- 积分
- 2655
- 明经币
- 个
- 注册时间
- 2007-9-23
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2024-5-5 15:15:11
显示全部楼层
'以下是cCommonDialog类的代码,建个类改名,把下面的代码放进去
#If VBA7 Then
Private Declare PtrSafe Function FILEOPEN Lib "CommonDialog.dll" (ByVal hOwner As Long, ByVal Title As String, ByVal FileSpec As String, ByVal Path As String, _
ByVal Fileter As String, ByVal DefExtension As String, ByVal FLAGS As Long, ByVal CenterFlag As Integer) As String
Private Declare PtrSafe Function FILESAVE Lib "CommonDialog.dll" (ByVal hOwner As Long, ByVal Title As String, ByVal FileSpec As String, ByVal Path As String, _
Private Declare PtrSafe Function BROWSEFOLDER Lib "CommonDialog.dll" (ByVal hOwner As Long, ByVal Title As String, ByVal Path As String) As String
Private Declare PtrSafe Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
#Else
Private Declare Function FILEOPEN Lib "CommonDialog32.dll" Alias "FILEOPEN@32" (ByVal hOwner As Long, ByVal Title As String, ByVal FileSpec As String, ByVal Path As String, _
Private Declare Function FILESAVE Lib "CommonDialog32.dll" Alias "FILESAVE@32" (ByVal hOwner As Long, ByVal Title As String, ByVal FileSpec As String, ByVal Path As String, _
Private Declare Function BROWSEFOLDER Lib "CommonDialog32.dll" Alias "BROWSEFOLDER@12" (ByVal hOwner As Long, ByVal Title As String, ByVal Path As String) As String
Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
#End If
'创建并显示打开的通用对话框。返回所选的文件名,如果选择了多个文件将会用“|”分隔列表。若无选择返回空字符。
'nFilename = FILEOPEN(hWndForm, 标题, 默认文件名, 初始目录, 筛选器, 默认扩展名, Flags, 中心)
'hOwner: (如果有) 的父窗口的句柄
'Title: 标题将显示为对话框的标题?
'FileSpec: 要显示的默认文件名。默认文件夹最后不能带 \ 字符
'Path: 对话框中将显示初始目录。如果此值为 null,则使用当前目录。
'Filter: 要在对话框中显示的文件的筛选器: 说明。这是一个分隔的字符串,将在"文件类型"组合框中产生可用的选项。
'例: "图像文件(*.bmp;*.jpg;*.jpeg;*.gif;*.png)|*.bmp;*.jpg;*.jpeg;*.gif;*.png"
'DefExtension: 默认文件扩展名适用于文件名,如果用户不提供一个。
'Flags: Win32 帮助下"OpenFileName"文件中所述的一个或多个值的组合。
'E.g.: OFN_ALLOWMULTISELECT Or OFN_FILEMUSTEXIST Or OFN_NOCHANGEDIR
'CenterFlag: TRUE 对中心对话框上的桌面屏幕。
Private Const OFN_ALLOWMULTISELECT = &H200 '指定文件名列表框允许多选?
Private Const OFN_CREATEPROMPT = &H2000 '如果用户指定了一个不存在的文件,这个标记使用对话框能提示用户是否新建这个文件。
Private Const OFN_ENABLEHOOK = &H20 '激活在lpfnHook成员中指定的钩子函数?
Private Const OFN_ENABLETEMPLATE = &H40 '当用户打开一个文件夹时,引起对话框发送CDN_INCLUDEITEM通知消息到你的OFNHookProc程序。
Private Const OFN_ENABLETEMPLATEHANDLE = &H80 'OFN_ENABLETEMPLATEHANDLE 指出hInstance成员能识别的包含预载对话框模板的数据块。如果这个标记被指定的,系统忽略lpTemplateName。
Private Const OFN_EXPLORER = &H80000 'OFN_EXPLORER 指出任何打开或另存为对话框使用新的Explorer风格的用户化模块?
Private Const OFN_EXTENSIONDIFFERENT = &H400 'OFN_EXTENSIONDIFFERENT 指定用户输入的一个文件的扩展名与lpstrDefExt指定的扩展名不同?
Private Const OFN_FILEMUSTEXIST = &H1000 'OFN_FILEMUSTEXIST 指定用户仅可以在文件名登录字段中输入已存在的文件的名字?
Private Const OFN_HIDEREADONLY = &H4 'OFN_HIDEREADONLY 隐藏只读复选框
Private Const OFN_LONGNAMES = &H200000 'OFN_LONGNAMES 对于旧风格对话框,这个标记引起对话框使用长文件名。
Private Const OFN_NOCHANGEDIR = &H8 'OFN_NOCHANGEDIR 如果当搜索文件时用户改变了目录的时候,恢复当前目录到它的初始值。
Private Const OFN_NODEREFERENCELINKS = &H100000 'OFN_NODEREFERENCELINKS 引导对话框为选择的快捷方式(.LNK)文件返回路径和文件名。
Private Const OFN_NOLONGNAMES = &H40000 'OFN_NOLONGNAMES 对于旧风格对话框,这个标识引起对话框去使用短文件名(8.3格式)。
Private Const OFN_NONETWORKBUTTON = &H20000 'OFN_NONETWORKBUTTON 隐藏和显示风格按钮?
Private Const OFN_NOREADONLYRETURN = &H8000 'OFN_NOREADONLYRETURN 指定返回的文件不带有只读复选框,不是在写保护的目录中。
Private Const OFN_NOTESTFILECREATE = &H10000 'OFN_NOTESTFILECREATE 指定文件不是在对话框关闭前建立的?
Private Const OFN_NOVALIDATE = &H100
Private Const OFN_OVERWRITEPROMPT = &H2 'OFN_OVERWRITEPROMPT 如果选择的文件已经存在,使用另存为对话框产生一个消息框。用户必须确认是否覆盖这个文件。
Private Const OFN_PATHMUSTEXIST = &H800 'OFN_PATHMUSTEXIST 指定用户仅能输入的路径和文件名?
Private Const OFN_READONLY = &H1 'OFN_READONLY 当对话框建立时,显示被选择的只读复选框。
Private Const OFN_SHAREAWARE = &H4000 'OFN_SHAREAWARE 指出如果调用OpenFile函数因为网络共享冲突而失败,这个错误被忽略并且对话框返回选择的文件名。
Private Const OFN_SHAREFALLTHROUGH = 2
Private Const OFN_SHARENOWARN = 1
Private Const OFN_SHAREWARN = 0
Private Const OFN_SHOWHELP = &H10 'OFN_SHOWHELP 使对话框显示帮助按钮?
'打开文件对话框
'FILEOPEN hWnd, "打开文件:", "", "c:\", "Text Files(*.txt)|*.txt|AutoCAD Files(*.dwg)|*.dwg", "dwg", OFN_ALLOWMULTISELECT + OFN_EXPLORER, 1
Public Function openDiaLog(ByVal OwnerTitle As String, ByVal InitPath As String, ByVal Filter As String, ByVal extName As String, ByVal MulSelect As Boolean) As String
Dim hWnd As Long
hWnd = FindWindow(vbNullString, Application.Caption)
openDiaLog = FILEOPEN(hWnd, "打开文件:", "", InitPath, Filter, extName, IIf(MulSelect = True, OFN_ALLOWMULTISELECT, 0) + OFN_EXPLORER, 1)
End Function
'保存文件对话框
'FILESAVE hWnd, "保存文件:", "", "c:\", "Text Files(*.txt)|*.txt|AutoCAD Files(*.dwg)|*.dwg", "dwg", OFN_EXPLORER, 1
Public Function SaveDiaLog(ByVal OwnerTitle As String, ByVal InitPath As String, ByVal Filter As String, ByVal extName As String) As String
Dim hWnd As Long
SaveDiaLog = FILESAVE(hWnd, "保存文件:", "", InitPath, Filter, extName, OFN_EXPLORER, 1)
End Function
'文件夹选择对话框
'MsgBox BROWSEFOLDER(hWnd, "文件夹:", "c:\")
Public Function DirDiaLog(ByVal OwnerTitle As String, ByVal InitPath As String) As String
Dim hWnd As Long
DirDiaLog = BROWSEFOLDER(hWnd, "文件夹:", InitPath)
End Function
Private Sub Class_Initialize()
Dim strPath As String, fileName As String
'拷文件到CAD程序文件夹
On Error Resume Next
strPath = Application.VBE.ActiveVBProject.fileName
strPath = Left(strPath, InStrRev(strPath, "\"))
fileName = strPath & "CommonDialog.dll"
FileCopy fileName, Application.Path & "\CommonDialog.dll"
fileName = strPath & "CommonDialog32.dll"
FileCopy fileName, Application.Path & "\CommonDialog32.dll"
End Sub
