楼主: wanhongron
[提问] 多段线变多边形
发表于 2022-2-12 13:57:00 | 显示全部楼层
ml不好用
道路不止直线还有弧线段
 楼主| 发表于 2022-2-13 16:33:36 | 显示全部楼层
菜卷鱼大侠的思路很好,可是运行显示错误: no function definition: CMD0,麻烦能改成批量执行并能适应任何多段线
 楼主| 发表于 2022-2-13 16:36:57 | 显示全部楼层
烦问下夏大侠,偶尔执行还是会显示错误: 参数类型错误: numberp: nil,另外能否改成能批量执行
发表于 2022-2-13 20:38:51 | 显示全部楼层
;;线变矩形
(defun c:jx (/ ss l en sz i lp h a);定义命令
  (if (not $$)
    (setq $$ 1) ;设置默认数值
  (if (setq l (getdist (strcat "\n执行心心命令\n线变矩形\n请量取或输入矩形宽度:当前宽度:<" (rtos $$) ">\n")))
    (setq $$ l)(setq l $$))
  (princ "\n请选择对象:\n")
  (if (setq ss (ssget '((0 . "LWPOLYLINE,LINE,ARC"))))
    (progn (setvar "cmdecho" 0)
           (if (= 8 (logand (getvar "undoctl") 8))
             (command-s "_.UNDO" "e")
             (command-s "_.UNDO" "be"))
           (setq i 0)
           (repeat (sslength ss)
             (setq en (ssname ss i)
                   sz (ssadd)
                   i  (1+ i))
             (setq lp (mapcar
                        '(lambda (y)
                           (list (vlax-curve-getStartPoint y)
                                 (vlax-curve-getEndPoint y)))
                        (mapcar 'car
                                (mapcar
                                  '(lambda (x)
                                     (setq o (vlax-invoke (vlax-ename->vla-object en) 'Offset x))
                                     (ssadd (entlast) sz) o)
                                  (list (setq h (* 0.5 l)) (- h))))))
             (mapcar
               '(lambda (k l)
                  (entmakex (list (cons 0 "LINE") (cons 10 k) (cons 11 l)))
                  (ssadd (entlast) sz))
               (car lp)
               (cadr lp))(setvar 'PEDITACCEPT 1)
             (command-s "_.pedit" "m" sz "" "j" 0.0 ""))
           (if (not (setq p (getpoint "\n单击不删除源对象 <空格删除>\n")))
             (command-s "_.ERASE" ss ""))
           (if (= 8 (logand (getvar "undoctl") 8)) (command-s "_.UNDO" "e"))
           (setvar "cmdecho" 1)
           (princ "\n心心命令执行完毕\n!"))
    (progn (princ "\n未选择对象!\n")))
  (princ (menucmd "M=$(edtime,$(getvar,date),YYYY.MO.DD HH:MM DDDD )"))
  (princ))
 楼主| 发表于 2022-2-14 08:37:34 | 显示全部楼层
CXHYY大侠的程序非常完美,功能正是我想要的,非常感谢
 楼主| 发表于 2022-2-14 09:25:22 | 显示全部楼层
如果能把生成的多边形全部改为当前图层,区别原来的多段线图层就跟完美了,哪位侠能帮完美一下
发表于 2022-2-14 19:33:53 | 显示全部楼层
;;线变矩形
(defun c:jx (/ ss l en sz i lp h a la);定义命令
  (if (not $$)
    (setq $$ 1) ;设置默认数值
           (setq i 0)
                   sz (ssadd)
                   i  (1+ i))
             (setq lp (mapcar
                        '(lambda (y)
                        (mapcar 'car
                                (mapcar
                                  '(lambda (x)
             (mapcar
               '(lambda (k l)
               (car lp)
             (command-s "_.pedit" "m" sz "" "j" 0.0 "")(setq la (getvar "clayer"))
      (command-s "_.chprop" (entlast) "" "la" la ""))
  (princ))
 楼主| 发表于 2022-2-15 08:26:00 | 显示全部楼层
非常完美,做工效率高了很多,万分感谢热心cxhhyy大侠
发表于 2022-2-15 12:39:35 | 显示全部楼层
过奖过奖 我不会写代码的  我也是在明经找的代码
上面代码遇到编组开始的时候会对操作对象不编组 不能一步撤回 我修改了一下
;;线变矩形
  (if (not $$)
    (setq $$ 1) ;设置默认数值
             (progn (command-s "_.UNDO" "e") (command-s "_.UNDO" "be"))
           (setq i 0)
                   sz (ssadd)
                   i  (1+ i))
             (setq lp (mapcar
                        '(lambda (y)
                        (mapcar 'car
                                (mapcar
                                  '(lambda (x)
             (mapcar
               '(lambda (k l)
               (car lp)
  (princ))
GMT+8, 2026-1-16 18:40 , Processed in 0.200715 second(s), 20 queries , Gzip On.
