查看: 2396|回复: 5
[源码] Visual LISP练习--文字标注面积
发表于 2019-8-22 22:40:02 | 显示全部楼层 |阅读模式
(defun c:bb (/ th ss obj pt pt2 textobj)
(vl-load-com)(setq th (getreal "\n必强提示:字高<100>:"))(if (not th)(setq th 100))(setq ss (ssget '((0 . "HATCH")))i -1)
(if ss(progn(repeat (sslength ss)(setq obj (vlax-ename->vla-object (ssname ss (setq i (1+ i)))))
(vla-GetBoundingBox obj 'minpt 'maxpt)(setq pt(mapcar '(lambda (x) (/ x 2.0))(mapcar '+
(vlax-safearray->list minpt)(vlax-safearray->list maxpt)))pt2 (vlax-make-safearray vlax-vbDouble '(0 . 2))
textobj(vla-addtext  (vla-get-Modelspace (vla-get-activeDocument (vlax-get-acad-object)))
(strcat "S" (itoa i) "=" (rtos (/ (vla-get-area obj) 1000000) 2 3) "㎡")(vlax-3d-point pt) th)) (vlax-safearray-fill pt2 pt)
(vla-put-Alignment textobj 10)(vla-put-TextAlignmentPoint textobj pt2))))(princ))
发表于 2019-8-23 09:12:19 | 显示全部楼层
字高能鼠标量取最好
发表于 2019-8-23 09:20:14 | 显示全部楼层
bai2000 发表于 2019-8-23 09:12
字高能鼠标量取最好
  1. [code=lisp](defun c:bb (/ th ss obj pt pt2 textobj)
  2.   (vl-load-com)
  3.   (setq th (getdist "\n字高<100>:"))
  4.   (if (not th)
  5.     (setq th 100)
  6.   )
  7.   (setq        ss (ssget '((0 . "HATCH")))
  8.         i  -1
  9.   )
  10.   (if ss
  11.     (progn
  12.       (repeat (sslength ss)
  13.         (setq obj (vlax-ename->vla-object (ssname ss (setq i (1+ i)))))
  14.         (vla-GetBoundingBox obj 'minpt 'maxpt)
  15.         (setq pt      (mapcar '(lambda (x) (/ x 2.0))
  16.                               (mapcar '+
  17.                                       (vlax-safearray->list minpt)
  18.                                       (vlax-safearray->list maxpt)
  19.                               )
  20.                       )
  21.               pt2     (vlax-make-safearray vlax-vbDouble '(0 . 2))
  22.               textobj (vla-addtext
  23.                         (vla-get-Modelspace
  24.                           (vla-get-activeDocument (vlax-get-acad-object))
  25.                         )
  26.                         (strcat        "S"
  27.                                 (itoa i)
  28.                                 "="
  29.                                 (rtos (/ (vla-get-area obj) 1000000) 2 3)
  30.                                 "㎡"
  31.                         )
  32.                         (vlax-3d-point pt)
  33.                         th
  34.                       )
  35.         )
  36.         (vlax-safearray-fill pt2 pt)
  37.         (vla-put-Alignment textobj 10)
  38.         (vla-put-TextAlignmentPoint textobj pt2)
  39.       )
  40.     )
  41.   )
  42.   (princ)
  43. )
[/code]
 楼主| 发表于 2019-8-23 22:26:37 | 显示全部楼层
字高能鼠标量取最好
2006年入门的你,getreal和getdist都没搞懂?
发表于 2019-12-17 09:29:20 | 显示全部楼层
支持一下虽然2020用不了!
GMT+8, 2026-1-5 09:42 , Processed in 0.165603 second(s), 26 queries , Gzip On.
