查看: 881|回复: 2
[提问] 如何用lisp合并有公共边的多边形(多边形可能为不闭合多段线或二维多段线画的)
发表于 2021-4-17 13:04:15 | 显示全部楼层 |阅读模式
如何用lisp合并有公共边的多边形(多边形可能为不闭合多段线或二维多段线画的)?
发表于 2021-4-17 18:41:27 | 显示全部楼层
转面域 再合并 再生成边界
发表于 2021-4-17 22:30:40 | 显示全部楼层
使用Lee Mac的outline
   http://www.theswamp.org/index.php?topic=48031.msg573108#msg573108
   Lee Mac
   Re: Create boundary (polyline) around selected objects
   << Reply #33 on: November 26, 2014, 06:24:28 PM >>
(defun c:outline ( / sel )
    (vl-load-com)
    (if (setq sel (ssget))
        (sssetfirst nil (LM:outline sel))
;; Object Outline  -  Lee Mac
;; Attempts to generate a polyline outlining the selected objects.
;; sel - [sel] Selection Set to outline
(defun LM:outline ( sel / app are box cmd dis enl ent lst obj rtn tmp )
    (setq app (vlax-get-acad-object)
          box (LM:ssboundingbox sel)
          dis (/ (apply 'distance box) 20.0)
          lst (mapcar '(lambda ( a o ) (mapcar o a (list dis dis))) box '(- +))
          are (apply '* (apply 'mapcar (cons '- (reverse lst))))
          dis (* dis 1.5)
          ent
        (entmakex
            (append
               '(   (000 . "LWPOLYLINE")
                    (100 . "AcDbEntity")
                    (100 . "AcDbPolyline")
                    (090 . 4)
                    (070 . 1)
                (mapcar '(lambda ( x ) (cons 10 (mapcar '(lambda ( y ) ((eval y) lst)) x)))
                   '(   (caar   cadar)
                        (caadr  cadar)
                        (caadr cadadr)
                        (caar  cadadr)
    (apply 'vlax-invoke
        (vl-list* app 'zoomwindow
            (mapcar '(lambda ( a o ) (mapcar o a (list dis dis 0.0))) box '(- +))
    (setq cmd (getvar 'cmdecho)
          enl (entlast)
          rtn (ssadd)
    (while (setq tmp (entnext enl)) (setq enl tmp))
    (setvar 'cmdecho 0)
    (command
        "_.-boundary" "_a" "_b" "_n" sel ent "" "_i" "_y" "_o" "_p" "" "_non"
        (trans (mapcar '- (car box) (list (/ dis 3.0) (/ dis 3.0))) 0 1) ""
    (while (< 0 (getvar 'cmdactive)) (command ""))
    (entdel ent)
    (while (setq enl (entnext enl))
        (if (and (vlax-property-available-p (setq obj (vlax-ename->vla-object enl)) 'area)
                 (equal (vla-get-area obj) are 1e-4)
            (entdel enl)
            (ssadd  enl rtn)
    (vla-zoomprevious app)
    (setvar 'cmdecho cmd)
    rtn
;; Selection Set Bounding Box  -  Lee Mac
;; Returns a list of the lower-left and upper-right WCS coordinates of a
;; rectangular frame bounding all objects in a supplied selection set.
;; s - [sel] Selection set for which to return bounding box
(defun LM:ssboundingbox ( s / a b i m n o )
    (repeat (setq i (sslength s))
        (if
            (and
                (setq o (vlax-ename->vla-object (ssname s (setq i (1- i)))))
                (vlax-method-applicable-p o 'getboundingbox)
                (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list o 'a 'b))))
            (setq m (cons (vlax-safearray->list a) m)
                  n (cons (vlax-safearray->list b) n)
    (if (and m n)
        (mapcar '(lambda ( a b ) (apply 'mapcar (cons a b))) '(min max) (list m n))
GMT+8, 2025-7-6 12:12 , Processed in 0.178344 second(s), 27 queries , Gzip On.
