查看: 3564|回复: 11
[经验] 视口比例
发表于 2023-1-7 09:54:43 | 显示全部楼层 |阅读模式
快捷键  sv  视口比例
(defun c:sv (/ bl)
(command"mview""l""off""all""");解锁所有视口
(command"mspace");从布局空间切换到视口模型空间
(if (setq bl (getreal "\n视口比例 1:"))
(command "zoom" "s" (strcat (rtos (/ 1.0 bl) 2 10) "xp")))
(command"pspace");从视口模型空间切换到布局空间
(command"mview""l""on""all""");锁定所有视口
(princ))
上面的程序为视口的标准比例,要怎样才能做到编辑视口标准比例的同时视口注释比例同步
 楼主| 发表于 2023-1-12 10:58:36 | 显示全部楼层
常用比例如下
快捷键  svxp  CAD视口默认的比例列表
(defun c:svxp()
(setvar "cmdecho" 0)
(command "-scalelistedit" "D" "*" "E" )
(setvar "expert" 5)
"A" "1:1" "1:1"
"A" "1:2" "1:2"
"A" "1:3" "1:3"
"A" "1:5" "1:5"
"A" "1:10" "1:10"
"A" "1:15" "1:15"
"A" "1:20" "1:20"
"A" "1:25" "1:25"
"A" "1:30" "1:30"
"A" "1:40" "1:40"
"A" "1:50" "1:50"
"A" "1:60" "1:60"
"A" "1:75" "1:75"
"A" "1:80" "1:80"
"A" "1:100" "1:100"
"A" "1:125" "1:125"
"A" "1:150" "1:150"
"A" "1:175" "1:175"
"A" "1:200" "1:200"
"A" "1:250" "1:250"
"A" "1:300" "1:300"
"A" "1:400" "1:400"
"A" "1:500" "1:500"
"A" "1:750" "1:750"
"A" "1:1000" "1:1000"
"A" "1:1500" "1:1500"
"A" "1:2000" "1:2000"
"A" "1:2500" "1:2500"
"A" "1:3000" "1:3000"
"A" "1:4000" "1:4000"
"A" "1:5000" "1:5000"
"E" )
(setvar "expert" 0)
(setvar "cmdecho" 1))
(c:svxp)
 楼主| 发表于 2025-5-12 23:03:38 | 显示全部楼层
快捷键  sv  视口比例
(defun c:sv (/ bl scl)
(command "mview" "l" "off" "all" "");解锁所有视口
(command "mspace");进入视口
(progn (setq scl (/ 1.0 bl))
(command "zoom" "s" (strcat (rtos scl 2 10) "xp"));设置视口缩放比例
(setvar "cannoscale" (strcat "1:" (rtos bl 2 0)))));同步注释比例
(command "ucsicon" "n");ucs坐标设为非原点
(command "ucsicon" "off");ucs坐标关
(command "navvcubedisplay" "0");viewcube图标关
(command "pspace");退出视口
(command "mview" "l" "on" "all" "");锁定所有视口
(princ))
这个代码可以做到同步视口注释,但不是整数的比例就不行了。还是不够通用,1:2、1:3 、1:4、这些比例也有常用到,还得等高手来解决完善一下
发表于 2023-1-9 21:32:37 | 显示全部楼层
(defun c:sv (/ bl)
(command "CANNOSCALE"  (strcat "1:" (rtos bl 2 1)))
(princ))
发表于 2023-1-8 07:12:42 | 显示全部楼层
谢谢楼主分享
发表于 2023-1-8 19:05:01 | 显示全部楼层
(command "CANNOSCALE"  aa);aa为注释比例,如“1:2"
 楼主| 发表于 2023-1-8 21:22:12 | 显示全部楼层
朋友在我上面程序上编辑视口比例,程序怎么改注释比例才同步?
 楼主| 发表于 2023-1-9 23:56:01 | 显示全部楼层
xzd716 发表于 2023-1-9 21:32
(defun c:sv (/ bl)
(command"mspace");从布局空间切换到 ...
经过测试不行,你那边可以吗
发表于 2023-1-10 11:30:48 | 显示全部楼层
谢谢分享        .
发表于 2023-1-10 21:12:21 | 显示全部楼层
可以,一次只能对一个视口设置
 楼主| 发表于 2023-1-11 14:38:25 | 显示全部楼层
xzd716 发表于 2023-1-10 21:12
可以,一次只能对一个视口设置
视口默认的比例列表如果没有需要的比例的情况下
运行此程序是不成功的
GMT+8, 2026-1-27 04:17 , Processed in 0.180284 second(s), 29 queries , Gzip On.
