查看: 990|回复: 0
[源码] 100% Pure Full Screen Tool for AutoCAD for mac
发表于 2020-4-26 16:30:38 | 显示全部楼层 |阅读模式
此 AutoLISP 源代码由 kedora编写,软件许可授权为 GPL v2。
  1. ;; 100% Pure Full Screen Tool for AutoCAD for mac
  2. ;; Coder: kedora
  3. ;; License and Copyright: GPL v2
  4. ;; Rev:
  5. ;;         R0.0.1:      2020/04/23:     First version
  6. ;;         R0.0.2:      2020/04/26:     Optimized internal routine.
  7. (defun C:lkpt_ui_FullScreenSwitcher (/
  8.                                      _lkpt_ui_FullScreenExit
  9.                                      _lkpt_ui_fullscreen
  10.
  11.                                      sRegLocation lKeys)
  12.   (defun _lkpt_ui_FullScreenExit (sRegLocation lKeys / oldvar sKey)
  13.     (setq oldvar (getvar "CMDECHO"))
  14.     (setvar "CMDECHO" 0)
  15.     (vl-cmdf "_.undo" "_be")
  16.     (foreach sKey lKeys
  17.       (if (= sKey "DYNMODE")
  18.         (setvar "DYNMODE" (vl-registry-read sRegLocation sKey))
  19.         (vl-cmdf (vl-registry-read sRegLocation sKey))
  20.       );_fi
  21.       (vl-registry-delete sRegLocation sKey)
  22.     );_for
  23.     (vl-cmdf "_.fullscreen")
  24.     (vl-cmdf "_.undo" "_e")
  25.     (setvar "CMDECHO" oldvar)
  26.     (princ)
  27.   )
  28.   (defun _lkpt_ui_FullScreen (sRegLocation / lOpeningUiParts lUiParts oldvar1 oldvar2 i sItem)
  29.     (setq lOpeningUiParts '()
  30.           lUiParts '( ("TOOLBARSTATE" "_.toolbar" "_.toolbarclose")
  31.                       ("FILETABSTATE" "_.filetab" "_.filetabclose")
  32.                       ("STATUSBARSTATE" "_.statusbar" "_.statusbarclose")
  33.                       ("COMMANDWINDOWSTATE" "_.commandline" "_.commandlinehide")
  34.                     )
  35.           oldvar1 (getvar "CMDECHO")
  36.           oldvar2 (getvar "DYNMODE")
  37.     )
  38.     (vl-registry-write sRegLocation "DYNMODE" oldvar2)
  39.     (setvar "CMDECHO" 0)
  40.     (vl-cmdf "_.undo" "_be")
  41.     (cond
  42.       ( (= oldvar2 0) (setvar "DYNMODE" 3) )
  43.       ( (< oldvar2 0) (setvar "DYNMODE" (abs oldvar2)) )
  44.     );_cond
  45.     (vl-cmdf "_.fullscreen")
  46.     (mapcar (function (lambda (x) (if (= (getvar (car x)) 1)
  47.                                     (progn
  48.                                       (setq lOpeningUiParts (cons (cadr x) lOpeningUiParts))
  49.                                       (vl-cmdf (caddr x))
  50.                                     )
  51.                                   );_fi
  52.                       )
  53.             )
  54.             lUiParts
  55.     );_map
  56.     (setq lOpeningUiParts (cons "_.showpalettes" lOpeningUiParts))
  57.     (vl-cmdf "_.hidepalettes")
  58.     (setq i -1)
  59.     (foreach sItem lOpeningUiParts
  60.       (vl-registry-write sRegLocation
  61.                          (strcat "UI_Status_" (itoa (setq i (1+ i))))
  62.                          sItem
  63.       )
  64.     );_for
  65.     (vl-cmdf "_.undo" "_e")
  66.     (setvar "CMDECHO" oldvar1)
  67.     (princ)
  68.   );_defun
  69.   ;;==========   main   ==========
  70.   (setq sRegLocation "HKEY_CURRENT_USER\\Software\\Lkcadway\\LKPT")
  71.   (if (setq lKeys (vl-registry-descendents sRegLocation "*"))
  72.     (_lkpt_ui_FullScreenExit sRegLocation lKeys)
  73.     (_lkpt_ui_Fullscreen sRegLocation)
  74.   );_fi
  75.   (princ)
  76. );_defun
GMT+8, 2026-1-5 09:16 , Processed in 0.178533 second(s), 27 queries , Gzip On.
