楼主: magicheno
[提问] 不用command语句该如何表达
发表于 2020-8-10 09:55:21 | 显示全部楼层
magicheno 发表于 2020-8-9 01:13
(defun c:TT5() (try-Layer-off '("WP_G""WP_G_DN")))
(defun try-Layer-off (layList))
        (se ...
复制都复制错
(setq
        ;;常用VLA对象、集合
        *ACAD*  (vlax-get-acad-object)
        *DOC*   (vla-get-ActiveDocument *ACAD*)
        *DOCS*  (vla-get-Documents *ACAD*)
        *MS*    (vla-get-modelSpace *DOC*)
        *PS*    (vla-get-paperSpace *DOC*)
        *BLKS*  (vla-get-Blocks *DOC*)
        *LAYS*  (vla-get-Layers *DOC*)
        *LTS*   (vla-get-Linetypes *DOC*)
        *STS*   (vla-get-TextStyles *DOC*)
        *GRPS*  (vla-get-groups *DOC*)
        *DIMS*  (vla-get-DimStyles *DOC*)
        *LOUTS* (vla-get-Layouts *DOC*)
        *VPS*   (vla-get-Viewports *DOC*)
        *VS*    (vla-get-Views *DOC*)
        *DICS*  (vla-get-Dictionaries *DOC*)
        *Layouts* (vla-get-Layouts *doc*)
(defun try-Layer-Off (LayList)
        (setq LayList(mapcar 'strcase LayList))
        (vlax-for each *LAYS*
                (if (member (strcase (vla-get-name each)) LayList)
                        (if (vlax-write-enabled-p each)
                                (vla-put-LayerOn each :vlax-False)
                (vlax-release-object each)
(defun c:tt5 ()
 楼主| 发表于 2020-8-10 11:33:20 | 显示全部楼层
tryhi 发表于 2020-8-10 09:55
复制都复制错
(setq
感谢大侠原来如此,没把集合放进去,这种不能用*通用符号的,是不是只能一个一个输入图层的,图层是比较多的都是类似的,某一类的图层,比如WP_G_DN,WP_G_EV,WP_G_PJ,WP_G_NOTE,WP_G_LG,WP_G_TXT,等等图层的
发表于 2020-8-10 15:34:43 | 显示全部楼层
magicheno 发表于 2020-8-10 11:33
感谢大侠原来如此,没把集合放进去,这种不能用*通用符号的,是不是只能一个一个输入图层的,图层 ...
(try-Layer-Off(vl-remove-if-not '(lambda(x)(wcmatch x "WP_G*"))(try-Layer-allname)))
 楼主| 发表于 2020-8-10 16:53:43 | 显示全部楼层
感谢大侠,原来如此,懂了一点点,这样子就可以实现我发的command那样的效果了,其他类似不同的图层的也只需要增加 try-Layer-Off  try-Layer-on命令就可以了
(setq
        ;;常用VLA对象、集合
;;返回所有图层的名称(字符串表)
(defun try-Layer-allname(/ out)
        (vlax-for obj *LAYS*
                (setq out (cons (vlax-get-property obj 'Name) out))
        (reverse out)
;;打开关闭图层
;;参数:图层名称表
(defun try-Layer-On (LayList)
                                (vla-put-LayerOn each :vlax-True)
(defun c:tt5 ()
        (try-Layer-Off(vl-remove-if-not '(lambda(x)(wcmatch x "*"))(try-Layer-allname)))
        (try-Layer-on(vl-remove-if-not '(lambda(x)(wcmatch x "WP_G*"))(try-Layer-allname)))
(defun c:tt6 ()
(defun c:tt7 ()
发表于 2020-8-10 17:36:55 | 显示全部楼层
magicheno 发表于 2020-8-10 16:53
感谢大侠,原来如此,懂了一点点,这样子就可以实现我发的command那样的效果了,其他类似不同的图层的也 ...
;;打开关闭图层
;;参数:字符串,支持通配符
(defun try-Layer-on-2 (layer)
         (try-Layer-on(vl-remove-if-not '(lambda(x)(wcmatch x layer))(try-Layer-allname)))
;;打开关闭图层
;;参数:字符串,支持通配符
(defun try-Layer-off-2 (layer)
         (try-Layer-off(vl-remove-if-not '(lambda(x)(wcmatch x layer))(try-Layer-allname)))
(try-Layer-on-2 "WP_G*");打开P_G开头的图层
(try-Layer-on-2 "WP_G_DN,WP_G_EV,WP_G_PJ,WP_G_NOTE,WP_G_LG,WP_G_TXT");打开WP_G_DN,WP_G_EV,WP_G_PJ,WP_G_NOTE,WP_G_LG,WP_G_TXT这6个图层
关闭图层不做举例
 楼主| 发表于 2020-8-10 17:57:14 | 显示全部楼层
tryhi 发表于 2020-8-10 17:36
;;打开关闭图层
;;参数:字符串,支持通配符
感谢大侠,相当于设定了指定函数,后面只要加开关就行了,更简化了
 楼主| 发表于 2020-8-10 21:05:24 | 显示全部楼层
;;打开关闭图层
;;参数:字符串,支持通配符
大侠按照新的要求改了下,运行不了,不知道是哪里的问题呢
(setq
        ;;常用VLA对象、集合
;;返回所有图层的名称(字符串表)
        (reverse out)
;打开图层
;;参数:图层名称表
;;关闭图层
;;参数:图层名称表
;;打开关闭图层
;;参数:字符串,支持通配符
;;打开关闭图层
;;参数:字符串,支持通配符
;;;打开给水图层
(defun c:tt5 ()
      (try-Layer-off-2 "*")
      (try-Layer-on-2 "WP_G,DN_G,LGBH_G,TXT_G,EV_G,WP_G_*")
;;;关闭给水图层
(defun c:tt7 ()
      (try-Layer-off-2 "WP_G,DN_G,LGBH_G,TXT_G,EV_G,WP_G_*")
;;;可开给水层
(defun c:tt6 ()
;; 关其他水层仅显示给水层
(defun c:tt8 ()
      (try-Layer-off-2 "WP_*,DN_*,LGBH_*,TXT_*,EV_*,W-DIM,W_DIM,WW_*,WX-*,SB,SB_*,PUB_W-DIM,PUB_TABLE,PUB_W-DIM")
发表于 2020-8-10 23:32:35 | 显示全部楼层
(setq
        ;;常用VLA对象、集合
一对全角括号,怀疑你平时程序怎么写出来的
 楼主| 发表于 2020-8-11 01:12:22 | 显示全部楼层
一直都没注意这个,只会一点皮毛,没怎么真正写过程序,之前修修改改一些command,没怎么出现这种问题的,我就纳闷了,原来打括号的时候打成中文括号了,尴尬了,感谢大侠指教的按你的函数这样写,比之前command简化太多了,我要把之前用command设定的命令全部简化一遍的,行数可以少太多了
GMT+8, 2026-1-18 04:34 , Processed in 0.378683 second(s), 19 queries , Gzip On.
