楼主: alexmai
[源码] 请大家修改一下这个非常好用的对齐工具
发表于 2019-3-9 22:09:29 | 显示全部楼层
start4444 发表于 2019-3-9 21:29
自己选肯定可以实现,就不算批量了,操作慢
谢谢解答!!
发表于 2019-3-10 10:34:29 | 显示全部楼层
不错的帖子顶一下
发表于 2019-3-10 20:22:42 | 显示全部楼层
start4444 发表于 2019-3-9 21:36
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=178718
参考这里,如果图框是块就好办,求得外框 ...
谢谢帮忙,可惜图框不是块,是一般的矩形
发表于 2019-9-9 15:03:36 | 显示全部楼层
start4444 发表于 2019-3-8 17:03
在原代码上单独修改了横向对齐,如果要合并就用if函数搞一下就行了
(defun c:dq (/ selobjs oldcmdecho)
  (setq oldcmdecho (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq selobjs (ssget))
  (if (or (not selobjs) (= (sslength selobjs) 1))
    (princ "\n你必须选定两个或两个以上的对象")
    (process selobjs)
  (setvar "cmdecho" oldcmdecho)
(defun process (selobjs          /            amode     apnt        apnt_x
                apnt_y          count            objname   vlaxobj        MinPoint
                MaxPoint  minext   maxext   ext_l        ext_r
                ext_m          tpnt
  (initget "L M R")
  (setq        amode (getkword
                "\n选择对齐方式[左对齐(L)/对中(M)/右对齐(R)]<左对齐>:"
  (if (not amode)
    (setq amode "L")
  (initget 1)
  (setq apnt (getpoint "\n选择水平对齐方向的对齐点:"))
  (setq        apnt_x (car apnt)
        apnt_y (cadr apnt)
  (vl-load-com)
  (setq count 0)
  (repeat (sslength selobjs)
    (setq objname (ssname selobjs count))
    (setq vlaxobj (vlax-ename->vla-object objname))
    (setq MinPoint (vlax-make-variant))
    (setq MaxPoint (vlax-make-variant))
    (vla-GetBoundingBox vlaxobj 'MinPoint 'MaxPoint)
    (setq minext (vlax-safearray->list MinPoint))
    (setq maxext (vlax-safearray->list MaxPoint))
    (setq ext_l (car minext))
    (setq ext_r (car maxext))
    (setq ext_m (+ (/ (abs (- ext_l ext_r)) 2) ext_l))
    (cond
      ((= amode "L")
       (setq tpnt (list ext_l apnt_y))
      ((= amode "M")
       (setq tpnt (list ext_m apnt_y))
      ((= amode "R")
       (setq tpnt (list ext_r apnt_y))
    (if        tpnt
      (command "_move" objname "" "non" tpnt "non" apnt)
    (setq count (1+ count))
(defun c:tt5 (/ selobjs oldcmdecho)
    (process selobjs)
                ext_m          tpnt
  (initget "D M S")
                "\n选择对齐方式[底对齐(D)/对中(M)/顶对齐(S)]<底对齐>:"
  (if (not amode)
    (setq amode "D")
  (initget 1)
  (setq apnt (getpoint "\n选择对齐点:"))
               apnt_y (cadr apnt)
  (vl-load-com)
  (setq count 0)
    (setq ext_l (cadr minext))
    (setq ext_r (cadr maxext))
    (cond
      ((= amode "D")
       (setq tpnt (list apnt_x ext_l))
      ((= amode "M")
       (setq tpnt (list apnt_x ext_m))
      ((= amode "S")
       (setq tpnt (list apnt_x ext_r))
    (if        tpnt
请问这两个程序放一起怎么只运行了Y轴的,X轴的运行读不出来什么原因呢,能不能把这两个轴的并合出一套完善的程序呢
发表于 2019-9-10 17:02:19 | 显示全部楼层
mark一下,感谢大佬分享
发表于 2019-9-10 23:24:28 | 显示全部楼层
如果是散的对象,想对齐,就是选择集对齐,论坛里也有的
 楼主| 发表于 2019-11-5 10:47:57 | 显示全部楼层
  (setvar "cmdecho" 0) ...
修改一下变量名称就可以合并
发表于 2019-12-11 20:18:18 | 显示全部楼层
alexmai 发表于 2019-11-5 10:47
修改一下变量名称就可以合并
用这个最实用了,什么对象都可以对齐
这代码是那个大师的我忘记了,我修改了一点点。
;;==============实体对齐=================
(defun process (amode / apnt apnt_x apnt_y count objname vlaxobj MinPoint MaxPoint
        minext maxext ext_l ext_r ext_m ext_vt ext_vd ext_vm tpnt)
        (initget 1)
                apnt_y (cadr apnt))
        (vl-load-com)
        (setq count 0)
                (setq ext_vd (cadr minext))
                (setq ext_vt (cadr maxext))
                (setq ext_vm (+ (/ (abs (- ext_vt ext_vd)) 2) ext_vd))
                (cond
                        ((= amode "HL") (setq tpnt (list ext_l apnt_y)))
                        ((= amode "HM") (setq tpnt (list ext_m apnt_y)))
                        ((= amode "HR") (setq tpnt (list ext_r apnt_y)))
                        ((= amode "VT") (setq tpnt (list apnt_x ext_vt)))
                        ((= amode "VM") (setq tpnt (list apnt_x ext_vm)))
                        ((= amode "VD") (setq tpnt (list apnt_x ext_vd)))
                (if tpnt (command "_move" objname "" "non" tpnt "non" apnt))
(defun c:ad ()
        (if (> (setq dcl_id (load_dialog (setq Dcl_File (Write_Dcl_dq)))) 0)
                        (vl-file-delete Dcl_File);加载后删除DCL文件
                        (if (new_dialog "dq" dcl_id "")
                                        (action_tile "hl" "(done_dialog 1)")
                                        (action_tile "hm" "(done_dialog 2)")
                                        (action_tile "hr" "(done_dialog 3)")
                                        (action_tile "vt" "(done_dialog 4)")
                                        (action_tile "vm" "(done_dialog 5)")
                                        (action_tile "vd" "(done_dialog 6)")
                                        (action_tile "cancel" "(done_dialog 0)")
                                        (setq re (start_dialog))
                                (princ "\n无法显示对话框!")
                        (unload_dialog dcl_id)
                (princ "\n无法加载对话框!")
        (cond
                ((= re 1) (process "HL"))
                ((= re 2) (process "HM"))
                ((= re 3) (process "HR"))
                ((= re 4) (process "VT"))
                ((= re 5) (process "VM"))
                ((= re 6) (process "VD"))
(defun Write_Dcl_dq(/ Dcl_File file str)
        (setq Dcl_File (vl-filename-mktemp nil nil ".Dcl"))
        (setq file (open Dcl_File "w"))
        (foreach str '(
        "dq:dialog{"
        " label=\"实体对齐\";"
        " :row{"
        "  :button{label=\" 左对齐x轴 \";key=\"hl\";width=13;height=2.5;allow_accept=true;}"
        "  :button{label=\"水平居中x轴\";key=\"hm\";width=13;height=2.5;allow_accept=true;}"
        "  :button{label=\" 右对齐x轴 \";key=\"hr\";width=13;height=2.5;allow_accept=true;}"
        " :row{"
        "  :button{label=\" 上对齐y轴 \";key=\"vt\";width=13;height=2.5;allow_accept=true;}"
        "  :button{label=\"垂直居中y轴\";key=\"vm\";width=13;height=2.5;allow_accept=true;}"
        "  :button{label=\" 下对齐y轴 \";key=\"vd\";width=13;height=2.5;allow_accept=true;}"
        "  :button{label=\" 关闭 \";key=\"cancel\";width=13;height=2.2;is_cancel=true;fixed_width=true;alignment=centered;}"
        (write-line str file)
        (close file)
        Dcl_File
回复 支持 2 反对 0
 楼主| 发表于 2019-12-13 16:26:38 | 显示全部楼层
KO你 发表于 2019-12-11 20:18
用这个最实用了,什么对象都可以对齐
确实比我的更直观,便捷
GMT+8, 2026-1-13 11:36 , Processed in 0.175341 second(s), 19 queries , Gzip On.
