查看: 1680|回复: 1
[讨论] 一个画角钢的程序求修改一下
发表于 2019-5-17 08:58:34 | 显示全部楼层 |阅读模式
5明经币
  拼了一个联想画角钢(线变角钢)的lisp,希望增加一个点选偏移方向的功能,同时在角钢的断点及转角出,插入焊缝块。
(defun c:hjg()  ;线变角钢、连续画角钢
  (vl-load-com)
  (command "layer" "m" "JT2_钢结构--钢结构梁---GJGL" "c" "4" "" "lw" "0.13" "" "l" "Continuous" "" "")
  (command "layer" "m" "JT3_型材--钢投影----JD" "c" "140" "" "lw" "0.13" "" "l" "Continuous" "" "")
;(command "layer" "s" "JT2_钢结构--中心线---GJGL" "")
  (princ "\n线变角钢、连续画角钢")
  (setq os (getvar 'osmode))
  (setq cmd (getvar 'cmdecho))
  (mapcar 'setvar (list 'osmode 'cmdecho) '(0 0))
  (or (setq w (getreal "\n【角钢宽度】/<50.0>:"))
      (setq w 50.0)
  (while (or (setq enpline (car(entsel"\n拾取角钢基线,回车则画线角钢:")))
       (and (setq pt1 (getpoint"\n开始绘制角钢的起点/<退出>."))
      (setq pt2 (getpoint pt1 "\n开始绘制角钢的第2点/<退出>."))
        (setq L-en (entlast));先设置最后一次的图元为L-en
        (princ "\n继续绘制角钢,回车结束角钢.")
        (command "_.pline" "_non" pt1 pt2)
        (while (>(getvar 'cmdactive)0)(command pause))
        (setq enpline (entnext L-en))
        );end progn
      );end and
       );end or
          (command "change" enpline  "" "p" "LA" "JT3_型材--钢投影----JD" "" )
         (setvar 'osmode 0)
          (vla-Offset (vlax-ename->vla-object enpline) (/ w 1.0))
         (setq pline1 (entlast))
         (command "change" pline1  "" "p" "LA" "JT2_钢结构--钢结构梁---GJGL" "" )
         (vla-Offset (vlax-ename->vla-object enpline) (/ w 10.0))
         (setq pline2 (entlast))
         (command "change" pline2  "" "P" "la" "JT2_钢结构--钢结构梁---GJGL" "" )
         (command "chprop" pline2 "" "lt" "DASHED" "s" "1" "c" "40" "")
;       (command "change" pline2  "" "lt" "DASHED" "s" "2" "c" "252" "")
(mapcar 'setvar (list 'osmode 'cmdecho) (list os cmd))
要求及焊缝块见附件
附件: 您需要 登录 才可以下载或查看,没有账号?注册
发表于 2021-9-30 16:12:00 | 显示全部楼层
顶一下。。
GMT+8, 2026-1-5 09:43 , Processed in 0.171532 second(s), 23 queries , Gzip On.
