楼主: 37902505
[提问] 求编一个画指定宽度矩形并填充的LSP
发表于 2023-6-15 14:03:43 | 显示全部楼层
谢谢分享源码。
发表于 2023-6-15 15:09:31 | 显示全部楼层
牛啊牛啊!大佬厉害
 楼主| 发表于 2023-6-15 15:14:28 | 显示全部楼层
老大,这里有个问题,横矩形生成的文字是以长边来的,竖矩形生成的文字才是以短边来的,能不能改成不管横竖都是以短边来命名的?
发表于 2023-6-15 20:43:13 | 显示全部楼层
37902505 发表于 2023-6-15 15:14
老大,这里有个问题,横矩形生成的文字是以长边来的,竖矩形生成的文字才是以短边来的,能不能改成不管横 ...
     (defun c:rect (/ pt1 pt2 width height)
(if (setq pt1 (getpoint "\n指定插入点: "))
  (setq pt2 (getcorner pt1 "指定对角点"))
  (command "RECTANG" pt1 pt2)
        (command "CHPROP" (entlast) "" "LA" "EQUIP_消防" "")
        (command "-bhatch" "p" "stars"  10 180 "s" (entlast) "" "")
  (command "CHPROP" (entlast) ""  "LA" "EQUIP_消防填充" "")
        (setq k  (rtos (abs (- (car pt1) (car pt2))))
        n  (rtos (abs (- (cadr pt1) (cadr pt2)))))
(if (> n k)
     (setq n k)
              (setq txt (strcat "XF" n " F"))
              (setq pt-xz-y (center-max-y pt1 pt2))
              (setq pt3 (list (car pt1) (cadr pt2)))
        (entmake (list '(0 . "TEXT") (cons 1 txt) (cons 11 pt-xz-y) (cons 10 pt2)
                        (cons 40 150)(cons 62 3)(cons 72 1)(cons 73 1)))
        (command "CHPROP" (entlast) ""  "LA" "EQUIP_消防文字" "")
(defun center-max-y (pt1 pt2)
(setq x-center (/ (+ (car pt1) (car pt2)) 2.0)
        y-max (max (cadr pt1) (cadr pt2)))
    (list x-center y-max))
有时候后会出错
 楼主| 发表于 2023-6-16 08:17:41 | 显示全部楼层
这个不错了,只是都是以长边命名,不是以短边命名。
发表于 2023-12-29 11:16:36 | 显示全部楼层
能不能弄一个,画完矩形后打开填充界面选择填充样式后直接填充
发表于 2023-12-30 10:03:13 | 显示全部楼层
能不能帮我改下这个 在你的基础上   我加个两个填充 能不能添加个选择
(defun c:tcc (/ pt1 pt2 width height)
      (SETQ PT1 (ENTLAST))
      (command "-bhatch"
               "p"
               "平面_石材1_比例1【YBC】"
               0.5
               45
               "s"
               (entlast)
      (command "-bhatch"
               "p"
               "立面_木饰面1_90度_比例600【YBC】"
               600
               90
               "s"
               (entlast)
      (ENTDEL PT1)
发表于 2023-12-30 14:45:36 | 显示全部楼层
  1. (defun c:tt ()
  2.   "画指定宽度矩形并填充"
  3.   (setq ll (getdist "\n矩形长度<1200>: "))
  4.   (or ll (setq ll 1200.))
  5.   (setq ww (getdist "\n矩形宽度<300>: "))
  6.   (or ww (setq ww 300.))
  7.   (setq th (getdist "\n矩形字高<100>: "))
  8.   (or th (setq th 100.))
  9.   (setvar "hpname" "STARS")
  10.   (setvar "HPSCALE" 10)
  11.   (setvar "hpang" 0)
  12.   (while (setq p0 (getpoint "\n中心点<退出>: "))
  13.     (setq p1 (mapcar '+ p0 (list (* ll -0.5) (* ww -0.5)))
  14.           p2 (mapcar '+ p0 (list (* ll 0.5) (* ww 0.5)))
  15.     )
  16.     (command "rectang" "non" p1 "non" p2)
  17.     (setq s1 (entlast))
  18.     (command "-hatch" "s" s1 "" "")
  19.     (setq tx (strcat "XF" (rtos ww 2 0) " F"))
  20.     (setq pt (mapcar '+ p0 (list 0 (+ (* ww 0.5) (* th 0.75)))))
  21.     (command "text" "j" "mc" "non" pt th 0 tx)
  22.   )
  23.   (princ)
  24. )
发表于 2023-12-30 14:47:54 | 显示全部楼层
  1. (defun c:tt ()
  2.   "画指定宽度矩形并填充"
  3.   (defun udist (bit kwd msg def bpt / inp)
  4.    (if def
  5.     (setq msg(strcat"\n"msg"<"(rtos def)">: ")
  6.           bit(* 2(fix(/ bit 2)))
  7.     )
  8.     (setq msg(strcat"\n"msg": "))
  9.   )
  10.   (initget bit kwd)
  11.   (setq inp(if bpt(getdist msg bpt)(getdist msg)))
  12.   (if inp inp def)
  13.   )
  14.   (or ll (setq ll 1200.))
  15.   (or ww (setq ww 300.))
  16.   (or th (setq th 100.))
  17.   (setq ll (Udist 7 "" "矩形长度<输入或鼠标直接量取>" ll nil))
  18.   (setq ww (Udist 7 "" "矩形宽度<输入或鼠标直接量取>" ww nil))
  19.   (setq th (Udist 7 "" "字高<输入或鼠标直接量取>" th nil))
  20.   (setvar "hpname" "STARS")
  21.   (setvar "HPSCALE" 10)
  22.   (setvar "hpang" 0)
  23.   (while (setq p0 (getpoint "\n中心点<退出>: "))
  24.     (setq p1 (mapcar '+ p0 (list (* ll -0.5) (* ww -0.5)))
  25.           p2 (mapcar '+ p0 (list (* ll 0.5) (* ww 0.5)))
  26.     )
  27.     (command "rectang" "non" p1 "non" p2)
  28.     (setq s1 (entlast))
  29.     (command "-hatch" "s" s1 "" "")
  30.     (setq tx (strcat "XF" (rtos ww 2 0) " F"))
  31.     (setq pt (mapcar '+ p0 (list 0 (+ (* ww 0.5) (* th 0.75)))))
  32.     (command "text" "j" "mc" "non" pt th 0 tx)
  33.   )
  34.   (princ)
  35. )
GMT+8, 2026-1-14 18:29 , Processed in 0.171588 second(s), 18 queries , Gzip On.
