查看: 1091|回复: 2
如何新建视口的同时指定图层跟锁定视口?
发表于 2024-3-31 13:41:44 | 显示全部楼层 |阅读模式
在布局画图中,CAD自带的新建视口图层跟视口显示都要分步操作,但在实际应用中,这两个功能却很少去改,为何不一开始在新建视口的同时默认指定图层(Defpoints)跟锁定图层(是)?
请大佬指教!
发表于 2024-3-31 14:42:01 | 显示全部楼层
(defun c:tt (/ p1 p2 v)
        (or (tblsearch "layer" "defpoints")
                (command "-layer" "m" "defpoints" "")
        (setq p1 (getpoint))
        (setq p2 (getcorner p1))
        (command "MVIEW" "non" p1 "non" p2)
        (setq v (entlast))
        (command "MVIEW" "l" "on" v "" "chprop" v "" "layer" "defpoints" "")
谢谢海总,还得是你啊。  发表于 2024-3-31 15:16
回复 支持 2 反对 0
GMT+8, 2026-1-23 19:46 , Processed in 0.166267 second(s), 24 queries , Gzip On.
