楼主: 李青松
[提问] 组合命令f 在autocad2012中运行不了,2004,2005.2006中可以运行。
发表于 2020-6-29 12:13:54 | 显示全部楼层
李青松 发表于 2020-6-29 11:57
我觉得是以下的这个程序要重新写,写成先选对象再运行程序。
(defun c:tcrb() (command "change" (ssget ...
(defun C:ttt (/ ss)
          (setvar "cmdecho" 0)
  (if(= (tblsearch "layer" "软包") nil)(command "-layer" "n" "软包" "s" "软包" "")(command "-layer" "s" "软包" ""))
(setq ss (ssget "i"))
  (if (= ss nil)
  (c:tcrb)
  (c:ff2))
         (princ))
(defun c:tcrb()
        (command "change" (ssget) "" "p"     "la" "软包" "c" "bylayer" "lt" "bylayer" "")        (princ))
(defun c:ff2 ()
        (setvar "CLAYER" "0") ;设置0层为当前图层
        (command  "OSMODE" "4159" "ortho" "on" "line" )
发表于 2020-6-29 12:14:18 | 显示全部楼层
  1. (defun C:ttt (/ ss)
  2.     (setvar "cmdecho" 0)
  3.   (if(= (tblsearch "layer" "软包") nil)(command "-layer" "n" "软包" "s" "软包" "")(command "-layer" "s" "软包" ""))
  4. (setq ss (ssget "i"))
  5.   (if (= ss nil)
  6.   (c:tcrb)
  7.   (c:ff2)) (setvar "CLAYER" "0");设置0层为当前图层
  8. (princ))
  9. (defun c:tcrb()
  10.   (command "change" (ssget) "" "p"     "la" "软包" "c" "bylayer" "lt" "bylayer" "")  (princ))
  11. (defun c:ff2 ()
  12.   (setvar "CLAYER" "0") ;设置0层为当前图层
  13.   (command  "OSMODE" "4159" "ortho" "on" "line" )
  14.   (princ)
  15. )
最新修改
画直线的命令失效。  发表于 2020-7-1 14:01
 楼主| 发表于 2020-6-29 13:51:01 | 显示全部楼层
经测试,图层还是变了。运行完后当前的图层不是0层。
 楼主| 发表于 2020-7-1 13:59:21 | 显示全部楼层
画直线的命令失效。
发表于 2020-7-1 14:29:34 | 显示全部楼层
李青松 发表于 2020-7-1 13:59
画直线的命令失效。
请你自己找问题    2010  2012  2020  都有测试没有问题  最按后修改的代码
经测试cad2005上不能用  发表于 2020-7-6 11:49
GMT+8, 2026-1-18 07:52 , Processed in 0.253969 second(s), 23 queries , Gzip On.
