查看: 1292|回复: 1
[讨论] 哪位大侠帮忙简化一下刷多段属性的程序
发表于 2022-10-1 21:29:48 | 显示全部楼层 |阅读模式
如题,请大家帮忙简化,优化一下刷多段线特性的程序。谢谢
;;多义线专用特性匹配程序,可同时匹配图层、线型、线型比例、颜色及宽度。
(DEFUN C:XM ( / STXT SLEN I E_NT B E_NAME NEW_1 p_cen d_en vos ipl ela ew elt els ec xm_oe xm_err ec1)
(defun xm_err(s)
  (if (/= s "Function cancelled")
    (if (= s "quit / exit abort")
        (princ (strcat "\n错误: " s))
(if xm_oe (setq *error* xm_oe xm_oe nil))
(if new_1 (progn (redraw (car new_1) 4) (setq new_1 nil)))
(princ "用户取消了命令!")
   (SETVAR "CMDECHO" 0)
   (setq ipl nil)
;重新设置错误函数
(setq xm_oe *error* *error* xm_err)
   (PROMPT "\n多义线特性匹配程序,可匹配图层,颜色,线型,线型比例及宽度。")
   (PROMPT "\n---------------------------------------------------------")
   (while (not ipl)
    (SETQ NEW_1 (entsel "\n请选择多义线源对象:"))
    (if (/= new_1 nil) (progn
     (setq e_nt (entget (car new_1)) e_name (cdr (assoc 0 e_nt)))
     (if (= e_name "LWPOLYLINE") (progn (setq ipl T) (redraw (car new_1) 3)
       (setq ela (cdr (assoc 8 e_nt)) elt (cdr (assoc 6 e_nt)) els (cdr (assoc 48 e_nt)))
       (setq ew (cdr (assoc 40 e_nt)) ec (cdr (assoc 62 e_nt)))
     ));if
    ));if
   );while
(if (= elt nil) (setq elt "BYLAYER"))
(if (= els nil) (setq els 1))
(cond ((= ec 0) (setq ec "BYBLOCK" ec1 ec))
       ((or (= ec nil) (= ec 256)) (setq ec "BYLAYER" ec1 ec))
       ((= ec 1) (setq ec1 "红色"))
       ((= ec 2) (setq ec1 "黄色"))
       ((= ec 3) (setq ec1 "绿色"))
       ((= ec 4) (setq ec1 "青色"))
       ((= ec 5) (setq ec1 "蓝色"))
       ((= ec 6) (setq ec1 "紫色"))
       ((= ec 7) (setq ec1 "白色"))
       ((= ec 8) (setq ec1 "红色"))
       (T (setq ec1 (rtos ec 2 1)))
);cond
(prompt (strcat "\n源对象特性:图层=" ela ",线型=" elt ",线型比例=" (rtos els 2 2) ",颜色=" ec1 ",线宽=" (rtos ew 2 2) "。"))
   (PROMPT "\n请选择要匹配的目标(多义线,直线,圆或圆弧):")
   (SETQ STXT (SSGET))
   (if stxt (progn
   (command "undo" "group")
   (SETQ SLEN (SSLENGTH STXT) I 0 )
   (WHILE (SSNAME STXT I)
      (SETQ E_NT (SSNAME STXT I))
      (SETQ E_NAME (ENTGET E_NT))
      (SETQ B (CDR (ASSOC 0 E_NAME)))
      (COND ((or (= B "POLYLINE") (= B "LWPOLYLINE")) ;在R14中多义线名称为LWPOLYLINE;
              (COMMAND "PEDIT" E_NT "W" ew "")
              (command "change" e_nt "" "p" "C" ec "LA" ela "LT" elt "S" els "")
            ((= B "CIRCLE")
              (setq vos (getvar "osmode"))
              (command "osnap" "off")
              (SETQ P_CEN (CDR (ASSOC 10 E_NAME)))
              (SETQ D_EN (* (CDR (ASSOC 40 E_NAME)) 2.0))
              (COMMAND "DONUT" (- D_EN ew) (+ D_EN ew) P_CEN "")
              (ENTDEL E_NT)
              (command "change" "L" "" "p" "C" ec "LA" ela "LT" elt "S" els "")
              (setvar "osmode" vos)
            ((OR (= B "ARC") (= B "LINE"))
              (COMMAND "PEDIT" E_NT "Y" "W" ew "")
;;;              (COMMAND "PEDIT" E_NT "W" ew "")
      (SETQ I (1+ I))
  (command "undo" "end")
));if
(if xm_oe (setq *error* xm_oe))
(PRINC)
发表于 2022-10-1 22:15:06 | 显示全部楼层
为什么不用 MATCHPROP
GMT+8, 2026-1-16 04:20 , Processed in 0.152604 second(s), 25 queries , Gzip On.
