查看: 1662|回复: 9
[提问] 关于批量定义C:xx函数的疑问
发表于 2023-12-27 03:31:53 | 显示全部楼层 |阅读模式
如下三个函数需要批量定义
  • (defun C:F1()
  • (alert "C:F1 !!!")
  • (princ)
  • (defun C:F2()
  • (alert "C:F2 !!!")
  • (princ)
  • (defun C:F3()
  • (alert "C:F3 !!!")
  • (princ)
  • (defun C:DEF()
  • (setq count 0)
  • (repeat 3
  • (setq count (1+ count))
  • (setq func-name (strcat "C:F" (itoa count)))
  • (eval
  • (list 'defun-q (read func-name) '()
  • '(alert (strcat "C:F" (itoa count) " !!!"))
  • '(princ)
  • (princ)
用以上代码批量定义就会出错,求各位大佬指点一下
C:F1 C:F2 C:F3都是提示 C:F3 !!!
发表于 2023-12-27 13:59:34 | 显示全部楼层
(setq cfxx '(defun-q C:FXX()(alert "C:FXX !!!")));定义
;这样写易读性强一些
;(eval cfxx);加载
(foreach x '("C:F1" "C:F2" "C:F3")
        (setq cfxx0 (vl-prin1-to-string cfxx))
        ;里面的字符串大小写不变,其余均大写
        (while(vl-string-search "C:FXX" cfxx0)
                (setq cfxx0(vl-string-subst x "C:FXX" cfxx0))
        );修改
        (eval(read cfxx0));加载
);重定义并加载了C:F1 C:F2 C:F3
发表于 2023-12-27 08:58:49 | 显示全部楼层
要字符串形式 然后eval
发表于 2023-12-27 09:10:38 | 显示全部楼层
  1. (setq count 0)
  2. (setq func-name (strcat "C:F" (itoa count)))
  3. (setq func (strcat  "(alert "          "" abc ""            ")"))
  4. (eval (read (strcat "(defun " func-name "()   ("  func  "))")))
发表于 2023-12-27 12:21:34 | 显示全部楼层
改为
(list 'alert (strcat "C:F" (itoa count) " !!!"))
发表于 2023-12-27 13:16:33 | 显示全部楼层
'(alert (strcat "C:F" (itoa count) " !!!"))导致定义函数的时候,其后的所有运算均不会进行,到了运行的时候,才会取相应的变量值按设定的方式进行处理
  1. (defun C:DEF()
  2.   (setq count 0)
  3.   (repeat 3
  4.     (setq count (1+ count))
  5.     (setq func-name (strcat "C:F" (itoa count)))
  6.     (eval(List 'defun-q (read func-name)nil
  7.                (list 'alert(strcat"C:F"(itoa count)"!!!!!"))
  8.                '(princ)))))
 楼主| 发表于 2023-12-27 20:04:21 | 显示全部楼层
感谢大神解惑,又学了一招
 楼主| 发表于 2023-12-27 20:05:31 | 显示全部楼层
改为
感谢大神解惑
 楼主| 发表于 2023-12-27 20:07:00 | 显示全部楼层
llsheng_73 发表于 2023-12-27 13:16
'(alert (strcat "C:F" (itoa count) " !!!"))导致定义函数的时候,其后的所有运算均不会进行,到了运行的 ...
发表于 2023-12-28 12:34:07 | 显示全部楼层
感谢大佬分享
GMT+8, 2025-10-27 05:13 , Processed in 0.180561 second(s), 27 queries , Gzip On.
