查看: 1168|回复: 3
[讨论] 插入块,先按比例缩放,再指定插入点.可以实现吗?
发表于 2020-10-19 22:52:07 | 显示全部楼层 |阅读模式
20明经币
在插入块时,利用"DIMSCALE"来进行缩放,但是在指定插入点之前图块不能先预览缩放的效果。
有什么方法可以让"pause"在缩放后,再指定插入点呢?
(defun c:av ( / DS )
  (command "undo" "be")
  (SetQ DS (GETVAR "DIMSCALE"))
  (command "insert" "note" pause DS DS 0)
  (command "explode" (entlast))
  (command "undo" "end")
最佳答案
查看完整内容
纯命令,凑合用吧 (defun c:tt5 (/ DS) (command "undo" "be") (SetQ DS (GETVAR "DIMSCALE")) (command "insert" "note" '(0 0) DS DS 0 "copybase" "non" '(0 0) (entlast) "" "ERASE" (entlast) "" "PASTECLIP" pause) (command "explode" (entlast)) (command "undo" "end") (princ) )
发表于 2020-10-19 22:52:08 | 显示全部楼层
纯命令,凑合用吧
(defun c:tt5 (/ DS)
高手  发表于 2020-11-9 21:37
xvjiex + 1 CAD基础扎实
 楼主| 发表于 2020-10-20 09:58:04 | 显示全部楼层
谢谢!几个都认识,就没想到哦
GMT+8, 2025-6-26 04:48 , Processed in 0.174312 second(s), 28 queries , Gzip On.
