查看: 841|回复: 0
[提问] 反应器,如何使vlr-data-set的值变化
发表于 2022-10-23 05:50:36 | 显示全部楼层 |阅读模式
(defun c:test()
  (setq m (vlax-ename->vla-object(car(entsel))))
  (setq n 8)
  (setq l (vlr-object-reactor (list m ) n '((:vlr-modified . mm))))
  (defun mm(a b c)
    (setq nn (vlr-data b))
    (vlr-command-reactor a '((:vlr-commandEnded . nm)))
    (vlr-data-set b nn);如何使b=6,nn的值是个变量
  (defun nm(b c)
    (setq nn 6);如何使b=6,nn的值是个变量
GMT+8, 2026-1-16 03:07 , Processed in 0.167420 second(s), 25 queries , Gzip On.
