查看: 8247|回复: 30
[源码] 《块属性输出到excel》
发表于 2024-3-6 13:46:25 | 显示全部楼层 |阅读模式
;;; 《块属性输出到excel》
;;; 作者:langjs      命令:atoe
(defun c:atoe (/ active-sheet appxls ash cell col default elist ename ent i intcol j loop lst lst1 lst2
                 msxl-xl24hourclock n na name name0 newbook newitem newsheet nu numrow obj out path relcol relrow rng row
                 ss ss0 str tlb tlbfile tlbver ty xlcontinuous xlscells xlsworkbooks
              )                        ;  加载excel类型库
  (defun dsx-typelib-excel (/ path tlb)
    (setq obj (vlax-create-object "Excel.Application"))
    (setq path (vlax-get-property obj 'path))
    (cond
      ((setq tlb (findfile (strcat path "\\Excel8.olb")))
        tlb
      ((setq tlb (findfile (strcat path "\\Excel9.olb")))
        tlb
      ((setq tlb (findfile (strcat path "\\Excel10.olb")))
        tlb
      ((setq tlb (findfile (strcat path "\\Excel.exe")))
        tlb
      (t
        (alert "本系统内未找到EXCEL97、2000、2002、2003、2010,初始化失败!")
  )                                    ; 定义类型库接口
  (defun dsx-load-typelib-excel (/ tlbfile tlbver out)
    (cond
      ((null msxl-xl24hourclock)
        (if (setq tlbfile (dsx-typelib-excel)) ; 加载excel类型库
            (setq tlbver (substr (vl-filename-base tlbfile) 1 6))
            (cond
              ((= tlbver "10")
                (princ "\n初始化 Microsoft Excel 2002...")
              ((= tlbver "9")
                (princ "\n初始化 Microsoft Excel 2000...")
              ((= tlbver "8")
                (princ "\n初始化 Microsoft Excel 97...")
              ((= (vl-filename-base tlbfile) "Excel")
                (princ "\n初始化 Microsoft Excel ...")
            (vlax-import-type-library :tlb-filename tlbfile :methods-prefix "msxl-" :properties-prefix "msxl-"
                                      :constants-prefix "msxl-"
            (if msxl-xl24hourclock
              (setq out t)
      (t
        (setq out t)
    out
  )                                    ; 为选中的范围的实行自动调整宽度
  (defun dsx-excel-rangeautofit (active-sheet)
    (vlax-invoke-method (vlax-get-property (vlax-get-property (vlax-get-property active-sheet 'usedrange) 'cells)
                                           'columns
                        ) 'autofit
  )                                    ; 为选中的范围的实行网格线(自加)
  (defun dsx-excel-gridline (active-sheet)
                                           'columns
                        ) 'borderaround xlcontinuous default 1
  )                                    ; 为指定单元格填入颜色 (dsx-excel-put-cellcolor 1 1 14)
                                       ; 将颜色#14填入到单元格(1,a)
  (defun dsx-excel-put-cellcolor (row col intcol / rng)
    (setq rng (dsx-excel-get-cell ash row col))
    (msxl-put-colorindex (msxl-get-interior rng) intcol)
  )                                    ; 在活动的工作表中的单个单元格中获取数据; 获取行列范围内的单元格对象
  (defun dsx-excel-get-cell (rng relrow relcol)
    (vlax-variant-value (msxl-get-item (msxl-get-cells rng) (vlax-make-variant relrow) (vlax-make-variant relcol)))
  (defun data2cell (cell numrow col str) ; 写excel
    (vlax-put-property cell "item" numrow col (vl-princ-to-string str))
  (defun celltext (cell nu)            ; 把某一行或者列设置成文本各自nu"a:a"
    (vlax-put-property (msxl-get-range cell nu) "NumberFormat" (vlax-make-variant "@"))
  (defun initexcel ()
    (dsx-load-typelib-excel)
    (setq appxls (vlax-get-or-create-object "excel.application")
          xlsworkbooks (vlax-get-property appxls "workbooks")
          newbook (vlax-invoke-method xlsworkbooks "add")
          newsheet (vlax-get-property newbook "sheets")
          newitem (vlax-get-property newsheet "item" 1)
          xlscells (vlax-get-property newitem "cells")
          ash (msxl-get-activesheet appxls)
    (vla-put-visible appxls :vlax-true)
  (defun endexcel ()
    (vlax-release-object xlscells)
    (vlax-release-object newitem)
    (vlax-release-object newsheet)
    (vlax-release-object newbook)
    (vlax-release-object xlsworkbooks)
    (vlax-release-object appxls)
  (defun #err (s)
    (setvar "nomutt" 0)
    (if name0
      (redraw name0 4)
    (setq *error* $orr)
  (setq $orr *error*)
  (setq *error* #err)
  (vl-load-com)
  (setvar "cmdecho" 0)                 ; 关闭命令响应
  (setvar "nomutt" 1)
  (princ "\n 属性转EXCEL")
  (princ "\n选择属性块:")
  (while (not (and
                (setq ss0 (ssget ":E:S" (list '(0 . "insert") '(66 . 1))))
                (setq name0 (ssname ss0 0))
                (setq ent (entget name0))
                (setq na (assoc 2 ent))
    (if (= 52 (getvar "errno"))
      (vl-exit-with-error "")
  (if ss0
      (redraw name0 3)
      (princ "\n框选属性块:")
      (setq ss (ssget (list '(0 . "INSERT") na '(66 . 1))))
      (if (not ss)
        (setq ss ss0)
      (redraw name0 4)
      (setq ss (ssadd name0 ss))
      (setq lst '())
      (repeat (setq i (sslength ss))
        (setq name (ssname ss (setq i (1- i))))
        (setq ent (entget name))
        (setq ty (cdr (assoc 2 ent)))
        (setq ename (entnext name))
        (setq loop t)
        (setq lst1 '())
        (setq lst2 '())
        (while (and
                 ename
                 loop
          (setq elist (entget ename))
          (if (= (cdr (assoc 0 elist)) "ATTRIB")
              (setq lst1 (cons (cdr (assoc 1 elist)) lst1))
              (setq lst2 (cons (cdr (assoc 2 elist)) lst2))
            (setq loop nil)
          (setq ename (entnext ename))
        (setq lst (cons (reverse lst1) lst))
      (setq lst (cons (reverse lst2) lst))
      (initexcel)
      (celltext xlscells "B:B")
      (setq i 1)
      (foreach lst1 lst
        (setq j 1)
        (foreach n lst1
          (data2cell xlscells i j n)   ;    (dsx-excel-get-cell ash i j)
                                       ;    (dsx-excel-gridline ash)
          (setq j (1+ j))
        (setq i (1+ i))
      (dsx-excel-rangeautofit ash)
      (setq i 0)
      (repeat (length lst2)
        (dsx-excel-put-cellcolor 1 (setq i (1+ i))
                                 6
      (endexcel)
  (setvar "nomutt" 0)
ssyfeng + 1 赞一个!
发表于 2024-3-7 23:18:12 | 显示全部楼层
大师,请教您一个问题,我有一个将CAD里面通过xyz坐标将文字导出到excel, excel文字导出到CAD的程序,现在可以从CAD导出,但是目前没法导入。请教大神该如何修改呢。其实最佳的方式是将文件导出到已经打开excel中,然后在excel中修改后再导回CAD中。不知道能否实现呢。
(defun c:EXTCSV (/ ss i f ename text pos)
  (setq ss (ssget "X" '((0 . "TEXT,MTEXT"))))
  (if ss
      (setq f (open "D:/autocad_text.csv" "w"))
      (if f
          (write-line "TextString,X,Y,Z" f)
          (setq i -1)
          (repeat (sslength ss)
            (setq i (1+ i))
            (setq ename (ssname ss i))
            (setq text (cdr (assoc 1 (entget ename))))
            (setq pos (cdr (assoc 10 (entget ename))))
            (write-line (strcat text "," (rtos (car pos)) "," (rtos (cadr pos)) "," (rtos (caddr pos))) f)
          (close f)
          (princ "\nText has been exported to D:/autocad_text.csv")
        (princ "\nFailed to open file for writing.")
    (princ "\nNo text found in the drawing.")
(defun c:IMTCSV (/ f line fields text pos)
  (setq f (open "D:/autocad_text.csv" "r"))
  (if f
      (read-line f) ; Skip the header line
      (while (setq line (read-line f))
        (setq fields (strtok line ","))
        (setq text (nth 0 fields))
        (setq pos (list (atof (nth 1 fields)) (atof (nth 2 fields)) (atof (nth 3 fields))))
        (command "TEXT" pos "" "" text)
      (close f)
      (princ "\nText has been imported from D:/autocad_text.csv")
    (princ "\nFailed to open file for reading.")
我最近发的程序里有EXCEL导到CAD的程序,你可以参考下  发表于 2024-3-8 08:49
发表于 2024-3-8 15:58:06 | 显示全部楼层
yimiyangguang55 发表于 2024-3-7 23:18
大师,请教您一个问题,我有一个将CAD里面通过xyz坐标将文字导出到excel, excel文字导出到CAD的程序,现在 ...
正是慕名来找到您的帖子,
群里一个大神加了一段函数后,可以导出导入了。但是格式不一样,后处理特别码放。现在想请教您,有没有其他函数将导出导入的文字的格式一样。
导入函数加了这个语言,就可以运行了。
(defun STRTOK (str del / pos)
  (if (setq pos (vl-string-search del str))
    (cons (substr str 1 pos)
          (STRTOK (substr str (+ pos 1 (strlen del))) del)
    (list str)
发表于 2024-3-6 20:16:17 | 显示全部楼层
输出csv格式可能更通用:
(if (setq ss (ssget '((0 . "insert") (66 . 1))))
  (setq lst (mapcar 'xyp-Att2list (xyp-Ss2List ss))
        lst (mapcar '(lambda (x) (mapcar 'cdr x)) lst)
        lst (xyp-DelSame (apply 'append lst))
        aa (xyp-List2Csv lst)
发表于 2024-3-6 14:00:12 | 显示全部楼层
头香,感谢大师的分享
这一定要留存着使用
发表于 2024-3-6 14:19:41 | 显示全部楼层
大佬又发新作,非常顶。
发表于 2024-3-6 14:27:21 | 显示全部楼层
大佬 有发福利了,谢谢老师
发表于 2024-3-6 15:44:16 | 显示全部楼层
感谢大佬分享
发表于 2024-3-6 19:14:43 | 显示全部楼层
大佬连发,先都用看看再说。
发表于 2024-3-7 08:51:58 | 显示全部楼层
鹏程九万里,感谢郎大师!
发表于 2024-3-7 10:08:33 | 显示全部楼层
输出html格式,也是可以的,后缀改成xls
有些电脑不装微软excel ,装的wps
 楼主| 发表于 2024-3-7 10:23:42 | 显示全部楼层
xyp1964 发表于 2024-3-6 20:16
输出csv格式可能更通用:
主要是我几个程序是导出去再导回来,就用EXCEL编了
GMT+8, 2026-1-25 22:58 , Processed in 0.554102 second(s), 29 queries , Gzip On.
