "ROCESSOR_ARCHITECTURE"))    (if (not (member "dynarxfor2010-2012x32.arx" (arx)))      (if (setq fn (findfile "dynarxfor2010-2012x32.arx"))        (setq loaded (arxload fn "1"))        (setq loaded "2")        )      (setq loaded "3")      )    (if (not (member "dynarxfor2010-2012x64.arx" (arx)))      (if (setq fn (findfile "dynarxfor2010-2012x64.arx"))        (setq loaded        (arxload (findfile "dynarxfor2010-2012x64.arx")          "1"))        (setq loaded "2")        )      (setq loaded "3")      )    )  ) (t (setq loaded "2")) )  (if (not (or (= "1" loaded) (= "2" loaded)))    (if *dynViewEnt* (closeview) (openview) )    )  (princ)  )
GMT+8, 2026-1-19 14:59 , Processed in 0.161972 second(s), 19 queries , Gzip On.
