查看: 2093|回复: 8
[函数] 求点绕两点形成的轴旋转一角度之后坐标
发表于 2021-6-7 20:50:47 | 显示全部楼层 |阅读模式
函数名rotpt
参数
pt1 被旋转的三维点
pt2 pt3 两点轴
ang 弧度旋转角度
  1. <blockquote>(defun rotpt (pt1 pt2 pt3 ang / k axl pedpt vecped1 n f vecped2)
guosheyang + 1 很给力!
 楼主| 发表于 2021-6-8 01:55:01 | 显示全部楼层
于2021.6.8 2点修改
演示
(setq pt1 '(989 -2384 99) pt2 '(331 -1550 503) pt3 '(1142 -1970 0) ang (* 0.5 pi))
(rotpt pt1 pt2 pt3 (- ang))   》(902.398 -1973.19 -383.649)
 楼主| 发表于 2021-6-8 01:55:47 | 显示全部楼层
(defun rotpt (pt1 pt2 pt3 ang / k axl pedpt vecped1 an f vecped2 fnorm)
  (setq        k        (/ (apply '+
                          (mapcar '* (mapcar '- pt1 pt2) (mapcar '- pt3 pt2))
                   (apply '+
                          (mapcar '(lambda (x) (expt x 2)) (mapcar '- pt3 pt2))
        axl        (mapcar '- pt3 pt2)
        pedpt        (mapcar '+ pt2 (mapcar '* (list k k k) (mapcar '- pt3 pt2)))
        vecped1        (mapcar '- pt1 pedpt)
        an        -1
        f        (lambda        (x n)
                  (setq c -1)
                  (apply 'append
                         (mapcar '(lambda (a)
                                    (if        (/= (setq c (1+ c)) n)
                                      (list a)
        fnorm (lambda (x) (apply '+ (mapcar '* x x)))
        vecped2        (mapcar
                  '(lambda (x)
                     (apply
                       (mapcar '*
                               (list (cos ang) (sin ang) (- 1 (cos ang)))
                  (mapcar
                    '(lambda (x y)
                       (list
                         (if (= (setq an (1+ an)) 1)
                           (- (apply '-
                                     (mapcar '*
                                             (f axl an)
                                             (reverse (f vecped1 an))
                           (apply '-
                                  (mapcar '*
                                          (f axl an)
                         (* y (apply '+ (mapcar '* vecped1 axl)))
                    vecped1
                    axl
  (mapcar '+ (mapcar '(lambda (x) (* x (expt (/ (fnorm vecped1) (fnorm vecped2)) 0.5))) vecped2) pedpt)
USER2128 + 1 赞一个!
发表于 2021-6-8 07:02:22 | 显示全部楼层
  (setq        k        (/  ...
不错不错!现在正确了
发表于 2021-8-14 14:59:28 | 显示全部楼层
楼主的程序是有问题的,刚好要用到,因而花时间编了一个:
  1. ;;; 求点绕两点形成的轴旋转一角度之后坐标(lisp方式,适应3d,WCS及UCS)
  2. ;;; 原作者  HLCAD.
  3. ;ie:
  4. ;  (mapcar 'set '(ptx pt2 pt3)(list(getpoint"\n测点:")(getpoint"\n轴1:")(getpoint"\n轴2:")))
  5. ;  (HL:RotPt ptx pt2 pt3 (* pi(/ 133 180.0)))
  6. (defun HL:RotPt (ptx pt2 pt3 ang / PT1 PTV RTN RTN1 VVV VX VY X0 Y0)
  7.   (setq vvv (mapcar '- pt3 pt2))
  8.   (setq pt1 (mapcar '- ptx pt2))
  9.   (setq ptv (trans pt1 0 vvv))
  10.   (mapcar 'set '(Vx Vy) ptv)
  11.   (setq x0 (- (* Vx (cos ang)) (* Vy (sin ang))))
  12.   (setq y0 (+ (* Vx (sin ang)) (* Vy (cos ang))))
  13.   (mapcar '+ (trans (list x0 y0 (caddr ptv)) vvv 0) pt2)
  14.   )
发表于 2021-8-14 16:00:07 来自手机 | 显示全部楼层
感谢发现问题后分享,支持一下!
发表于 2021-8-14 20:51:43 | 显示全部楼层
好简洁的代码,牛!
发表于 2021-8-14 21:24:40 | 显示全部楼层
对头  递归哥的代码   在当旋转轴的两点 在wcs的xy平面,旋转点也在此平面时候会出错
       “”忽略倾斜、不按统一比例缩放的对象。
      忽略倾斜、不按统一比例缩放的对象。参数太多“”
 楼主| 发表于 2021-8-14 23:21:02 | 显示全部楼层
       “”忽略倾 ...
之前写的代码 有问题是吧 我看看
GMT+8, 2026-1-17 05:17 , Processed in 0.153877 second(s), 28 queries , Gzip On.
