楼主: `中微子
[提问] 又遇到一个表处理难题,请高手解决。顺带学习学习。
发表于 2023-8-15 17:18:01 | 显示全部楼层
`中微子 发表于 2023-8-15 16:16
请看9楼,也有同样的容差问题。求解决。辛苦了!!
(and (equal (+ (car e) (cadr e)) (car (nth (+ d i 1) waco))0.01)
               (= (caddr e) (caddr (nth (+ d i 1) waco)))
 楼主| 发表于 2023-8-15 20:50:51 | 显示全部楼层
               (= (caddr e) (caddr (nth ...
谢谢!成了,又多学习一个函数。
发表于 2023-8-16 06:53:52 | 显示全部楼层
  1. (setq waco1
  2. '((0 468.548 1) (468.548 1332.85 1) (3041.5 675.413 4) (5396.91 547.939 3) (5944.85 360.787 3) (7145.64 278.132 3) (7423.77 991.957 3) (8415.73 468.926 4)))
  3. (princ "原表:")(princ waco1)
  4. ;; 按色号排序并分组
  5. (setq waco1 (vl-sort
  6.               waco1
  7.               '(lambda (x y)
  8.                  (<
  9.                    (last x)
  10.                    (last y)))))
  11. (setq waco1 (list:group-by
  12.               waco1
  13.               '(lambda (x y)
  14.                  (=
  15.                    (last x)
  16.                    (last y)))))
  17. ;; 组内起点从小到大排序
  18. (setq waco1 (mapcar
  19.               '(lambda (x)
  20.                  (vl-sort
  21.                    x
  22.                    '(lambda (m n)
  23.                       (< (car m) (car n)))))
  24.               waco1))
  25. ;; (princ "\n排序表:")(princ waco1)
  26. ;; 合并同色且连续的,即前一个的起点+长度 >= 紧临表的起点
  27. (defun join-line (lst / res fuzz)
  28.   (setq fuzz 0.01)
  29.   (setq res (cons (car lst) nil))
  30.   (while (setq lst (cdr lst))
  31.     (if
  32.       (and
  33.         (setq f (car res))
  34.         (>= (+ (+ (car f) (cadr f)) fuzz) (caar lst)))
  35.       (setq res (cons
  36.                   (list
  37.                     (caar res)
  38.                     (max
  39.                       (+ (cadar lst) (- (caar lst) (caar res)))
  40.                       (cadar res))
  41.                     (last (car res)))
  42.                   (cdr res)))
  43.       (setq res (cons (car lst) res))))
  44.   (reverse res)
  45. )
  46. (princ "\n结果:")(princ (apply 'append (mapcar 'join-line waco1)))
  47. (princ)
非得有现成的函数才会用容差吗?
 楼主| 发表于 2023-8-17 00:24:03 | 显示全部楼层
vitalgg 发表于 2023-8-16 06:53
非得有现成的函数才会用容差吗?
谢谢!高手的代码改起来一下子糊涂了
发表于 2023-8-18 22:32:53 来自手机 | 显示全部楼层
overkill命令用一下
GMT+8, 2025-12-29 00:01 , Processed in 0.183778 second(s), 19 queries , Gzip On.
