楼主: hhh454
[源码] 批量更新圆的半径
发表于 2023-11-6 00:26:34 | 显示全部楼层
hhh454 发表于 2023-11-4 13:49
需要加载院长的自定函数,论坛里面有
是这个函数吗?
(defun xyp-SubUpd (ename code val / ent x y i s1)
(cond ((= (type ename) 'ENAME)
(setq ent (entget ename))
(if (and (= (type code) 'LIST) (= (type val) 'LIST))
(mapcar '(lambda (x y) (xyp-SubUpd ename x y)) code val)
(if (= (xyp-dxf code ename) nil)
(entmod (append ent (list (cons code val))))
(entmod (subst (cons code val) (assoc code ent) ent))
(entupd ename)
((= (type ename) 'PICKSET)
(setq i -1)
(while (setq s1 (ssname ename (setq i (1+ i))))
(xyp-SubUpd s1 code val)
((= (type ename) 'LIST)
(foreach s1 ename (xyp-SubUpd s1 code val))
ename
xyp1964 + 1 赞一个!
发表于 2023-11-7 22:35:08 | 显示全部楼层
xyp1964 发表于 2023-11-4 09:52
(defun c:tt ()
  "批量更新圆或圆弧的半径"
  (setq rr (Ureal 7 "" "新半径" rr))
(defun c:11 ()
  "批量更新圆或圆弧的半径"
  (setq rr (getreal "输入新半径:"))
  (while (setq ss (ssget '((0 . "CIRCLE,ARC"))))
    (xyp-SubUpd ss 40 rr)
  (cond
       (progn (if (= (xyp-dxf code ename) nil)
              (entupd ename)
     (setq i -1)
  ename
(defun xyp-dxf (code ename / ent lst a)
  (if (= (type code) 'list)
    (progn (setq ent (entget ename))
           (setq lst nil)
           (foreach a code
             (setq lst (cons (list a (cdr (assoc a ent))) lst))
           (reverse lst)
    (progn (if (= code -3)
             (progn (cdr (assoc code (entget ename '("*")))))
             (progn (cdr (assoc code (entget ename))))
发表于 2023-11-7 22:36:27 | 显示全部楼层
LYC688 发表于 2023-11-7 22:35
(defun c:11 ()
  "批量更新圆或圆弧的半径"
感觉也不行
发表于 2023-11-7 22:41:07 | 显示全部楼层
(defun c:11 ()
  "批量更新圆或圆弧的半径"
院长的函数加在一起其实也挺长的呀
发表于 2023-11-7 23:17:25 | 显示全部楼层
感谢楼主分享,VERY GOOD
发表于 2023-11-14 09:41:09 | 显示全部楼层
很实用,小白一枚,向大佬学习
发表于 2023-11-18 10:14:43 | 显示全部楼层
我的2013  2024全可以用谢谢
lisp源码几乎全版本通用  发表于 2023-12-5 21:01
GMT+8, 2026-1-14 21:25 , Processed in 0.176202 second(s), 20 queries , Gzip On.
