查看: 1318|回复: 2
[提问] 删除
发表于 2021-12-23 20:48:32 | 显示全部楼层 |阅读模式
删除
发表于 2021-12-23 21:03:35 | 显示全部楼层
你好你是要获取文件目录吗?你用quicker试下https://getquicker.net/
发表于 2021-12-25 21:51:39 | 显示全部楼层
猜想楼主想读取多行多列的数据,不过还是觉得你理解的对,但要是这么简单的问题,楼主应该也会呀
(setq str(getclip))
(gxl-StrParse str "\r\n")
(defun gxl-StrParse (str del / pos lst)
   ;;;Command: (gxl-StrParse "9/10" "/")
;;;("9" "10") by gxl
    (while (setq pos (vl-string-search del str))
      (setq lst    (cons (substr str 1 pos) lst)
        str    (substr str (+ pos 1 (strlen del)))
    (if    (= " " Del)
      (vl-remove "" (reverse (cons str lst)))
GMT+8, 2026-1-3 05:10 , Processed in 0.143339 second(s), 25 queries , Gzip On.
