楼主: mokson
[提问] viewsize 只获取了视图的高度, 那么它的宽度如何获取?
发表于 2024-11-2 20:48:59 | 显示全部楼层
nyistjz 发表于 2023-9-5 09:41
(setq
        pix (getvar "screensize") ;当前视口宽高像素值
        sc (/ (car pix) (cadr pix)) ;当前视口宽高比
请教一下,怎么设置“screensize”这个变量的值呢?“screensize”是只读属性,不能设置
发表于 2024-11-2 20:54:21 | 显示全部楼层
已经解决~嚯嚯~~~
发表于 2024-11-3 13:07:48 | 显示全部楼层
  1. (defun ScreenWin(/ h c);;当前屏幕对角坐标(wcs)
  2.   (setq c(trans(getvar'viewctr)1 0)
  3.         h(*(getvar'viewsize)0.5)
  4.         h(list(*(apply'/(getvar'screensize))h)h))
  5.   (mapcar'(lambda(x)(mapcar x c h))'(- +)))
(apply'command(cons"rectang"(SCREENWIN)));;绘制当前屏幕
(sssetfirst'nil(ssadd(entlast)))
GMT+8, 2026-1-13 11:40 , Processed in 0.163329 second(s), 19 queries , Gzip On.
