楼主: sunny_8848
[提问] 直线转换为矩形框
 楼主| 发表于 2022-11-26 13:56:39 | 显示全部楼层
xyp1964 发表于 2022-11-26 13:49
;; 神经元选择,代码需要e派工具箱的支持
谢谢帮忙,可是没有安装您这个工具箱
发表于 2022-11-26 15:22:10 | 显示全部楼层
sunny_8848 发表于 2022-11-26 13:56
谢谢帮忙,可是没有安装您这个工具箱
搜索:分堆
不用考虑他原始的样子,直接给她们各自重新套框,图层为图框,打印不可见色,就解决了
sunny_8848 + 1 很给力!
 楼主| 发表于 2022-11-26 16:09:37 | 显示全部楼层
cq4920 发表于 2022-11-26 15:22
搜索:分堆
分堆的方法效率很高,目前在上传的图纸中暂时发现多出一根线条
 楼主| 发表于 2022-11-26 16:37:29 | 显示全部楼层
;下面分堆的代码效率很高,限制也少。可惜矩形不是在图框层
(defun c:tt (/ wkjl ss lst obj maxp minp flst nlst maxpx maxpy pt )
  (IF (NULL *wkjl) (setq *wkjl 30.0))
   (setq wkjl (GETREAL (strcat "\n外扩距离<" (rtos *wkjl 2 2) ">:")))
   (if (NULL wkjl) (setq wkjl *wkjl) (setq *wkjl wkjl))
  (setq ss (ssget))
  (setq  lst
   (mapcar '(lambda (x)
        (setq obj (vlax-ename->vla-object x))
        (vla-getboundingbox obj 'minp 'maxp)
        (setq
          maxp (mapcar '* '(1.0 1.0) (vlax-safearray->list maxp))
        (setq
          minp (mapcar '* '(1.0 1.0) (vlax-safearray->list minp))
        (list x (car minp) (car maxp) (cadr minp) (cadr maxp))
     (vl-remove-if-not
       '(lambda (x) (= 'ENAME (type x)))
       (apply 'append (ssnamex ss))
  (setq  flst (lambda (lst key)
         (if lst
     (if key
         (setq nlst   (list (list (caar lst)
               (cadddr (car lst))
               (last (car lst))
         maxpx (caddar lst)
         lst   (cdr lst)
         (while (and lst (<= (cadar lst) maxpx))
           (setq nlst  (cons (list (caar lst)
                 (cadddr (car lst))
                 (last (car lst))
           nlst
           maxpx (max maxpx (caddar lst))
           lst   (cdr lst)
         (cons nlst (flst lst key))
         (setq nlst   (list (caar lst))
         maxpy (caddar lst)
         lst   (cdr lst)
         (while (and lst (<= (cadar lst) maxpy))
           (setq nlst  (cons (caar lst) nlst)
           maxpy (max maxpy (caddar lst))
           lst   (cdr lst)
  (setq
    lst
     (apply
       'append
       (mapcar
   '(lambda (wlst)
      (flst (vl-sort wlst '(lambda (a b) (< (cadr a) (cadr b))))
      nil
   (flst (vl-sort lst '(lambda (a b) (< (cadr a) (cadr b)))) t)
  (mapcar
    '(lambda (x)
       (setq pt (apply
   'append
   (mapcar
     '(lambda (ent)
        (vla-getboundingbox (vlax-ename->vla-object ent) 'minp 'maxp)
        (list (mapcar '* '(1.0 1.0) (vlax-safearray->list maxp))
       (setq minp (mapcar '- (apply 'mapcar (cons 'min pt)) (list wkjl wkjl)))
       (setq maxp (mapcar '+ (apply 'mapcar (cons 'max pt)) (list wkjl wkjl)))
       (entmake  (list '(0 . "LWPOLYLINE")
          '(100 . "AcDbEntity")
          '(100 . "AcDbPolyline")
          '(90 . 4)
          '(70 . 1)
          '(62 . 1)
          (cons 10 minp)
          (cons 10 (list (car minp) (cadr maxp)))
          (cons 10 maxp)
          (cons 10 (list (car maxp) (cadr minp)))
    lst
发表于 2022-11-27 14:58:34 | 显示全部楼层
(defun c:tt (/ wkjl ss lst obj maxp minp  ...
如果不考慮程式完成後須  1. 刪除原本外框的舊線段
                                     2. 刪除分堆程式所產生面積為零的重疊線段
只需修改程式1處及新增幾段程式便可很快完成
 楼主| 发表于 2022-11-27 15:02:53 | 显示全部楼层
谢谢。您给的最后一个文件已经很方便了
发表于 2022-11-27 15:05:14 | 显示全部楼层
若要考慮 上述2點
那就需多花些時間來排除
发表于 2022-11-27 15:06:16 | 显示全部楼层
了解! 收到...
发表于 2022-11-29 16:28:45 | 显示全部楼层
lee50310 发表于 2022-11-26 08:39
將外圍線替換為矩形框  程式 tt5
執行指令:tt5
很好用,谢谢lee分享。
如果可以批量闭合更好
发表于 2022-11-29 20:01:16 | 显示全部楼层
lxl217114 发表于 2022-11-29 16:28
很好用,谢谢lee分享。
如果可以批量闭合更好
批量 將外圍線替換為矩形框
程式已寫好放置 5樓
GMT+8, 2026-1-15 22:47 , Processed in 0.183969 second(s), 22 queries , Gzip On.
